ATARI TT030 cubase problem
roginator
Postby roginator » Wed Oct 28, 2015 4:58 pm
Hi Guys .. my first post here ...
I was long time user of atari ... till 2002 then switched to mac...
I decided few months ago that i want to put atari back into studio. so i got myself TT 030 .. TOS 3.06 .. 4mb ram ST , 4 mb ram TT ... and running crazy dots VGA card.
I have original cubase v3, SMP II, MIDEX and export
also I have USB mode adapter and that all works perfect ..
BUT .. I have next problem ... cubase original or cracked freeze when cubase load into main screen .. no ARR loaded ..mouse pincher gone and i have to reboot it ..
any idea ?
D
roginator
Re: ATARI TT030 cubase problem
Postby roginator » Tue Nov 03, 2015 11:17 am
looks like my Crazy dots card don't support cubase .. is that normal .. anybody here run Cubase 3.01 or 3.1 on Nova drivers with crazy dots or ???
frank.lukas
Postby frank.lukas » Tue Nov 03, 2015 1:02 pm
You can try the original TKR Drivers for the Card or NVDI 5 or the Nova Driver for the CrazyDots Card -> http://silicon-heaven.com/atari/nova/TT/
Or try the CT60 patches for Cubase ...
edingacic
Postby edingacic » Sun Aug 20, 2017 1:44 am
roginator did you ever fix your Crazy dots support for cubase I just got TT030 and i am thinking of some addon cards
Atarieterno
Postby Atarieterno » Sun Aug 20, 2017 2:20 am
We will expect more experiences with Crazy Dots and Cubase.
Meanwhile, I can tell you that TT and Cubase work perfectly with my ET4000 and also with the resolution adapter TT built by Máté.
edingacic
Postby edingacic » Mon Aug 21, 2017 9:56 pm
@Atarieterno can you please tell me where to find this adapter by Máté? is that the Tenox adapter or something else? I just got my TT so I am new to it but today I installed CosmosEX and latest NVID and fixed the brightness of TTM195 CRT monitor (was quite scared to do it but read the manual about what to calibrate and it looks really grate now) :)
My mission is to build the fastest most responsive CubaseScore machine I can out of TT030
Atarieterno
Postby Atarieterno » Mon Aug 21, 2017 11:01 pm
Hi Edin Gacic;
In this forum the adapter manufacturer uses the nick "CodeKiller", and in the facebook "Atari TT users" is named "Máté Sebők".
The adapter works perfectly with my LCD Samsung SyncMaster P2470HD, the image is in 4:3 format but you can "stretch" it with the monitor function (although it is no longer the "natural", obviously). The Cubase gains a wonderful space for its working windows.
Tenox I think is also in this forum, but I do not know his nickname.
Best regards.
dbsys
Postby dbsys » Tue Aug 22, 2017 8:58 am
Atarieterno wrote:Hi Edin Gacic;
Best regards.
tenox
gemtwo
Postby gemtwo » Mon Aug 28, 2017 9:55 am
Hi i have exactly same problems with my VME card and ET4000 , that is on my Mega STE . I also tried all cracked and original versions.
I crashes after some minutes. And i have tried ALL versions eve Pro-24 all crashes , so whatever steinberg put in their code , it harms the emulation of graphics. The link to the CT60 fix is broken .
Atarieterno
Postby Atarieterno » Mon Aug 28, 2017 2:04 pm
Maybe it's a drivers problem.
This is my VME "Imagine" (ET4000) card with native drivers, without NVDI:
frank.lukas
Postby frank.lukas » Mon Aug 28, 2017 2:24 pm
When the Imagine Driver works, the Nova CrazyDots Driver for the Atari TT maybe will work too. Ask Idek for the Driver ...
edingacic
Postby edingacic » Thu Aug 31, 2017 11:20 pm
This is my setup now. I have fixed the brightness of my CRT monitor but I will get cable for bigger LCD also. I am looking for SoundPool green box to give me 4 more out or Steinberg SMP or FriendChip MM1 (this one I can't even find a picture to see how it looks)
stormy
Postby stormy » Sun Sep 10, 2017 12:12 pm
My cubase crashes on my et4000 driver (supplied by frank) but using the ECL device by Máté it is fine.
charles
Postby charles » Sun Sep 10, 2017 3:54 pm
Cubase likes to have no accessories loaded...basically Cubase wants to be exclusive on your Atari...no extras
good to see you got it working .....
I do a lot of midi stuff ...do u do any sys ex stuff?
The radioactive half-life : )
Atarieterno
Postby Atarieterno » Sun Sep 10, 2017 6:20 pm
I use these drivers for my "Imagine" card, which have the version for Mega STe and another for TT.
To work with music I have not loaded NVDI or any kind of accelerator.
http://www.mediafire.com/file/aazti9ct7 ... 4000ax.rar
edingacic
Postby edingacic » Tue Nov 28, 2017 1:12 am
can you post a picture with that card for 1024x768x256, 44hz running cubase? does it work?
piotrk
Postby piotrk » Sun Dec 17, 2017 6:37 pm
Hi @edingacic !
I can confirm that Cubase 3 and Cubase Score 2.06 is working on my Atari MSTE with Nova adapter (made by frank.lukas) and ATI Mach32.
Today I'm testing original Cubase 3 with red cartridge dongle and it works. Sometime i have blank screen after while (2-3 minutes) like screen saver and but I will test with different Nova configuration.
Cubase 3 cracked doesn't work and hangs after start. Only original one works.
charles
Postby charles » Sun Dec 17, 2017 6:46 pm
try replacing or removing some of the def files
then it might work ,,,def set def all def arr
I think these hold the setup informations which might conflict
and rectify the driver files all to .DRx extention
maybe even reduce the MIX files too!
EOX!!! : )
piotrk
Postby piotrk » Sun Dec 17, 2017 7:00 pm
@charles
It will solve "blank screen after a moment" or "cracked version hanging" ?
Right now I'm testing clean "vanilla" version of Cubase.
charles
Postby charles » Sun Dec 17, 2017 7:09 pm
cracked version ...
I think vanilla version is set up to default
but whoever cracked Cubase used somebodies disk that had prefences set .....
piotrk
Postby piotrk » Sun Dec 17, 2017 7:34 pm
Cracked version starts ok. When you start moving mouse cursor everything hangs and needs cold boot. For me not a problem I should solve the blank display after random while. Right now it could be everything. Computer, my ATI Mach32, Nova adapter, driver, driver settings... Currently it is awesome that it works at all...
Atarieterno
Postby Atarieterno » Sun Dec 17, 2017 7:53 pm
Beware of the screen saver: it is not compatible with Cubase and must be deactivated.
edingacic
Postby edingacic » Mon Jan 22, 2018 1:37 am
cool thanks for the update piotrk
Atarieterno
Postby Atarieterno » Fri Mar 09, 2018 5:04 pm
More information regarding my VME Imagine (ET4000) graphic card and Cubase:
In the TT, Cubase v3.02 works perfectly but Cubase Score does not work (the startup screen freezes). Cubase Score works correctly with the TT-high video adapter built by Máté.
Here we see the graphics card with a resolution of 1024 x 768 at 60 hZ, providing a huge working screen for Cubase:
Atarieterno
Postby Atarieterno » Fri Mar 09, 2018 10:58 pm
Of course, as was also mentioned in another thread: the screensaver of the graphics card is incompatible with Cubase.
I use the IM_COL.ACC accessory to deactivate the screensaver and it has also worked for other users with different graphics cards.
