CosmosEX v2 SCSI MegaSTE HELP!
Estrayk
Postby Estrayk » Fri Apr 01, 2016 12:30 am
Hello all.
I´ve an Atari MegaSTE 4Mb. TOS 2.06 working with an old SCSI IBM HD 1Gb.
I want to change my old internal IBM HD for the CE and use a SD card as HD.
I´ve follow the tutorial from: http://joo.kie.sk/?page_id=704 and seems all works fine until:
When booted, your Atari should show you a desktop with the drives A,B and O. Open the drive O.
I can see drivers A and B but not O. :shrug:
Hmm.. I checked all pass again and seems all the connection between raspberry and cosmos runs because I can upload a floppy from my browser to ATARI and I can see the config from the browser and change the parameters.
Also, I´ve read 1000 times: http://info-coach.fr/atari/documents/_m ... _Guide.pdf without results.
I change the CE to ACSI mode flashing it with the same results. (I try this, becasuse I read time ago that CE uses SCSI ID:0 and can make a weird conflict with my old SCSI configuration) but the same result. No O: device in desktop.
I re-flash again to SCSI and try to change all options in ID config page: no results.
I dont know what I can do more. I´m sad.
Please help. :cry:
I´ve made a video showing the problem:
https://youtu.be/61wes_1H2OQ
Thank you. :cheers:
dblanch369
Re: CosmosEX v2 SCSI MegaSTE HELP!
Postby dblanch369 » Fri Apr 01, 2016 2:50 am
Perhaps it isn't setting desktop.inf properly? Try selecting "Install Devices" from the drop-down menu. I think on TOS 2.06 that's all you have to do, on TOS 1.62 I have to manually enter the drive letter, then name the drive "Config". I only had that happen once, however, not every time like you are seeing. Then if it works, select the drop-down for "Save Desktop"
David
Jookie
Postby Jookie » Fri Apr 01, 2016 1:54 pm
it sounds similar to the other topic related on more devices on the SCSI / ACSI bus:
http://www.atari-forum.com/viewtopic.php?f=103&t=29642
What ACSI-to-SCSI host adapter you have in your Mega STE? As mentioned in the other thread, it will probably have some issues when sharing ACSI bus with the other device, it could possibly work on SCSI bus, but that might have some other issues.
I need to do some tests here during the weekend. I don't have much SCSI adapters in my STs, so there wasn't much testing related to usage of multiple devices on the same bus.
One thing which you could try is to disable / remove that ACSI-to-SCSI host adapter from your STE and try if the CE device works fine with your STE then.
Jookie
Estrayk
Postby Estrayk » Fri Apr 01, 2016 2:28 pm
Hello Jookie, I´ve this one:
Well, I think that I cant remove the Hard Disk Controller because in MegaSTE you cant remove it. (If I do that, I will lost the the external ACSI device).
See this:
http://atari.8bitchip.info/MegaSTEACSI.html
Anyway, I remove it and the Atari dont boot. Just four bombs in check memory page!
I´ll buy "jumpers" (I need a lot) and I´ll test tonight , putting in the J402 connector. But I see in http://www.lotharek.pl/product.php?pid=92 that this will not enough. Maybe I´ll need buy this Ultrasatan ATARI MEGA STE Adapter from lotharek?
Estrayk
Postby Estrayk » Fri Apr 01, 2016 11:28 pm
Well, I think that the main problem is that SCSI controller from MEGA STE is pure crap. Reading the limitations I can check that:
ACSI Hints for Mega STE and Stacy
You should keep these rules in mind for the ACSI/DMA bus of the Mega STE:
The drive must not require initiator identification. Some drives require the computer to have a SCSI ID of its own, but the Mega STE has no full-featured SCSI bus (only ACSI/DMA) and does not provide this feature.
You can only use 1 GByte of the drive's capacity, even if the drive has a higher capacity.
Parity should be switched off, the Mega STE does not support parity.
The drive at the end of the SCSI chain must not be terminated. Terminating the SCSI device can damage the SCSI adapter.
The cable to the drive should be short.
The SCSI device must be set to SCSI ID 0.
ACSI ID is set by DIP switches on the host adapter.
so, I decided use cosmos via external ACSI. but... there´re a problem with it.
MegaSTE needs the SCSI controller plug-in for that ACSI works. Well, no problem I can keep the SCSI hard disk controller and connect the cosmos via ACSI external. Uhmmm.. Doesnt work.! why? Coz the SCSI use IDE:0 and the CE too !!! so , make it a weird conflict.
