ATARI TT030 cubase problem
Atarieterno
Re: ATARI TT030 cubase problem
Postby Atarieterno » Sat Mar 10, 2018 12:40 am
Does anyone have any theory of what can change in the graphical section of Cubase v3 regarding Cubase Score?
Both programs are compatible for ST, TT and Falcon.
P.S. Please try to read this message before some begin to fill in threads without any logic, just to push this question to the last page.
Foxie
Postby Foxie » Mon Mar 19, 2018 12:31 pm
While I don't yet own a graphics card, I have found one odd thing about Cubase and graphics. If you install NVDI, inserting notes behaves differently. Without NVDI, you click and hold to "stretch" the note to the desired length. With NVDI, it just inserts at the shortest length. It's such a strange behaviour. It tells me there's something very weird about how Cubase handles graphics.
Atarieterno
Postby Atarieterno » Mon Mar 19, 2018 12:41 pm
I have tested with NVDI and without NVDI, but in both forms Cubase V3.02 works perfectly and Cubase Score 2.0r7 freezes. The internal graphic section of Cubase has obviously changed with the latest version published by Steinberg: Cubase Score 2.0r7.
Atarieterno
Postby Atarieterno » Sun May 20, 2018 12:07 pm
Cubase Audio CBX is also not compatible with "Imagine - ET4000" VME graphics card, the program starts and freezes when loading DEF.ARR or DEF.ALL.
In TT resolution modes (without VME card) it works correctly.
Any ideas? Does someone have an ET4000 driver that they are using with Cubase Score or Cubase Audio CBX?
charles
Postby charles » Sun May 20, 2018 1:06 pm
are u using it in medium resolution with your graphics card>
The radioactive half-life : )
stormy
Postby stormy » Sun May 20, 2018 1:17 pm
I heard that cubase audio falcon will run on a TT just without the audio part. Since CAF is designed for higher res colour displays maybe this would work on more et4000 etc TT configurations. Just an idea.
charles
Postby charles » Sun May 20, 2018 1:23 pm
I checked my manual for him ,
it says medium resolution in color mode...
I only have mono stock monitors 124/125
Atarieterno
Postby Atarieterno » Sun May 20, 2018 1:37 pm
Thanks for answering, guys.
In TT medium resolution (color) there is no problem, the fault is in higher resolutions (for example 1024x768x2, 60Hz). It's kind of weird because Cubase MIDI v3.02 works perfectly, but Cubase MIDI v3.10 freezes just like Cubase Score and Cubase Audio CBX. Even the old Cubase MIDI 2.01 works correctly at high resolutions.
edingacic
Postby edingacic » Sat Jun 02, 2018 1:23 am
@piotrk - did you fix the issue with black screen after few minutes. Can you record a video of it and show me the scrolling speed in the arrangement window. I can send you some midi files if you need. I wold like to find out if the card is speeding the interface scrolling at all.
As for NVIDI I have never had issue with Cubase Score 2.0r8 but I think I am now running 4.x something version because I heard its better for Cubase.
Atarieterno
Postby Atarieterno » Sat Jun 02, 2018 8:19 pm
edingacic wrote:As for NVIDI I have never had issue with Cubase Score 2.0r8 but I think I am now running 4.x something version because I heard its better for Cubase.
Cubase Score v2.0r8?
I have v2.0r7 and I thought it was the last one; Where can I download the original update?
edingacic
Postby edingacic » Sat Jun 02, 2018 11:11 pm
Sorry you are right its r7 my mistake
roginator
Postby roginator » Fri Oct 26, 2018 12:59 pm
Im back to atari after some time .. still havin headache...
when i moved out crazy dots card ... cubase works on ST resolutions .. also i tried TENOX i have .. no luck .. I have quadraple picture and its hard to see a damn thing.. cant enter TT high mode.. dunno why
I would like to try other drivers on crazy dots .. but links you guys gave me many months ago, dont work..
im hanging, this is last chance i will give my TT 030 to run cubase!
Help
Atarieterno
Postby Atarieterno » Fri Nov 01, 2019 12:52 am
roginator wrote:Im back to atari after some time .. still havin headache...
Help
Have you solved the problem?
Have you tried the original version Cubase 3.02 ?, If you do not have it I will send it to you, with that version the VME graphics card and the Máté adapter work perfectly for me.
