SMS core
SMS core
Postby Newsdee » Sat Jun 04, 2016 12:10 am
Splitting the discussion from over the SAM Coupe thread :)
The ZxUno seems to have made some improvements to the SMS core, perhaps they can be backported into the MiST.
SVN:
http://www.atc.us.es/svn/zxuno/cores/sm ... an6/test2/
login:
guest/zxuno
Re: SMS core
Postby Newsdee » Sat Jun 04, 2016 12:16 am
Quoting from original thread:
MasterOfGizmo wrote:Ok, found the comment and adjusted the audio pitch. Will check if there are more fixes we might have a use for. But maybe this discussion should not continue in the SAM Coupe thread ...
Thanks a lot! I'll give the new core a try.
Re: SMS core
Postby Newsdee » Sun Jun 05, 2016 9:49 am
Thanks! The sound is much nicer now!
The video in NTSC is a bit scrunched though (too narrow) - the PAL version seems more correct, but then the games run slower.
vebxenon
Re: SMS core
Postby vebxenon » Mon Jun 06, 2016 8:55 am
Thanks for the audio fixing! :-) About NTSC on SMS, most games were released only at Europe, so PAL 50 HZ is the most common configuration to play SMS games.
About FM sound, FM chip is the OPLL, the same is on MSX, which MSX core has :-)
Regards,
Salva
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
ericgus
Re: SMS core
Postby ericgus » Mon Jun 06, 2016 5:41 pm
vebxenon wrote:Thanks for the audio fixing! :-) About NTSC on SMS, most games were released only at Europe, so PAL 50 HZ is the most common configuration to play SMS games.
Regards,
Salva
There are about 115 games for NTSC .. so about 1/2 that of PAL .. still nothing to sneeze at though but I wouldn't say "most games were PAL" ..
vebxenon
Re: SMS core
Postby vebxenon » Tue Jun 07, 2016 8:27 am
PAL: 300 games
US NTSC: 115 games
JAP: 87 games
67 releases didn't came to Europe (JP, US or BR exclusives). No game since October 1991 (Sonic the Hedgehog, last US Master System Release, only three games were released on US that year) were released on US. On Japan, last game appeared on February 1989, Bomber Raid (The only game released for SMS that year).
Yes, 115 is good number, but, actually, most games appeared on Europe and except some US exclusive games, the most common configuration for playing SMS is PAL 50 Hz
Regards,
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
ericgus
Re: SMS core
Postby ericgus » Tue Jun 07, 2016 3:17 pm
vebxenon wrote:PAL: 300 games
US NTSC: 115 games
JAP: 87 games
Regards,
Ok as I said about 1/2 ... I'd still prefer to stick with NTSC as thats the ones I am most familiar with since it was not possible to play PAL based games here in the USA. Though id be curious to check out some of the PAL/non-US based titles.
Paradroyd
Re: SMS core
Postby Paradroyd » Tue Jun 07, 2016 10:07 pm
Same here. While I'm glad the core is progressing, I'm going to stick with the older version until NTSC is working properly. It's really irrelevant to me how many titles were released in PAL/vs NTSC as I generally don't run it in PAL here.
- Paradroyd
NML32
Re: SMS core
Postby NML32 » Tue Jun 07, 2016 10:13 pm
Same for me as well but I just ordered a monitor that should be able to display both NTSC and PAL. (Hopefully)
ericgus
Re: SMS core
Postby ericgus » Wed Jun 08, 2016 1:21 am
Hopefully they can apply the same magic Sorgelig did to fix the NTSC mode on the c64 core.
vebxenon
Re: SMS core
Postby vebxenon » Wed Jun 08, 2016 10:37 am
I've tested last SMS core with the same games I've used with previous versions. PSG timings seem to be OK, although for example, on Space Harrier, voices sound very accelerated :shrug:
Video aspect ratio I think it must be fixed, but good progress :)
Regards :cheers:
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Re: SMS core
Postby vebxenon » Wed Jun 08, 2016 10:41 am
ericgus wrote:Hopefully they can apply the same magic Sorgelig did to fix the NTSC mode on the c64 core.
