Wait for 5secs or leave with keypress...
Postby simonsunnyboy » Fri Sep 18, 2015 4:40 pm
Hello all,
I'm a bit stuck with a small piece of m68k.
I want to code a loop, waiting for 5secs max, the loop is to be aborted on keypress. I do not want to use direct hardware access or polling the _hz_200 variable directly.
Is there a cheap and simple way available?
Regards,
ssb
mfro
Re: Wait for 5secs or leave with keypress...
Postby mfro » Fri Sep 18, 2015 4:57 pm
while Cconis() Cconin();       /* empty keyboard buffer */
start = Tgettime();
while (!Cconis() && Tgettime() <= start + 2);
Cconin();                      /* empty keyboard buffer again */
(off head, not tested, but should do the trick)
Why do you want to avoid reading _hz_200? There is no other easy way in TOS (apart from setting up an MFP timer yourself using Xbtimer() or direct MFP programming) to measure time. Even the GEMDOS way above _is not_ exactly what you want because GEMDOS can measure time in 2 sec intervals only (so it's either 4 or 6 seconds).
Postby simonsunnyboy » Fri Sep 18, 2015 5:24 pm
Tgettime() sounds like a good solution, 2secs intervals are ok.
I want to avoid using Super() in my case, that'S why I don't want to poll _hz_200 directly.
Thank you!
mfro
Postby mfro » Fri Sep 18, 2015 5:50 pm
Tgettime() bit 0-4 wraps around at 30 (=60 seconds) instead of 31, so above code will be off by 2 seconds occasionally.
This one is cleaner:
long get_time(void)
    return * _hz_200;
long timer(void)
    return Supexec(get_time);
start = timer();
while (!Cconis() && timer() <= start + 5 * Tickcal());
Mikefulton
Postby Mikefulton » Fri Dec 11, 2015 6:51 am
If this is a GEM app, just do event-multi with a 5 second timer and a keypress event specified.
wietze
Postby wietze » Fri Dec 11, 2015 9:25 am
Whats against counting vbls?
Postby shoggoth » Fri Dec 11, 2015 10:58 am
VBL frequencies vary.
Postby simonsunnyboy » Thu Apr 14, 2016 4:17 pm
Short answer: I decided to poll _hz_200 directly and it doesn't make any fuss. I actually implemented the thing in C now, my menu does not use assembly code for this.
Return to “680x0”
