bug Point(x,y)
bug Point(x,y)
Postby rockyone » Sun Aug 14, 2016 2:43 pm
Bug in "Omikron 3.03" or in the "compiler 3.05" ?
POINT(X, y) returns the hardware color value of a point.
After compilation, the medium resolution value returned is not correct.
The values 2 and 3 are reversed!
Re: bug Point(x,y)
Postby shoggoth » Mon Aug 15, 2016 5:23 am
rockyone wrote:Bug in "Omikron 3.03" or in the "compiler 3.05" ?
Which VDI are you using?
Re: bug Point(x,y)
Postby rockyone » Mon Aug 15, 2016 2:11 pm
Steem v3.2
Tos 1.62 français
Re: bug Point(x,y)
Postby rockyone » Wed Aug 17, 2016 12:24 am
Re: bug Point(x,y)
Postby rockyone » Thu Sep 08, 2016 1:46 pm
Apart easy bug to compensate, the POINT(x,y) is two times faster than the function Line A $a002 Get Pixel
use save in "BMP" to test the two functions
TEST.zip
Return to “Other BASIC”
