Write MSA image with kyoflux
Gunstick
Postby Gunstick » Mon Jan 04, 2016 12:48 am
so I download a demo from pouet, and having no floppy in my laptop, I need to get it to the ST.
I can put it first into HXC and then write a floppy with the STE which I then insert into the ST... but that's quite cumbersome.
I don't want to buy a second HXC or reconnect the HXC between 2 computers. So the idea came to directly write the download to the floppy connected to my kryoflux.
Well... how would one do that? I think this is just a problem to convert .MSA -> .ST -> STREAM file?
To make things interesting, I'm running this on linux. So would need sourcodes instead of fancy windows EXEs.
Thanks for any help,
Georges
dlfrsilver
Re: Write MSA image with kyoflux
Postby dlfrsilver » Mon Jan 04, 2016 9:42 pm
HxC allows for conversion, from *.ST format to *.raw (KF stream file).
the sources are here :
http://sourceforge.net/projects/hxcfloppyemu/
Gunstick
Postby Gunstick » Mon Jan 04, 2016 9:49 pm
Oh thanks, I searched in KF sources and the solution was in another castle :-)
Georges
Gunstick
Postby Gunstick » Tue Jan 05, 2016 12:40 am
I wrote a little linux script. input ST output a floppy. And it works! Cannot publish the script as it contains my directory structure. Both hxc and kf are not really playing nice when not in the install folder.
dlfrsilver
Postby dlfrsilver » Wed Jan 20, 2016 3:02 pm
shame, would have been great, as well as a solution to write back easily the union demo on a fresh disk :)
Postby DrCoolZic » Thu Jan 21, 2016 4:41 pm
dlfrsilver
Postby dlfrsilver » Fri Jan 22, 2016 10:39 am
How ? Aufit doesn't read MSA, and can't convert the format to KF raw for writing.......
Postby DrCoolZic » Fri Jan 22, 2016 7:50 pm
Yes you are right I read things to quickly :(
Jeff_HxC2001
Postby Jeff_HxC2001 » Sat Feb 06, 2016 1:55 pm
dlfrsilver wrote:shame, would have been great, as well as a solution to write back easily the union demo on a fresh disk :)
The HxC software allows this without problem. Just open and export the msa file to the wanted stream file format (*.raw or scp).
Return to “Kryoflux”
