SV FW rev 9
instream
SV FW rev 9
Postby instream » Mon Mar 07, 2016 7:37 am
Hi!
Yesterday we added a new firmware, rev 9, to nature.atari.org. You need a JTAG cable to upgrade. The new FW contains a FIFO port register for queuing up to 56 blitter operations. The memory map has also been updated to reflect this.
patjomki
Re: SV FW rev 9
Postby patjomki » Thu Mar 10, 2016 6:10 pm
instream wrote:Hi!
That's great news. Can you explain what the advantage of this FIFO port register is?
And do you plan to provide an ATARI installation program for this firmware?
deeez
Re: SV FW rev 9
Postby deeez » Fri Mar 11, 2016 12:28 pm
I assume its to improve the speed at which blits are processed.
The way it was done before was to either poll the blitter to see if it was finished or to respond to an interrupt triggered when the blitter is finished.
Both ways introduce latency/overhead. The interrupt way I guess is the preferred way but it involves responding to the interrupt so if you have many blits a lot of time would be spent in the interrupt code just dealing with the interrupt itself, not only writing new blitter commands. This cost can now (if I understand this correctly) be spread across multiple (up to 9) blitter operations instead of being a cost per single blitter operation.
instream
Re: SV FW rev 9
Postby instream » Sat Mar 12, 2016 11:42 am
The amount of blitter operations that can be queued is 56 (and 9 registers for each operation is written). The FIFO helps us get away from using interupts, because they were freezing the machine too often, and we couldn't find the problem despite extensive searching using oscilloscope etc. And as deez points out, the FIFO solution also is a slightly faster way to handle things, because the CPU isn't interrupted all the time.
deeez
Re: SV FW rev 9
Postby deeez » Sat Mar 12, 2016 7:17 pm
Whats stopping you from increasing this to maybe 1000? It already mimics command buffers used by gpus but 56 sounds a bit low :)
instream
Re: SV FW rev 9
Postby instream » Sat Mar 12, 2016 7:39 pm
There is a very limited amount of block RAMs in the FPGA, which are used for this FIFO. Each BRAM is 2KB in size. With a 32bit data bus that gives us 512 longwords per BRAM. We would like to save the remaining BRAMs for other stuff. :)
instream
Re: SV FW rev 9
Postby instream » Sat Mar 12, 2016 7:43 pm
We will create a FW updater program for this version soonish.
AdamK
Re: SV FW rev 9
Postby AdamK » Sat Mar 12, 2016 8:06 pm
instream wrote:There is a very limited amount of block RAMs in the FPGA, which are used for this FIFO. Each BRAM is 2KB in size. With a 32bit data bus that gives us 512 longwords per BRAM. We would like to save the remaining BRAMs for other stuff. :)
Why not use SV Ram for that?
patjomki
Re: SV FW rev 9
Postby patjomki » Sat Mar 12, 2016 9:16 pm
instream wrote:We will create a FW updater program for this version soonish.
Cool. 8)
instream
Re: SV FW rev 9
Postby instream » Wed Mar 16, 2016 5:34 pm
Well, that is of course possible, but then we would need to redesign the blitter much more.
patjomki
Re: SV FW rev 9
Postby patjomki » Tue Mar 22, 2016 6:15 pm
instream wrote:Well, that is of course possible, but then we would need to redesign the blitter much more.
I just saw that you already put the atari updater program onto your website. Thank you. Downloaded, programmed, rebooted, everything's fine. 8)
BTW, programming the new firmware took 1 minute 39 seconds.
TheNameOfTheGame
Re: SV FW rev 9
Postby TheNameOfTheGame » Tue Mar 22, 2016 7:05 pm
Thanks for the head's up. Was waiting for the tool. :cheers:
Return to “SuperVidel”
