NEW OR UPDATED ARCADE CORES
vebxenon
Postby vebxenon » Mon Jan 30, 2017 7:59 am
Yes! Galaga arcade now on our MiST board! With sound and standard core menu! :cheers: :cheers:
https://github.com/sorgelig/Galaga_MIST ... r/releases
You must to rotate the monitor 90º clockwise, still no rotation.
Hope more arcade cores will be released or fixed :cheers: :cheers:
Thanks Sorgelig and Gehstock!
Regards,
Salva
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Re: New ported core by Sorgelig: GALAGA ARCADE
Postby DrOG » Mon Jan 30, 2017 8:19 am
Thank you again umpteenth time!
fury23
Re: New core by Sorgelig: GALAGA ARCADE
Postby fury23 » Mon Jan 30, 2017 9:32 am
Thank You!
Postby Sorgelig » Mon Jan 30, 2017 9:47 am
It's not my core.
MiST port has been started by Gehstock. He asked me to fix the video part.
Also i did some code cleanup and refactoring for possible future improvements or code study.
I think, this core will remain 90º turned to keep it compatible with TV signal. Actually it can be used as horizontal shooter ;) Buttons are also adapted for horizontal placement.
NML32
Postby NML32 » Mon Jan 30, 2017 9:52 am
Thank you Gehstock and Sorgelig for adding another Arcade title to the MiST. :D
vebxenon
GALAGA ARCADE
Postby vebxenon » Mon Jan 30, 2017 10:01 am
Sorgelig wrote:It's not my core.
Thanks very much! I've corrected the title :) And well, I'm able to rotate my monitor 8)
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
javidoom
Re: NEW CORE: GALAGA ARCADE
Postby javidoom » Mon Jan 30, 2017 10:15 am
Great news indeed!!
I have to find some spare time to give it a good try :)
Postby Newsdee » Mon Jan 30, 2017 11:55 am
If my count is right, this is the 40th MiST core! :D
DrChaos
Postby DrChaos » Mon Jan 30, 2017 1:19 pm
Galaga - excellent... Thanks to all developers. Does this core work on 15hz and 31khz?
fury23
Postby fury23 » Mon Jan 30, 2017 4:30 pm
It seems that it is possible to run other games on the same hardware: http://www.system16.com/hardware.php?id=516
Is it possible to load different roms from the same SD?
seastalker
Postby seastalker » Mon Jan 30, 2017 4:57 pm
WOW! Big thanks on this one!!!
Side edit:
Someone with access should update the first two cores' release dates as 2017 and not 2016 at https://github.com/mist-devel/mist-board/wiki (applies to Galaga and Sega Genesis/Megadrive)
Gehstock
Postby Gehstock » Mon Jan 30, 2017 5:36 pm
seastalker wrote:WOW! Big thanks on this one!!!
Side edit:
and add the Pet Core :D
on Both
slightley different
Currently working on Ladybug with Same Hardware like Cavenger,Dorodon,Snapjack and Space Raider
Next Core is
NML32
Postby NML32 » Mon Jan 30, 2017 7:54 pm
Does Galaga core support USB controller? I can only get the keyboard and db9 joystick to work.
I'm happy to see the MiST is getting more arcade titles.
vebxenon
Postby vebxenon » Tue Jan 31, 2017 7:51 am
Good work Gehstock! :D :cheers:
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrChaos
Postby DrChaos » Tue Jan 31, 2017 10:36 am
Phoenix! :cheers: Can't wait to see that. I think I need a new uprights ArcadeCab...
Postby Sorgelig » Wed Feb 01, 2017 2:08 am
test version with HQ2x scale.
(scale works with 31KHz mode obviously)
galaga_mist_hq2x.zip
MasterOfGizmo
Postby MasterOfGizmo » Wed Feb 01, 2017 10:17 am
Galaga is one of my favourites! :cheers:
MasterOfGizmo
Postby MasterOfGizmo » Wed Feb 01, 2017 10:20 am
Sorgelig wrote:I think, this core will remain 90º turned to keep it compatible with TV signal. Actually it can be used as horizontal shooter ;) Buttons are also adapted for horizontal placement.
It'*s probably time for me to write a OSD rotated by 90 deg ....
Gehstock
Postby Gehstock » Wed Feb 01, 2017 2:25 pm
Sorgelig wrote:test version with HQ2x scale.
The original never looked better :cheers: Please add to the Phoenix Core
fury23
Postby fury23 » Wed Feb 01, 2017 4:39 pm
Excellent! :D
Postby Sorgelig » Wed Feb 01, 2017 6:12 pm
Gehstock wrote:Please add to the Phoenix Core
i'm working on universal module, so i can add it to all my cores.
vebxenon
Postby vebxenon » Thu Feb 02, 2017 9:20 am
Yes :D
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrChaos
Postby DrChaos » Thu Feb 02, 2017 4:04 pm
I just saw that there are a couple of other FPGA cores annouced at the fpgaarcade forum and I hope we see some of these here as well. For example there is also a Galaga core, is that the same core as here?
Xevious VHDL source code has also been published, http://darfpga.blogspot.de/.
Unfortunately my skills are not sufficient to port cores and I am already a very happy MIST user and very greatful for the great support and number of cores available, so noone should misunderstand my posts...
Gehstock
Postby Gehstock » Thu Feb 02, 2017 4:15 pm
Xevious allready Checked, uses SRAM for Rom Content
Someone knows what this Screen on a Arcade Machine mean
have some Cores with it, think Rom decryption error
Darfpga
Postby Darfpga » Thu Feb 02, 2017 10:18 pm
Hello guys. There is no encryption on this. Read carefully README file, this core make use of external ram ( used to store rom program and graphics). You must implement this ram and load it in some manner. The screen you show means that the graphic character machine is running ok but the microprocessor is stopped or not correctly running.
Users browsing this forum: ManuFerHi and 3 guests