So, I changed the DIP-switch in the SCSI controller like this picture:
I hope this help to anyone with MegaSTE.
Jookie
Postby Jookie » Sun Apr 03, 2016 1:41 am
Estrayk wrote:Well, I think that I cant remove the Hard Disk Controller because in MegaSTE you cant remove it.
Did you test this one? I wonder if it helped.
Estrayk wrote:The SCSI device must be set to SCSI ID 0.
This bullet about the SCSI configuration on that adapters seems that it can operate only one SCSI device there (with ID 0), so you probably can't connect CosmosEx there, as it would need another ID on the bus.
Estrayk wrote:Uhmmm.. Doesnt work.! why? Coz the SCSI use IDE:0 and the CE too !!! so , make it a weird conflict.
Good one :) The other option would be to change IDs in CosmosEx, which is done purely in software, e.g. through web interface (if you can't connect through ACSI / SCSI at that time).
Thank you for this info, it really might help someone else when configuring it with Mega STE.
Postby joska » Mon Apr 04, 2016 7:31 am
Estrayk wrote:Anyway, I remove it and the Atari dont boot. Just four bombs in check memory page!
Sounds like you disconnected the floppydrive as well. TOS 2 will crash with four bombs after the memory test is no floppy is connected.
There is no reason why a MSTE should bomb when the SCSI-interface is not present.
Postby DarkLord » Mon Apr 04, 2016 2:20 pm
I would think you're right. My STacy doesn't crash with that controller removed and its basically the same board, IIRC.
frank.lukas
Postby frank.lukas » Mon Apr 04, 2016 2:44 pm
My Atari Mega ST and TOS 2.06 crash with four Bombs when no Harddisk is connected. The only Way is press the Alternate Key at Boottime.
Postby joska » Mon Apr 04, 2016 4:34 pm
Pressing Alternate during booting forces TOS to not load a harddisk-driver and skip all accs/autofolder-programs on your bootdrive. So I suspect the cause for these crashes is some acc/autofolder/harddisk-driver on your boot device. If not, you have a faulty ROM or some hardware-issue.
Estrayk
Postby Estrayk » Tue Apr 05, 2016 9:12 pm
All works fine now! I´m very happy. Anyway... I´ve found a weird problem with ppdriver.
If I use ICDriver, all works fine. But If I use PPDriver, sometimes TOS show me a error like this:
when I try to copy files from a partition to another.
Anyone have the same issues with PPdriver? (I use original PPdriver from Petari 1.01hs)
thx
Postby joska » Wed Apr 06, 2016 9:05 am
Estrayk wrote:But If I use PPDriver, sometimes TOS show me a error like this:
I think ppera likes to write heavily optimized software, as his driver is both small in size and very fast. Maybe his driver is too optimized for CosmosEx' SCSI implementation?
Estrayk
Postby Estrayk » Fri Apr 08, 2016 12:12 am
I use CE in ACSI mode.
Postby joska » Fri Apr 08, 2016 6:04 am
Or ACSI, for that matter :) The point is that the ACSI/SCSI implementation in CosmosEx might have some timing issues with a highly optimized driver like ppera's.
tin
Postby tin » Fri Apr 08, 2016 6:17 am
Estrayk wrote:All works fine now! I´m very happy. Anyway... I´ve found a weird problem with ppdriver.
Just for completeness: does the hd test you'll find on the config drive show any hickups?
And some questions out of curiosity:
Can you reproduce this with the same fileset reliably? Does it by chance happen at the same file? Big or small files? Does it happen in 8MHz mode also?
tin
Postby tin » Fri Apr 08, 2016 7:47 am
Forgot one essential question, ppera just reminded me:
I simply assumed you meant from SD card (raw) partition to SD card (raw) partition, which might be a false assumption.
Did you copy by any chance from/to a translated drive (e.g. network or USB stick)? If yes, what kind of operation exactly?
Estrayk
Postby Estrayk » Fri Apr 08, 2016 1:56 pm
tin wrote:Forgot one essential question, ppera just reminded me:
Yes! the same! from Shared folder to RAW SD and from USB (FAT32) to RAW SD, and from RAW SD to RAW SD.
When I copy from RAW SD to SHARE (For example) all works fine. so, seems the problem is saving data in RAW SD.
tin wrote:Just for completeness: does the hd test you'll find on the config drive show any hickups?
