SMS core
DanyPPC
Re: SMS core
Postby DanyPPC » Thu Mar 21, 2019 4:33 pm
Thanks Slingshot, I tested the new release with various games without any problem.
:wink:
PsyFX
Re: SMS core
Postby PsyFX » Thu Mar 21, 2019 4:40 pm
slingshot wrote:Here's a fix for Shadow Dancer:
https://github.com/mist-devel/mist-bina ... 190320.rbf
Hope didn't break other games.
I'll test once the "mister" build is updated
Thanks Slingshot!
Lroby74
Re: SMS core
Postby Lroby74 » Wed Apr 17, 2019 10:09 am
seastalker wrote:Actually, WOW, that works! Thanks! It shows the boot loader splash screen for a brief moment first but does immediately launch a title as you directed.
Try to disable SMS Bios on OSD menù :)
theflynn49
Re: SMS core
Postby theflynn49 » Mon May 06, 2019 12:16 pm
Hello fellow SMSers,
Allow me to put here a modified-for-MiST copy of the message I put on the MiSTer forum recently, because as you know the core share the same sources for the two plateforms :
I just released a new core, from a new branch, named sms_mist_20190507.rbf and you can find it here https://github.com/theflynn49/MiSTer_co ... /mode2-msx
This core supports
- mode2 graphics (like in f16 fighter)
- SMS/MSX dual compatible games (like in Cyborg Z),
- SG-1000 games (like in .. err you know.)
- there are a lot of SMS enhancements ahead of the march release
The question that arose is that this core has a lot of modifications in the graphic engine, more than usual, and maybe I broke a few things ...
So it would be nice if you'd test it thoroughly to see if you can find any regression, I mean any SMS native game that worked but doesn't work properly with this new core, and, at the end, choose which branch you want to keep : the new one or the old one more simple.
A few more goodies :
- most SMSMSX games need the OSD parameter "no bios"
- some of them need a patch :
F-1 Spirit : adr $0000 is : F3 C3 E4 00 00 00 should be : 41 42 F3 C3 E4 00
Knightmare II : adr $0000 is : F3 C3 A5 00 00 00 s/b : 41 42 F3 C3 A5 00
Nemesis2 : adr $0000 is F3 C3 E9 00 00 00 s/b : 41 42 F3 C3 E9 00
Penguin Adv : adr $0000 is F3 C3 A6 00 00 00 s/b : 41 42 F3 C3 A6 00
Thank you all.
slingshot
Re: SMS core
Postby slingshot » Mon May 06, 2019 2:20 pm
Great, you really like to hack on this core :)
DanyPPC
Re: SMS core
Postby DanyPPC » Mon May 06, 2019 4:42 pm
Excuse me, perhaps I'dont understand.
Can I play MSX roms games with this core in order SMS/GG/SG ?
And what I need ?
DanyPPC
Re: SMS core
Postby DanyPPC » Mon May 06, 2019 6:04 pm
Ok, perhaps I understand: this new core for MiST doesn't incorporate MSX mapper.
Anyway thanks for the improvements :cheers:
theflynn49
Re: SMS core
Postby theflynn49 » Mon May 06, 2019 6:49 pm
@slingshot : lol ... what's not to like in it ? You know how much fun this is when the thing gets alive.
@DanyPPC : my bad, this is confusing. There is a small list of about 10 games, written mainly by Zemina, said to be "dual compatible" with SMS and MSX (the same physical cartridge works in both machines). This is what this core supports. To play a MSX game you need the MSX core, I guess.
see: http://www.smspower.org/Tags/MSXCompatibleROM and http://www.smspower.org/Tags/MSXPort
slingshot
Re: SMS core
Postby slingshot » Mon May 06, 2019 8:14 pm
theflynn49 wrote:@slingshot : lol ... what's not to like in it ? You know how much fun this is when the thing gets alive.
Of course...it develops an addiction :)
vebxenon
Re: SMS core
Postby vebxenon » Wed May 29, 2019 10:03 pm
Just a question... can a black or some colour or artwork border be put around the Game Gear games? Border changes when you are playing and it's a bit annoying sometimes...
I'm very happpy with this core :D :cheers: :cheers: . Apart from the border in Game Gear, the only problem I've found is the FM music on Afterburner, in the title screen, it sounds bad :shrug:
Thanks for your great work!
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Higgy
Re: SMS core
Postby Higgy » Thu May 30, 2019 8:41 pm
Remember quite a lot of GameGear games have been converted to SMS format. I mean ROM hacks, not official SMS versions of GG games.
So you should get a better screen size. I love the GG Shinobi games.
I think the website is SMS Power which hosts the patch files (no ROMs).
vebxenon
Re: SMS core
Postby vebxenon » Thu May 30, 2019 11:31 pm
Higgy wrote:Remember quite a lot of GameGear games have been converted to SMS format. I mean ROM hacks, not official SMS versions of GG games.
Only few games have been correctly pached. I tried some months ago all the patches and I have four in my MiST card. I stay with The GG games :-)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
hyperterminal
Re: SMS core
Postby hyperterminal » Fri May 31, 2019 4:11 am
In the MiSTer version of the SMS core, there is an option to disable the border, so that everything around the visible screen area is black. It might be possible to port this over to the MiST core.
Sheldon
Re: SMS core
Postby Sheldon » Thu Jun 20, 2019 9:58 am
with las core sms_190524.rbf and last firmware firmware_190601.upg only one button work with a usb pad.
i'm alone ? or not.
it works for you ?
DanyPPC
Re: SMS core
Postby DanyPPC » Thu Jun 20, 2019 4:18 pm
Check your controller.
slingshot
Re: SMS core
Postby slingshot » Thu Jun 20, 2019 5:54 pm
Try the input test in the OSD, it's independent of the core.
Sheldon
Re: SMS core
Postby Sheldon » Thu Jun 20, 2019 8:21 pm
slingshot wrote:Try the input test in the OSD, it's independent of the core.
Yes very big evolution !!!
i check many core with same usb pad from mist beginning :): easy before and now need more work:
for Sega Master System Core:
1) setting joystick_remap for all your usb pad (min right,left,down,up,A,B,select,start)
2) setting Swap joysticks to yes
and you can play alex kid for example :D
slingshot
Re: SMS core
Postby slingshot » Sat Jun 22, 2019 7:44 pm
Sheldon wrote:i check many core with same usb pad from mist beginning :): easy before and now need more work:
Probably you have a gamepad which had hardcoded mapping in the firmware, but this was removed I think last December. So you really must had an old release installed.
vebxenon
Re: SMS core
Postby vebxenon » Tue Oct 08, 2019 8:58 am
Do you know if FM music issue (test for example After Burner) will be dices? :)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Re: SMS core
Postby vebxenon » Wed Oct 16, 2019 8:17 am
vebxenon wrote:Do you know if FM music issue (test for example After Burner) will be fixed? :)
Fixed :shrug: , my phone changed the last word...
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Re: SMS core
Postby vebxenon » Wed Oct 16, 2019 8:18 am
hyperterminal wrote:In the MiSTer version of the SMS core, there is an option to disable the border, so that everything around the visible screen area is black. It might be possible to port this over to the MiST core.
That's a good option.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Users browsing this forum: No registered users and 14 guests
