Time Slices / STNICCC 2015
All about ST/STE demos
Dbug
Postby Dbug » Sun Dec 27, 2015 8:38 am
(I already posted that on the DHS BBS but I realized there was probably way more persons active here)
as you probably already know I released a monochrom demo in the Commodore 128 times revisited at the STNICCC 2015 party last week.
This demo is kind of experimental (as far as I know, not many people played with the STe registers in monochrom mode), and as a result the timings are a bit wonky and were tested only on four different machines.
If any of you happens to have a STe (or Mega STe) and a SM124 screen (or a Mono to VGA cable), could you try the demo on your machine and check that the second part is working ok? If it is not, then please try to press/release the left or right arrow keys to see if you can get it to work (probably no more than 4 key presses in any direction) and report the results so we can get some kind of reference values for any future attempt :)
You can find the demo on pouet: http://www.pouet.net/prod.php?which=66703
How the demo is supposed to look (filmed on my own machine): https://www.youtube.com/watch?v=RlpP7JV ... nrzt3iqm04
How the demo unfortunately looked like at the party: https://youtu.be/MhMQVn5K8lE?t=448
Thanks again :)
Re: Time Slices / STNICCC 2015
Postby Cyprian » Sun Dec 27, 2015 11:39 am
looks fine on my SM124.
I'll post a video a bit later.
---EDIT---
https://www.youtube.com/watch?v=hBIfstdP7h4
Dbug
Postby Dbug » Mon Dec 28, 2015 9:32 am
Thanks for the test. Was that on a STe or MegaSTe ?
Postby Cyprian » Mon Dec 28, 2015 2:46 pm
1040 STe,
my MSTE shows me 4 bombs
Dbug
Postby Dbug » Mon Dec 28, 2015 5:42 pm
Whaou, that's strange, I did most of the dev on my own mega ste.
Can you describe the configuration you used (memory, tos version, from floppy/hdd/ultra satan, if you have a vme card or some fancy cards, ...)
Does my previous demo (Save the Earth) ran on this machine?
Postby Cyprian » Mon Dec 28, 2015 10:31 pm
actually MSTE throws bombs during booting process not during your demo :)
Postby Cyprian » Tue Dec 29, 2015 11:05 am
Finally my Mega comes back to life.
Unfortunately there are some glitches in your demo: https://www.youtube.com/watch?v=Nfmm99_sQjA
In additional to STNICCC issue on my SM124 is also visible electron beam issue under the scroll on the left border.
alexh
Postby alexh » Tue Dec 29, 2015 12:22 pm
Are you running your MegaSTe at 8MHz?
calimero
Postby calimero » Tue Dec 29, 2015 12:28 pm
Very cool demo! I really love recent SM124 mono demoes! :)
Postby Cyprian » Tue Dec 29, 2015 12:54 pm
alexh wrote:Are you running your MegaSTe at 8MHz?
It was clean boot, no AUTO folder, no Harddisk.
If I remember correctly Mega STe boots in 8MHz no cache mode
---EDIT---
My little program set MSTE to mode 8MHz no cache
; $FF8E21|byte |Mega STe Cache/Processor Control           BIT 15-1 0|R/W (MSTe)
;        |     |Cache enable lines (set all to 1 to enable) -----'  ||
;        |     |CPU Speed (0 - 8mhz, 1 - 16mhz) --------------------'|
   move.b   #$0,$FFFF8E21.w
and the demo shows is the same issue.
Dbug
Postby Dbug » Tue Dec 29, 2015 2:28 pm
I force the machine to be at 8mhz without cache on startup (and restore the original value on exit), so that's not the problem.
Have you tried using the left and right arrows to see if you could fix the problem?
Basically what I'm looking for is a set of values I can use to setup the timings on the start of the machine, so knowing if this megaste requires one or two key presses to the left or the right to get it perfect, would be invaluable :)
Thanks for the tests, and videos are cool :)
Postby Cyprian » Tue Dec 29, 2015 2:52 pm
one right arrow key press fix that problem
you are welcome
Postby Steven Seagal » Tue Dec 29, 2015 6:31 pm
Future version of Steem will support this demo.
I was looking for programs using HSCROLL in high res.
wietze
Postby wietze » Wed Dec 30, 2015 12:54 am
Cyprian wrote:one right arrow key press fix that problem
you are welcome
Same for my ste.
Dbug
Postby Dbug » Fri Jan 01, 2016 10:04 am
Steven Seagal wrote:Future version of Steem will support this demo.
What would be nice is if you could also emulate somewhat the screen persistence of the SM124, like perhaps adding some blending of the previous frame on the next frame.
On the SM124, flickering between two pictures with alternated black and white pixels gives a pretty comfortable to watch grey, but on a standard PC monitor it's like a recipe for epilepsy :)
In case that may help, the source code is here: http://miniserve.defence-force.org/svn/public/atari/demos/defenceforce/TimeSlices/
npomarede
Postby npomarede » Sun Jan 03, 2016 7:15 pm
Hello
looking at the demo on the video you made, as well as looking at it under Hatari, the 1st text scroller looks interlaced / hardly readable to me.
Even on your video, I can read the 3 other scrolltexts, but this one looks blurry.
Is that because you used some double buffer on this scroll to get a kind of grey by alternating on each VBL ?
Nicolas
Dbug
Postby Dbug » Tue Jan 05, 2016 2:42 pm
On the SM124 it's totally readable despite the speed because the scrolling is smooth as butter, with the mono to vga adapter it's already barely readable, and on the capture it's pointless :)
I'm not alternating anything on the scrollers, it's just that different frequencies or encoding made it hard to read: It's hard to make a video capture of something that displays at 71.2hz when it's finally compressed into a movie that is then rendered on a 50hz or 60hz screen.
Return to “Demos - General”
