Alternate TT hi/VGA adapter
CodeKiller
Re: Alternate TT hi/VGA adapter
Postby CodeKiller » Wed Oct 26, 2016 9:31 pm
Sorry, there hasn't been much progress, just a little re-design in the PCB, but still not finished.
Arawn
Postby Arawn » Wed Oct 26, 2016 11:58 pm
Hi there, I'm also interested in buying one, will keep this thread under watch. Thx.
1040STfm (Spanish), SM125 monitor, Megafile 30, 520STe (4MB), 520STfm (XtraRAM 1MB), Mega STe (4MB, 120MB HDD), Mega ST4, TT030 (4MB+64MB, 1.2GB HDD)
leech
Postby leech » Wed Nov 02, 2016 3:33 am
I'd like one as well.
CodeKiller
Postby CodeKiller » Wed Nov 02, 2016 6:30 pm
Ok guys, ordered PCBs and parts for another 10 pieces. Some minor tweaks and a power LED has been added.
I will post the updates after the parts arrived.
1st1
Postby 1st1 » Wed Nov 02, 2016 9:10 pm
Have you tested with NEC Multisync LCD 1990 FXp? I have Tenox adapter picture is not very stable with it. If this one makes stable picture (no horizontal flickering) I am also interested to take one.
CodeKiller
Postby CodeKiller » Wed Nov 02, 2016 9:26 pm
Sorry, i'm not even have my own atari TT --- no way I could get one of said monitor.
However during development, one TT from the 2 was available for me in HighRez mode had quite bad horizontal sync (fuzzy lines, unreadable screen) and after some time it cleaned up (maybe weak power supply?)
My adapter does almost the same as the Tenox, but can be turned off/on and only need common mini USB-B as power connector. Also has case too.
1st1
Postby 1st1 » Thu Nov 10, 2016 6:25 am
Does your adapter make something with the H and V sync signals, or it just passes them through?
CodeKiller
Postby CodeKiller » Thu Nov 10, 2016 10:30 am
If switched to Hi-Res mode, the H signal get delayed a bit, otherwise the picture would be too much in the right side.
In normal VGA mode both H and V transmitted uninterrupted.
CodeKiller
Postby CodeKiller » Mon Dec 12, 2016 6:03 pm
Just a brief update:
The boards are almost ready, just a few parts missing (ic, switch, case)
CodeKiller
Postby CodeKiller » Fri Jan 06, 2017 2:16 pm
10 boards are ready, tested, working :)
Housing also ready.
PM me if you would like to buy.
Arawn
Postby Arawn » Fri Jan 06, 2017 4:05 pm
Contacted. :)
simonj5
Postby simonj5 » Fri Jan 13, 2017 1:02 pm
Contacted and purchased :-)
CodeKiller
Postby CodeKiller » Thu Jan 19, 2017 5:38 pm
6 units are still available!
A bit extra info:
-it has a bit better connection-- totally separated input power (no ground-loop issues) -- older one may have issue if the connector shielding is connected to GND
-has power indicator LED "hidden" inside the case, if better visuals needed, you can drill a hole for it..
-consumes only 70mA in idle/VGA mode and ~85mA in High-Resolution/ECL mode
-switch is smaller, only the handle hags out from the case
Arawn
Postby Arawn » Fri Jan 27, 2017 5:58 pm
It has arrived and it works great! Thank you, CodeKiller! :D
There's a moiré pattern but I just played with it quickly to adjust the image, might be able to clean it spending some more time adjusting it. Also the LCD monitor is a chinese low quality one I have around (17" Haier branded).
CodeKiller
Postby CodeKiller » Fri Jan 27, 2017 7:55 pm
Yup. this adapter only translates the signal type but not scales the image. It has to be adjusted in your monitor.
It looks like your monitor scales vertically -- the TT's image width is pretty standard 1280px, but the height is the not so common 960px -- maybe it tries to stretch out to 1024.
vido
Postby vido » Fri Jan 27, 2017 8:28 pm
I also received mine.
bid
Postby bid » Sat Jan 28, 2017 5:10 pm
Mine also came, and I am very grateful! ... The build quality is excellent, and I am looking forward to trying it when I get a free moment!
My company website http://www.thebigconsultant.com[/i][/color]
Arawn
Postby Arawn » Mon Jan 30, 2017 1:18 am
All the monitors I've tried will scale vertically and cannot reduce size. There will always be some moiré at high res. Best way is either all white or all black background. On the other hand I think it's for the best since old CRT monitors were 4:3 ratio and newer non wide LCD are 5:4, which means the pixel will be square. You can confirm this in the pic I took, the icons and text are well proportioned.
CodeKiller
Postby CodeKiller » Sun Feb 05, 2017 1:03 pm
5 units are still available
CodeKiller
Postby CodeKiller » Thu Mar 09, 2017 7:42 pm
There are still 4 units remaining!
alienkidmj12
Postby alienkidmj12 » Thu Mar 09, 2017 9:57 pm
Cost? ;)
CodeKiller
Postby CodeKiller » Thu Mar 09, 2017 10:02 pm
alienkidmj12 wrote:Cost? ;)
As in the first post: 50€ + 6€ shipping world wide.
leech
Postby leech » Sat Mar 11, 2017 5:19 pm
I ordered one, and have a lot of monitors to test it on.
CodeKiller
Postby CodeKiller » Sun Mar 12, 2017 1:54 pm
All 4 has been sold. but if there is still interest for another 10, I can build more...
Gaiyan
Postby Gaiyan » Thu Mar 16, 2017 5:05 pm
Oh noooo. I came in too late. I'm up for one please!
