BeeKey Atari on a key and now BeePi
matt
Re: BeeKey Atari on a key and now BeePi
Postby matt » Fri Dec 13, 2019 6:09 pm
ThorstenOtto wrote:
matt wrote:Is there an alternate way to get to Aranym Setup? Alt+F12 is not working for me. Will keep trying.
You can run aranym with the -G option, that should open the setup before booting the ROM. And since a commit done Jun 26, you can also use the middle mouse button to enter setup.
Where do I specify the -G using BeeKey?
I'll find a mouse with a 3rd button!
ThorstenOtto
Postby ThorstenOtto » Fri Dec 13, 2019 6:16 pm
In the command that invokes aranym. Don't ask me where that is specified in BeePi ;)
Note that for the middle mouse button to invoke setup, you have to use the above method, and change the setting in "Keyboard + Mouse", or edit the default config file first, and set
[IKBD]
MiddleButton = 2
Otherwise the default action for middle button is to release the mouse grab.
matt
Postby matt » Sat Dec 14, 2019 6:05 pm
So I gave up going down the USB/Pi route.
I found MacAranym, and then unsquashed the filesystem from BeeKey and combined the two.
Now I have MacAranym running Philippe's setup in a window. Perfect for my needs!
Thanks all.
Onwards!
Faucon2001
Postby Faucon2001 » Tue Dec 17, 2019 1:02 pm
I am happy that you found a solution to use it.
I have originally tested Beekey on a Macbook with OSX 10.6.8 and 10.11 and it was working flawlessly.
Now with a more recent version of OSX, I don’t know.
USB booting on Mac is not an easy topic.
Philippe
matt
Postby matt » Thu Dec 19, 2019 12:52 am
I ended up using files from your EasyAraMiNT beta2 rather than BeeKey. I prefer the simpler setup and vibe.
Anyway, I'm happy! Merci mec
christos
Postby christos » Thu Jan 02, 2020 11:39 am
Any chance we can get the beekey hard disk image as a separate download for local aranym installs?
b9 is very nicely done, though i do get an error with netsurf complaining it's running out of memory
vido
Postby vido » Thu Jan 02, 2020 5:57 pm
christos wrote:b9 is very nicely done, though i do get an error with netsurf complaining it's running out of memory
Netsurf complain sometimes its running out of memory if you type URL without "http://" or "https://". Maybe that solves your problem wint Netsurf?
Faucon2001
Postby Faucon2001 » Fri Jan 03, 2020 11:05 am
Sorry guys but I don’t have time to continue BeeKey and BeePi development now.
I don’t give up, but for the next 2 years I won’t have the necessary time to do it.
All the system files are stored in the directory /H/.system if you want to modify it. BeePi is the most up to date install.
Philippe
Playmobil
Postby Playmobil » Fri Jan 03, 2020 11:10 am
christos wrote:Any chance we can get the beekey hard disk image as a separate download for local aranym installs?
Take a look here : viewtopic.php?f=8&t=34013&p=350068#p350068
Inside my archive, you'll find all the necessary... :wink:
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Jan 03, 2020 6:19 pm
Faucon2001 wrote:Sorry guys but I don’t have time to continue BeeKey and BeePi development now.
Ah, that is bad news - was really looking forward to seeing how the Raspberry Pi 4 worked. But understandable as real work has to come first. Thanks for everything you have done for BeePi.
ragnar76
Postby ragnar76 » Sat Jan 04, 2020 12:03 am
Playmobil wrote:Inside my archive, you'll find all the necessary... :wink:
is there any other download? mega.nz is really slow :(
