Minimal multitask configuration for Hatari
OL
Re: Minimal multitask configuration for Hatari
Postby OL » Tue Jul 11, 2017 8:55 pm
sashapont wrote:OL, Can you upload your configuration for aranym?
Yes of course what you expect to find in this configuration, because I have several. I suppose you want something with video more compatible than fVDI using Videl extension as I alreday describe using videl inside. I have this in very basic configuration need TOS4 to run.
If you want in more Mint + MyAES I have to build it, I have only configuration with fVDI with this components but of course it is possible to do it, just need a bit time to do it.
OL
sashapont
Postby sashapont » Wed Jul 12, 2017 8:46 am
Thank you! Can you explain, how to map joystick to keyboard in aranym?
Atari Falcon, Firebee
OL
Postby OL » Wed Jul 12, 2017 6:37 pm
sashapont wrote:Thank you! Can you explain, how to map joystick to keyboard in aranym?
I don't know, I think Aranym itself not do this.
You still want Aranym config with videl inside in simple TOS configuration?
OL
sashapont
Postby sashapont » Wed Jul 12, 2017 6:40 pm
I want very much you configuration with myAes for aranym with tos (without emutos) with big resolution and true color :) And without hard disk images (if it possible)
OL
Postby OL » Thu Jul 13, 2017 5:47 pm
sashapont wrote:I want very much you configuration with myAes for aranym with tos (without emutos) with big resolution and true color :) And without hard disk images (if it possible)
All this conditions are not possible!
TOS and without hard disk image is not possible under Aranym, without image disk need Emutos, but really I not see any interest to use TOS if you want in same time true color (32 bits so fVDI), MyAES and Mint, because Mint replace near all Emutos use only to boot because with fVDI you probably lost compatibility and TOS vs Emutos only add DSP management and I think most software using DSP (if it work not sure) will don't like fVDI I think. The configuration of the video is with Emutos.
Olivier
OL
sashapont
Postby sashapont » Thu Jul 13, 2017 7:42 pm
And wat can you say about tos games under emutos? I cannot start anything :( tomoraw I try to upload my arcanaranym config with myaes without hard disk images...
Postby Eero Tamminen » Thu Jul 13, 2017 10:10 pm
In general you shouldn't have EmuTOS related problems with games under Aranym.
The main remaining issues with EmuTOS and games are...
Bugs in games that EmuTOS can do nothing about:
  • Dirty, floppy-only, TOS-version specific games that happen to work just by pure luck on real TOS (not to overwrite themselves etc). Just use HD fixed versions of those
  • STOS games that use undocumented, TOS-version specific memory addresses to handle input. Just use versions fixed for newer TOS versions instead
Missing EmuTOS Falcon features:
  • Games using DSP e.g. for music. EmuTOS doesn't have DSP functions support yet, but Aranym's DSP support isn't accurate enough for games either, so it doesn't matter
  • Few games that require TOS support for setting or using 16-bit HiColor mode. If it's GEM game, just use VDI replacement like fVDI
I.e. in summary, the only games issue with EmuTOS on Aranym is with non-GEM Falcon games requiring 16-bit HiColor mode, and which use XBios() call to set the 16-bit mode instead of poking the regs directly. There aren't that many of them.
OL
Postby OL » Fri Jul 14, 2017 9:24 am
sashapont wrote:And wat can you say about tos games under emutos? I cannot start anything :( tomoraw I try to upload my arcanaranym config with myaes without hard disk images...
9 years ago I have done a page of Aranym (http://aranym.lutece.net), it is outdated but minimal Falcon configuration should still work, I'm looking to update it soon.
OL
sashapont
Postby sashapont » Fri Jul 14, 2017 3:20 pm
It is link to aranym configuration without hd images with tos and with true color.
https://cloud.mail.ru/public/MMie/fwN2dtm8V
Please can you help me configure keyboard for joystick emulation? And fix problem with ztask start?
OL
Postby OL » Fri Jul 14, 2017 4:32 pm
sashapont wrote:It is link to aranym configuration without hd images with tos and with true color.
I know very well this configuration I have done it!
But it have been lightly modified as I can see adding a floppy drive with Auto folder (it replace the HD image)
For Joystick emulation, I have already answer and the answer is no I don't know how to do this, perhaps someone know an Joystick emulator for Atari?
For the second I have also anwer and I think yes.
OL
sashapont
Postby sashapont » Fri Jul 14, 2017 6:07 pm
Thank you! Fix for task is working.
What we have in this moment
1. In Hatari we have joystick emulation but there are no emulation for high resolution, true color and network
2. In Aranym we have high resolution, true color and network, but undocumented joystick emulation :( And same games (also modern try prince of Persia from games folder) is not work
OL
Postby OL » Sat Jul 15, 2017 4:45 pm
sashapont wrote:Thank you! Fix for task is working.
Just replace in Drive/gemsys/myaes/ the content of this zip file
app_conf.zip
Notice I give you the answer in a previous message
OL
OL
Postby OL » Mon Oct 02, 2017 6:37 pm
I just updated the minimal configuration with the new MyAES 68000 version, other files have not been changed, you can too just take the patch file from MyAES website and copy the new version in your configuration.
