NEW OR UPDATED ARCADE CORES
DrOG
Re: NEW OR UPDATED ARCADE CORES
Postby DrOG » Fri Nov 24, 2017 6:28 am
Hi!
Tested the problematic cores on my BenQ, which dispays them fine, but the 'info' says they have non-standard refresh rates/resolutions over VGA:
Cosmic Avenger, Dorodon, Ladybug, Snapjack, Amidar, Frogger and Scramble are 640x500@61Hz.
Time Pilot is 640x500@62Hz.
Most weird is Computer Space, with 640x500@51Hz over VGA, and 720x240@51Hz over RGB.
Gehstock
Postby Gehstock » Wed Nov 29, 2017 10:03 am
Moon Patrol with Sound.I am far away from Home and can´t Test.
RGB should not work
Everett1954
Postby Everett1954 » Wed Nov 29, 2017 1:55 pm
Gehstock and Sorelig,
Thanks for all the great arcade core work you both have done for MIST. I enjoy them and hope to see more. I am also playing some arcade games that never made it to the US or were not popular here. They all display fine on my Westinghouse 32" LCD TV with VGA input. I have it wall mounted so I can flip the orientation easily.
With all the cores in general (8-Bit games, computers) I do not have any video problems. For me its the learning curve of some of the other computers i never had. My first computer was an Atari 400 and then an Amiga 1000.
Sorry got of topic a bit....Would love to see S.T.U.N Runner arcade by Atari if possible.
Gehstock
Postby Gehstock » Wed Nov 29, 2017 4:39 pm
Is Sound Working?
danielb
Postby danielb » Wed Nov 29, 2017 4:40 pm
Gehstock wrote:Is Sound Working?
Apparently not. I tried versions 1.00 and 1.05.
D.
DanyPPC
Postby DanyPPC » Wed Nov 29, 2017 5:05 pm
Idem here, no sound in Moon Patrol 1.00 and 1.05.
Anyway thanks
Gehstock
Postby Gehstock » Wed Nov 29, 2017 5:42 pm
Will See if i back Home
DrOG
Postby DrOG » Thu Nov 30, 2017 5:23 am
I confirm the bug report: no sound.
But compatible with my TV with 800x600@60Hz!
schombi
Postby schombi » Thu Nov 30, 2017 10:32 am
This is very likely a stupid question, but how to configure the two buttons in Moon Patrol (Fire/Jump)? Can "Jump" be set to "Joystick up"?
Gehstock
Postby Gehstock » Thu Nov 30, 2017 12:19 pm
Will change it in next Version
schombi
Postby schombi » Thu Nov 30, 2017 6:28 pm
+1
Thanks so much for all your work!
Gehstock
Postby Gehstock » Sun Dec 03, 2017 10:43 am
Maybe Sound Repaired(forgot a Wire) and Jumping Changed
danielb
Postby danielb » Sun Dec 03, 2017 11:00 am
Thanks! I'll try it this evening and let you know whether it worked.
D.
hyperterminal
Postby hyperterminal » Sun Dec 03, 2017 11:48 am
Gehstock wrote:Maybe Sound Repaired(forgot a Wire) and Jumping Changed
Thank you. I just tested it and there is still no sound.
danielb
Postby danielb » Sun Dec 03, 2017 3:53 pm
Confirmed.
D.
schombi
Postby schombi » Sun Dec 03, 2017 7:36 pm
"Jump" now works great with an Atari joystick. Also the rest seems pixel-perfect to me, so it´s just the sound that needs to be fixed. Thank you!!!
vebxenon
Postby vebxenon » Mon Dec 11, 2017 10:33 pm
Thanks for your great work! :D
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Gehstock
Postby Gehstock » Mon Dec 18, 2017 2:30 pm
6 new Arcade Ports on my Github
    The End
    Galaxian
    Mr. Do´s Nightmare
    Orbitron (Screen 180° rotated)
    Moon Cresta (Screen 180° rotated)
    Black Hole
DanyPPC
Postby DanyPPC » Mon Dec 18, 2017 3:17 pm
Oh, yes !
All to download :cheers:
Gehstock
Postby Gehstock » Mon Dec 18, 2017 3:43 pm
schombi wrote:Great! Many thanks to both of you!
I can´t seem to find the Galaga.rbf. I guess the problem is in front of the PC again... :wink:
Galaga/Phoenix: clean up, add Binarys
DanyPPC
Postby DanyPPC » Mon Dec 18, 2017 3:48 pm
Successfully tested ;)
Gehstock
Postby Gehstock » Mon Dec 18, 2017 3:51 pm
Please Someone make me a Picture from VGA Output, are there Graphic Problems?
DanyPPC
Postby DanyPPC » Mon Dec 18, 2017 4:00 pm
Here my TV/Monitor via VGA
Gehstock
Postby Gehstock » Mon Dec 18, 2017 4:06 pm
Even with you, the first line is missing in the font, needs to fix (Galaxian Hardware)
schombi
Postby schombi » Mon Dec 18, 2017 6:08 pm
Great, thanks!
Christmas would be perfect if we had Moon Patrol with working sound :wink:
Edit: or has it been fixed already?