Seems everything is all right, look:
tin wrote:And some questions out of curiosity:
Let me check that... (EDIT FOR THE REPLY)
Hey tin! you´re right! The problem is just with big files, (more of 500k)
check this out:
The BLACK FILES (at the left) are the files that can't be copied well and all have more of 500k. (but wait! not ever! sometimes can be copied! and If i retry several times... can be copied)
BTW, the problem persists in 8Mhz - 16Mhz - 16Mhz+cache.
joska wrote:Is that the ACSI/SCSI implementation in CosmosEx might have some timing issues with a highly optimized driver like ppera's.
I´ll ask Petari about this issue. Maybe he knows whats the problem.
Estrayk
Postby Estrayk » Wed Apr 13, 2016 9:04 pm
Petari told me that I test it with another SD. Seems Kingston suxx. All works perfeclty with Sandisk.
thx to all.
Marakatti
Postby Marakatti » Sun Nov 19, 2017 12:46 pm
Huge thanks, finally got my Mega STe to talk with Cosmosex :)
Bikerbob
Postby Bikerbob » Thu Dec 21, 2017 4:26 pm
So Marakatti are you running it with an internal Asci drive? or you just wanted to set the jumpers so as not to conflict with your Cosmos?
I have mega STEs and I leave the controller in, but I have no HDD on it. all three of my switches are in the ON position, and working fine.
James
Marakatti
Postby Marakatti » Thu Feb 01, 2018 5:48 pm
Bikerbob wrote:So Marakatti are you running it with an internal Asci drive? or you just wanted to set the jumpers so as not to conflict with your Cosmos?
James
Sorry for a slow reply... I've removed the internal drive, and yes just to avoid conflict with CE. But sadly i've started having problems with CE. Usually if i write a hard disk image on the SD card and boot with it, every time CE writes something to the SD card, like even saving a NEWDESK.INF, it becomes corrupted. 0 Partitions after boot. Never experienced data corruption with my internal hard disk which has been in use since 1997. It makes no difference if i use ICD, HD Driver or Peter's drivers. They work for one boot and then the data is gone once something is written on the SD card :(
So i can only play Peter's hard disk adaptions but can't use it as a workhorse anymore... USB drive works great but i haven't found a way to to use it as a boot drive.
If i remove the internal controller, my MSTE can't see nothing on external ACSI bus either.
And yes PSU caps are replaced and CE has the latest updates i think ;)
frank.lukas
Postby frank.lukas » Thu Feb 01, 2018 6:05 pm
Marakatti wrote:If i remove the internal controller, my MSTE can't see nothing on external ACSI bus either.
When you remove the ACSI/SCSI Hostadapter you must set 8 Jumper on the MSTE Board for D0 to D7 ...
Bikerbob
Postby Bikerbob » Sun Feb 04, 2018 3:18 am
I assume you are using Sandisk and not some generic card?? Sandisk works for SURE! I have gotten other stuff to work, but it is slower. before you give up on the CE.. check that. Use a card everyone knows works.. aka Sandisk.
James
Marakatti
Postby Marakatti » Sun Feb 04, 2018 9:12 am
Thanks :) Will check this later today. Is there a guide to rest of the jumpers. Is it possible for example to force MSTe to boot 16Mhz instead of 8?
Bikerbob wrote:I assume you are using Sandisk and not some generic card?? Sandisk works for SURE! I have gotten other stuff to work, but it is slower. before you give up on the CE.. check that. Use a card everyone knows works.. aka Sandisk.
James
Local markets don't sell SanDisk SD cards here. Only Kingston, Transcend and Integral. I loaned Lotharek's ICD prepared SanDisk card from a friend and it indeed was more reliable. Need to order one for myself.
Transcend card was corrupted all the time after writing an image with PC.
Integral is working ok too, i just can't install Peter Putnik's driver to it. It always tells me there's not enough space on the bootblock. But i can use it to play his adaptions with a driver launched from GEM.
Not giving up with CE, it's a brilliant piece of hardware and used it for years. I just wish i could autoboot from the USB stick to make my Atari-life easier ;)
Bikerbob
Postby Bikerbob » Tue Feb 13, 2018 1:33 pm
I hope there are some coding users who want to improve the drivers. That is really what is needed now. Getting translated disks (USB) to work in a multi tasking enviorment is key. As you say, having it boot.
There is a function that if you had an .img on one of the usb - you are supposed to be able to set that up to boot from it, but I have yet to make that work myself.
James
Return to “CosmosEx”
