Sokoban for GEM
peterlane
Sokoban for GEM
Postby peterlane » Fri May 27, 2016 7:46 pm
With some help from this forum, I've finally finished my GEM version of Sokoban. The screen shot shows the program working under MINT+XaAES on a Firebee, but has also been tested in low and high resolution on an Hatari-emulated ST, and an Hatari-emulated Falcon.
Features:
- Contains the 50 classic levels from Thinking Rabbit
- Additional levels can be loaded from a text file
- Unlimited undo
- Total moves and pushes per level recorded and saved
- Size of display can be adapted
See http://peterlane.info/sokoban.html
- for downloadable files (there is a separate build for the Firebee, and for the ST / 68000), and
- the source code (this program was written on a Firebee using AHCC).
(If you are looking for more levels, http://www.sourcecode.se/sokoban/levels has nearly 40,000 of them!)
Peter Lane
Firebee | STE (4Mb, TOS 2.06)
http://peterlane.info/firebee.html
Re: Sokoban for GEM
Postby Cyprian » Fri May 27, 2016 9:28 pm
great!
Re: Sokoban for GEM
Postby shoggoth » Fri May 27, 2016 11:14 pm
Nice :)
Re: Sokoban for GEM
Postby joska » Sat May 28, 2016 10:13 am
Nice! Just tested it on my STE, it works really well.
I also like the fact that you have developed it *on* an Atari, not just *for* it :)
lotek_style
Mod(ul)erator
Mod(ul)erator
Re: Sokoban for GEM
Postby lotek_style » Sat May 28, 2016 11:50 am
I've put it into my archive: http://demozoo.org/productions/158370/
peterlane
Re: Sokoban for GEM
Postby peterlane » Sat May 28, 2016 1:40 pm
joska wrote:Nice! Just tested it on my STE, it works really well.
Thanks for the feedback. My STE is refusing to work at the moment, so I couldn't try it on the 'real thing'.
And yes, developing *on* an Atari is the enjoyable part!
Peter Lane
peterlane
Re: Sokoban for GEM
Postby peterlane » Sat May 28, 2016 1:41 pm
lotek_style wrote:I've put it into my archive: http://demozoo.org/productions/158370/
Thank you!
Peter Lane
Re: Sokoban for GEM
Postby Cyprian » Sat May 28, 2016 7:46 pm
Would be possible to add "Reset level" option? Now, whenever when I get stuck I have to find the level in the Classic window.
Scale option would work globally. Now every time when I open a new level I have to change it to Large.
And last point, a new window could be fit to the Sokoban level
BTW. under XaAES I see refresh bug in "Classic" window
jfl
Re: Sokoban for GEM
Postby jfl » Sat May 28, 2016 8:31 pm
Cyprian wrote:Would be possible to add "Reset level" option? Now, whenever when I get stuck I have to find the level in the Classic window.
Pressing "R" resets the level. Isn't it what you want?
Jean-François
GEMDict – GEMClip
jfl
Re: Sokoban for GEM
Postby jfl » Sat May 28, 2016 8:34 pm
Your game is working quite well on my FireBee. I did notice though that the windows do not respond to the WM_BOTTOMED message. It's so simple to implement you should think about adding this.
Jean-François
GEMDict – GEMClip
Re: Sokoban for GEM
Postby Cyprian » Sat May 28, 2016 8:51 pm
jfl wrote:Pressing "R" resets the level. Isn't it what you want?
yep, thx!
MM41
Re: Sokoban for GEM
Postby MM41 » Mon May 30, 2016 12:39 pm
Thank you Peterlane :D,
Good GEM game :cheers:.
Could you add the save screen parameter when we exit game?
peterlane
Re: Sokoban for GEM
Postby peterlane » Mon May 30, 2016 1:53 pm
jfl wrote:Your game is working quite well on my FireBee. I did notice though that the windows do not respond to the WM_BOTTOMED message. It's so simple to implement you should think about adding this.
