Is my SCP faulty?
Is my SCP faulty?
Postby Dal » Fri Feb 05, 2016 8:58 pm
Finally got around to cracking open my SCP as I had some disks to image. Installed the sw and drivers, hooked it all up and attempted to copy from the drive to a disk image. I always end up with a 42Kb SCP file regardless of what disk I use.
What's up with it?
JimDrew
Re: Is my SCP faulty?
Postby JimDrew » Sat Feb 06, 2016 5:20 pm
Sounds like the disk drive might have a problem. What type of drive?
I am the flux ninja
Postby Dal » Sat Feb 06, 2016 5:44 pm
Thanks for the response, Jim. It's a brand new drive supplied with my Kryoflux.
Model is Sony MFP920
JimDrew
Postby JimDrew » Sat Feb 06, 2016 7:39 pm
Send me the .scp file (data at cbmstuff.com) and I can look at it, but it sounds like the drive is not sending any data. It could be due to bad power. How are you powering the drive? Do you know if the cable and drive works with your Kryoflux?
I am the flux ninja
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Sep 27, 2016 2:55 am
Dal did you get this working?
Postby Dal » Tue Sep 27, 2016 2:38 pm
Yes - it was the drive in the end.
