KICK OFF 2 + WORLD CUP 90
kodak80
Re: KICK OFF 2 + WORLD CUP 90
Postby kodak80 » Sun Dec 04, 2016 9:31 pm
Tronic wrote:
kodak80 wrote:
Tronic wrote:I seem to have the same problem with Phantasie III The Wrath of Nikademus. I am trying to write Disk 1 back with 3 bombs too.
Any chance you could have a look at this too??? I imaged this from my original which is now lost :(
Tronic, you can check your dumps using AUFIT batch tool. It will produce images of the disks that will show any that are obvious bad dumps. Your Phantasie III disk 1 looks bad to me using AUFIT. Disk 2 looks good.
OK, does anyone have a version I can write back to disk using Kryoflux that works please?
Hi tronic. I did post a link to my Kryoflux dump of Phantasie III above. Let me know if this works or not. Here is the link again:
https://mega.nz/#!UsZQlRwb!8fONeE9tyUwG ... YzitOqYCY4
Tronic
Postby Tronic » Sun Dec 04, 2016 11:58 pm
kodak80 wrote:
Tronic wrote:
kodak80 wrote:Tronic, you can check your dumps using AUFIT batch tool. It will produce images of the disks that will show any that are obvious bad dumps. Your Phantasie III disk 1 looks bad to me using AUFIT. Disk 2 looks good.
No mate, it doesn't work. Data on the disk in Drive A: error when I navigate inside the AUTO folder due to non-booting :(
Atari STE, Mega STE, Atari STFM, UltraSatan, SatanDisk, Commodore 64, BBC Micro Model B, Playstation 1, Playstation 4, XBox 360, Amiga 600, Amiga 1200, Nintendo DS, Super Nintendo Classic Mini, Sony PSP and Super Nintendo.
http://www.ataristsales.com and http://stores.ebay.co.uk/Jays-Retro-Computer-Sales.
Atari ST demoscener, active in Effect^Elite since 1992! http://www.effect.org.uk.
kodak80
Postby kodak80 » Mon Dec 05, 2016 2:55 am
OK, I don't have access to the disks for a few weeks. I will try giving it a clean and re-dump when I get time. Anyone else have a copy they could share?
Tronic
Postby Tronic » Mon Dec 05, 2016 8:53 am
kodak80 wrote:
Tronic wrote:
kodak80 wrote:Hi tronic. I did post a link to my Kryoflux dump of Phantasie III above. Let me know if this works or not. Here is the link again:
I appreciate your help, thanks.
dlfrsilver
Postby dlfrsilver » Mon Dec 05, 2016 2:50 pm
Kodak, your dump is OK. The problem is the write back on disk. I guess it's one of the game needing to be in IPF, but your dump is seen as modified or not duplicated.....
Tronic
Postby Tronic » Mon Dec 05, 2016 2:52 pm
Can you please create an IPF?
dlfrsilver
Postby dlfrsilver » Mon Dec 05, 2016 11:59 pm
Tronic wrote:Can you please create an IPF?
I can't infortunately :/ the game is seen as either modified and/or unsupported.
kodak80
Postby kodak80 » Tue Dec 06, 2016 12:45 pm
Hi tronic. Try this Zipped KF RAW for Phantasie III disk 1:
https://mega.nz/#!Z8Ahmaoa!BB-bJ7jT1Jvw ... KpVR8p1fww
I converted the STX from Atarimania to KF RAW using the HxC Emulator software and then used my KF to write it back to a real floppy disk and it booted fine in my 1040STFM. Given that your disk 2 is fine, this should get going. :D
Tronic
Postby Tronic » Tue Dec 06, 2016 1:38 pm
Thanks man :) When I get home later, I'll check it :)
Brume
Red eyes
Red eyes
Postby Brume » Tue Dec 06, 2016 1:59 pm
Atarimania version has no protection : so you could even copy it with FastCopy or MSA on your ST, it should work (just convert the STX with HxC Emulator).
Also one file has been deleted on the disk... Strange. Is it a real dump of the original disk ?