OK, thanks for the suggestion. It does look easy to add.
Peter Lane
peterlane
Re: Sokoban for GEM
Postby peterlane » Mon May 30, 2016 1:58 pm
Cyprian wrote:Scale option would work globally. Now every time when I open a new level I have to change it to Large.
Thanks, I'll think about those.
MM41 wrote:Could you add the save screen parameter when we exit game?
Do you mean a kind of 'save current position' to return to later, option? I can see that would be useful. I'll also put it on the list to think about.
Peter Lane
Re: Sokoban for GEM
Postby Anima » Mon May 30, 2016 3:26 pm
Thanks for the game. That's truly a great classic.
I'll give it a try soon on my STE (which is back in business again after a long hibernation). :cheers:
Re: Sokoban for GEM
Postby Eero Tamminen » Mon May 30, 2016 7:11 pm
Thanks, looks nice!
I noticed one bug. Quitting the game works fine under EmuTOS, TOS v2.x and TOS v1.62, but it crashes TOS v1.04.
Might happen if you e.g. do some AES/VDI operation(s) after closing AES/VDI.
jfl
Re: Sokoban for GEM
Postby jfl » Mon May 30, 2016 7:20 pm
Eero Tamminen wrote:I noticed one bug. Quitting the game works fine under EmuTOS, TOS v2.x and TOS v1.62, but it crashes TOS v1.04.
It does happen to me too under XaAES with an illegal instruction.
Jean-François
GEMDict – GEMClip
peterlane
Re: Sokoban for GEM
Postby peterlane » Tue May 31, 2016 7:54 am
Eero Tamminen wrote:Thanks, looks nice!
Thanks for the report, and the extensive testing. It may be an uninitialised pointer being freed - I just found one, thanks to your prompt.
Peter Lane
Re: Sokoban for GEM
Postby joska » Tue May 31, 2016 8:08 am
peterlane wrote:Do you mean a kind of 'save current position' to return to later, option? I can see that would be useful. I'll also put it on the list to think about.
I'd like to see that too. Window size/position and graphics scale saved together with the scores.
I haven't played Sokoban since the 90's, spent many hours with the Syntax Terror version. And now I've spent/wasted hours on this one, trying to solve the levels again :)
peterlane
Re: Sokoban for GEM
Postby peterlane » Wed Jun 01, 2016 10:36 am
I have created a new version of Sokoban, version 1.1.0. The changes include:
. Respond to WM_TERM message
. Respond to WM_BOTTOMED message
. Scale for position is set to last value used (so you don't have to keep changing the scale)
. Window size will fit level, if there's room on screen
. Warning if you exceed number of open windows
. Help screen to show keys
. Fixed pointer error when exiting with statistics screen open
In addition to the Firebee and ST versions, there is also a build aimed at the Falcon, responding to TOS 4.0 messages.
Available from: http://peterlane.info/sokoban.html
Thanks to everyone who tried the program, reported problems and made suggestions for improvements.
Peter Lane
BlankVector
Re: Sokoban for GEM
Postby BlankVector » Wed Jun 01, 2016 8:02 pm
Very nice game.
It works perfectly on EmuTOS for Amiga :mrgreen:
Re: Sokoban for GEM
Postby Eero Tamminen » Sun Jun 05, 2016 3:57 pm
Tested the updated version. Quitting works now fine with TOS v1.04, when program is started from GEM desktop.
When starting program at TOS boot using DESKTOP.INF file (= what Hatari autostart does), it still crashes TOS v1.04. Other GEM programs seem to cause this too, so I think it's a TOS v1.04 bug, not Sokoban one, and can be ignored.
AtariCrypt
Re: Sokoban for GEM
Postby AtariCrypt » Sat Jul 16, 2016 11:03 am
How did I miss this little belter? Now I know what I'm doing today!! :D
Thank you!
Return to “Games”