Oh, Sorgelig is magic, yes :D
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
seastalker
Re: SMS core
Postby seastalker » Mon Jun 13, 2016 1:38 pm
Hey guys, I've been testing this core too. An added bonus is that it even recognized a small handful of my Game-gear ".gg" files! I also wish to point out that there is a glitch that may make troubleshooting and testing more difficult. I've hit F12 to load up many games (.sms) and it seemed like most did not work. Then I noticed that the core was able to hotswap games better at first startup, but the more I swapped, the more the incompatibility. I then tried repowering the MiST, restarting the SMS core, and games that did not boot or loaded with messed gfx and or sound suddenly worked! ...IF I loaded that game FIRST. Strange glitch, but if your favorite game doesn't seem to work, try that trick!
...Of course, this is a much more time consuming process if you wish to test all games for a compatibility list. :)
Re: SMS core
Postby Sorgelig » Tue Jun 14, 2016 3:44 pm
Just use my latest release of Menu core. It cleans the SDRAM while running.
So, if core has problems caused by non-clean SDRAM, then Menu will help you to solve it.
NML32
Re: SMS core
Postby NML32 » Tue Jun 14, 2016 4:39 pm
@Sorgelig True your menu core works like a champ. It just needs an option for upgrading firmware. I think I read it's an option you're considering. :D
Re: SMS core
Postby Sorgelig » Tue Jun 14, 2016 4:53 pm
NML32 wrote:@Sorgelig True your menu core works like a champ. It just needs an option for upgrading firmware. I think I read it's an option you're considering. :D
It's not in core control. FW limits OSD to only core selection if name of core is "Menu".
Firmware need to be changed to allow other OSD pages.
Actually, it's very minor issue. You always can load any core and update FW.
NML32
Re: SMS core
Postby NML32 » Tue Jun 14, 2016 5:26 pm
True, and that's what I've been doing
seastalker
Re: SMS core
Postby seastalker » Mon Jun 20, 2016 2:28 pm
I'd love to learn how to program code or tweak this one to make improvements like aspect ratio and smoother jumping between games. Anyone have tutorial videos of how to get started in core creation or helping to make one even better?
Re: SMS core
Postby Newsdee » Mon Jun 20, 2016 2:45 pm
seastalker wrote:I'd love to learn how to program code or tweak this one to make improvements like aspect ratio and smoother jumping between games. Anyone have tutorial videos of how to get started in core creation or helping to make one even better?
You can start by installing Quartus II and try to compile a core yourself. After that you can start tinkering :D
seastalker
Re: SMS core
Postby seastalker » Mon Jun 20, 2016 2:57 pm
Checking out some tutorials, thanks!!
vebxenon
Re: SMS core
Postby vebxenon » Tue Feb 28, 2017 11:08 pm
New updates!
https://github.com/mist-devel/mist-bina ... /cores/sms
Now SMS core has 15kHz support and games have now black border, so it's nicer to play. Hope new updates like better VDP, compatibility, better resolution or even FM music will follow.
Thanks to phoboz for this new update! :cheers:
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
leech
Re: SMS core
Postby leech » Sat Mar 04, 2017 11:56 pm
vebxenon wrote:New updates!
Regards,
Salva
I was trying out different cores, and I can't seem to get this one to display on my VGA monitor (I know it does support 15khz, as I've used my ST on it.)
jotego
Re: SMS core
Postby jotego » Sun Mar 05, 2017 11:12 am
I thought it already had it... I will look into it when I'm done with the Megadrive. I'll ask phoboz...
My Patreon page here.
DrChaos
Re: SMS core
Postby DrChaos » Mon Mar 06, 2017 8:27 am
leech wrote:I was trying out different cores, and I can't seem to get this one to display on my VGA monitor (I know it does support 15khz, as I've used my ST on it.)
Sure you used the 15kHz ST core? I haven't used the ST core for a while, but as far as I remember the frequency is set by the STimage? VGA is 31kHz and only few Multisyncs are able to work with 15kHz input...
vebxenon
Re: SMS core
Postby vebxenon » Mon Mar 06, 2017 1:16 pm
I'm using it using VGA :wink: , 31 kHz
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