Olivier
OL
OL
Postby OL » Tue Oct 24, 2017 8:42 pm
New version in download
In black and white Mint + MyAES + Teradesk 4Mb of ram, free memory is now at 1Mb
OL wrote:I just updated the minimal configuration with the new MyAES 68000 version, other files have not been changed, you can too just take the patch file from MyAES website and copy the new version in your configuration.
Olivier
OL
OL
Postby OL » Sat Oct 05, 2019 4:06 pm
Hello
new myhatari configuration, Mint and MyAES for Hatari directly on host file system without virtual hard disk.
Update of MyAES to fix bugs and add new features
Newe features :
- Single application mode (one application by screen with key word smartphone_gui = true or false (default false))
- Insulation application mode for application not t aking too much account other application with menu fix as under TOS (key word configuration: APPP_SINGLE applicationname)
- Applications cycle with CTRL+ALT+n or on Atari computer CTRL+ALT+TAB
bugs fix:
-Focus manager rewrite, far faster and accurate now
- Fix cursor edit
-Memory copy block too short if screen size was not a multiple from 16 (not very common!)
-Possible not receive of MU_M1 MU_M2 in some case of use of evnt_multi.
Compiled under Atari system with GCC 7
Always at same place http://myaes.lutece.net/telechargement/myhatari.zip
Olivier
OL
Postby Cyprian » Sun Oct 06, 2019 11:46 am
Many thanks Oliver!
two remarks (Hatari, ST mode, ST-HIGH, 14MB RAM):
1) in ST Mono mode, there is no a black line between a window's title and window's file information area (marked blue) and file information font size is too small (in comparison to TOS / EmuTOS) - marked red:
2) Qed doesn't work properly:
OL
Postby OL » Sun Oct 06, 2019 4:03 pm
Hello
I will check redraw issues
For Qed for me it work as expected, pay attention it take several second before start at 8Mhz and menu looks not display, you should go on top of screen to display menu or change option in myaes.cnf
from
flying_menu = true
to
flying_menu = false
I not see issue with this software
Olivier
Cyprian wrote:Many thanks Oliver!
OL
Postby Cyprian » Sun Oct 06, 2019 4:49 pm
OK, I've recheck and QED works fine.
My fault, as you mentioned the menu was hidden.
---edit---
when I click "Open" from "File" menu, then menu is grayed but nothing happen, there is no fileselector. After a while, menu is normal again.,
OL
Postby OL » Sun Oct 06, 2019 7:48 pm
Cyprian wrote:OK, I've recheck and QED works fine.
---edit---
Same for me :-(
I have done a quick check with normal myaes compiled with PureC in 68020 (just change CPU emulation) it work, it is not link to 68020 looks like there is something wrong with the compilation configuration (as it is light version) or something wrong with GCC7, first time I use it. I'm going to fix this
OL
OL
Postby OL » Mon Oct 07, 2019 10:32 pm
Hello
- File selector issue is fixed now, in the previous version appl_getinfo report FSLX_selector support while it is not and Qed use fslx_xxx functions
- A bit faster text redraw
- Now PureC 68000 version version, it reduce size memory used by MyAES.
Not yet fix small redraw window info menu
myhatari.zip updated
Olivier
---edit---
Same for me :-(
OL
Postby Cyprian » Tue Oct 08, 2019 9:38 am
I play a bit with QED and observed a few issues:
Sometimes I see two mouse cursors (one of them is leftover I guess )
Menu "File" is not unselected after open file:
Sometimes when I try to move fileselector BUS ERROR is thrown:
OL
Postby OL » Tue Oct 08, 2019 10:23 pm
Cyprian wrote:I play a bit with QED and observed a few issues:
I can reproduce crash, and I know exactly where it is, in fact it crash on vs_clip(handle, 0, NULL) this is emutos crashing, strange there will have an update tomorrow because I not need to do so much vs_clip, I'm going to find a solution.
Olivier
OL
BlankVector
Postby BlankVector » Wed Oct 09, 2019 12:10 am
Some QED versions may have issues if the USERDEF stack is very small, like in plain TOS/EmuTOS. No such thing happens with XaAES. I have no idea if this can cause trouble in MyAES. This could also be an EmuTOS bug, of course.
OL
Postby OL » Wed Oct 09, 2019 8:31 pm
BlankVector wrote:Some QED versions may have issues if the USERDEF stack is very small, like in plain TOS/EmuTOS. No such thing happens with XaAES. I have no idea if this can cause trouble in MyAES. This could also be an EmuTOS bug, of course.
Hello Vincent,
it is not an issue of stack of the AES, under MyAES stack for userdef is large and it was not under userdef. Now I have fixed the issue but I not understand I just do differently and it work but in fact there was something not nice in MyAES because I do vro_cpyfm without vs_clip even I'm sure I not go copy position was not outside the buffer or the screen, now I have added a clip of the size of the screen to be sure and I reduce highly number of call of vs_clip() , could it be call of several vs_clip(handle, 0, NULL) just one after the other could be an issue ? Now no more crash, I don't know if it is MyAES issue or Emutos or the twice!
Olivier
OL
OL
Postby OL » Wed Oct 09, 2019 8:35 pm
hello Cyprian,
crash is now fixed, mouse ghost is fixed and info area text is now center and there is a line between window name and info. I have fixed too the call or not of external selector depending of computer memory, now for 4MB computer external file selector is no more called and internal file selector is used (not very nice but globally work this looks more to TOS file selector)
Olivier
OL
Return to “Hatari”