Tronic
Postby Tronic » Tue Dec 06, 2016 5:23 pm
Works perfectly, thank you.
dlfrsilver
Postby dlfrsilver » Thu Dec 08, 2016 2:18 am
ah that's great :)
kodak80
Postby kodak80 » Thu Dec 08, 2016 8:25 am
Brume wrote:Atarimania version has no protection : so you could even copy it with FastCopy or MSA on your ST, it should work (just convert the STX with HxC Emulator).
Just checked the disk contents of my dump and it has exactly the same file and folders as the one from Atarimania. :shrug:
dlfrsilver
Postby dlfrsilver » Fri Dec 09, 2016 9:58 am
1 file has been deleted ? What file is it ?
StingRay
Postby StingRay » Tue Apr 24, 2018 10:22 am
Found this thread by coincidence, interesting disussion here regarding the Kick Off 2 protection... As someone who has cracked "a few" (i.e. all available protected Amiga versions) Kick Off 2 versions I can assure that Rob Northen didn't have anything to do with the protection at all. The encryption code is COMPLETELY different to anything Rob Northen ever made! Ijor and others are right, dlfrsilver is wrong! As simple as that.
We live, we die, we multiply.
Zippy
Postby Zippy » Tue Apr 24, 2018 10:58 pm
And I hacked the ST version and don't recall seeing anything that made me think Rob Northen had anything to do with it whatsoever. I got the impression that the protection was all done "in house" by Anco, at least on the software side, but the disc protection wasn't the usual Rob N type either.
It was a good protection, possibly the only time I had to release a fixed version a day or two later as I'd missed one checksum which wasn't discovered until a lot more testing had been done.
StingRay
Postby StingRay » Wed Apr 25, 2018 6:28 am
Protection was indeed made in-house by Anco. And it was one of the better ones back then as a lot of "crackers" didn't notice the various checksum checks which meant a lot of non-working "cracks" were released. The Cobra X-ROM encryption was neat too for its day, coding the decrypter took me a few hours when I first encountered this encryption. Same problem as with the various Rob Northen protections though, it was used for many Anco titles (Player Manager, Death Trap etc.) so it was a matter of coding the required decrypter once as it could be used for all incarnations of the protection.
dlfrsilver
Postby dlfrsilver » Wed Apr 25, 2018 5:36 pm
StingRay wrote:Found this thread by coincidence, interesting disussion here regarding the Kick Off 2 protection... As someone who has cracked "a few" (i.e. all available protected Amiga versions) Kick Off 2 versions I can assure that Rob Northen didn't have anything to do with the protection at all. The encryption code is COMPLETELY different to anything Rob Northen ever made! Ijor and others are right, dlfrsilver is wrong! As simple as that.
i have just said that i could not make an IPF because the disc was seen as either modified/unsupported. The protection on this game is in no way related to Rob Northern Copylock or did i missed something ? :)
StingRay
Postby StingRay » Wed Apr 25, 2018 6:18 pm
"i know he protected Kick Off (Amiga and ST) and Kick Off 3 (Amiga only). Maybe someone at Anco reworked his protection, it "could be" possible"
That's just one of your replies which can be found in this very thread. And it's interesting how you now claim that the protectiions is in no way related to RN Copylock. *Cough*! And just an aside, Rob Northen didn't protect Kick Off 3!
dlfrsilver
Postby dlfrsilver » Wed Apr 25, 2018 7:19 pm
StingRay wrote:"i know he protected Kick Off (Amiga and ST) and Kick Off 3 (Amiga only). Maybe someone at Anco reworked his protection, it "could be" possible"
the Amiga protection is called Anco copylock in the CTA. And i said maybe, there was nothing sure about it.
StingRay
Postby StingRay » Thu Apr 26, 2018 7:29 am
The Amiga protection is Anco's COBRA X-ROM. Same for the Atari version, yes I have just checked the code of the Atari version! And I also have, just for fun, started to code a decrypter for the Atari version too as I want to see how different the encryption is compared to the Amiga version.
StingRay
Postby StingRay » Fri Apr 27, 2018 10:05 pm
I have finished the decrypter for the Atari version of Kick Off 2, encryption is similar to the Amiga version, only in the final decryption loop different add.w/sub.w instructions are used for calculating the keys (Atari: sub, Amiga: add) which isn't too surprising as also for different Amiga titles these instructions differ (probably randomised). Source attached (quick and dirty hack which does the job).
Return to “Kryoflux”
