New core: Gameboy
NML32
Re: New core: Gameboy
Postby NML32 » Mon May 30, 2016 6:54 pm
F12 or the Mist middle button doesn't bring up the core menu.
I'm running the latest GB core and firmware.
mambrino
Postby mambrino » Mon May 30, 2016 8:01 pm
NML32 wrote:F12 or the Mist middle button doesn't bring up the core menu.
No problem with latest GB core (150914) and firmware (160530) in my Mist (F12 and middle button).
NML32
Postby NML32 » Mon May 30, 2016 9:54 pm
Thanks, I'll double check maybe I messed something up. I'm moving cores to multiple SD cards to organize them.
Update: I was running an older GB core.
Thx
Alki
Postby Alki » Fri Nov 18, 2016 10:40 am
Sorry for refloating the thread and for my English, but I can not press "start" in any games. I've tried two keyboards and one real genesis pad...
edit: In the end I had to use a usb pad
DrOG
Postby DrOG » Sat Dec 17, 2016 5:50 am
Yes, as I see this is an 'USB gamepad only' core. It would be very nice to control this with my default 2-button db9-joy (I hacked earlier my old QuickShot II Plus, I had to rewire it anyway, so connected one of the two fire buttons to pin 9 instead of pin 6, now using the NES core the top bottom is the jump, the front the fire playing Super Mario ;-)). Other cores (beside the NES the SMS, PC-engine, and many Amiga titles) already support this.
I always hated gamepads, because grew up using mostly c64, and I still think the most perfect game controller is the joystick.
Hardware hacking "howto": http://wiki.icomp.de/wiki/DB9-Joystick
Mapping 'Select' and 'Start' to keyboard would also be necessary.
Thanks in advance: Gábor
Gehstock
Postby Gehstock » Fri Dec 22, 2017 4:46 pm
Work a little bit on the Core
Add Keyboard Controls
Add a Option to Override the Mapper(Some Game with MBC5 Mapper will work(Antz, Speedy Gonzales)). Reset Needed
Add GBC File Format(some GBC Games work on a normal GB)
-- Keyboard inputs :
-- ESC : Start
-- TAB : Select
-- SPACE : Button A
-- LALT : Button B
-- ARROW KEYS : Movements
Edit: delete Attachment(outdated)
DrOG
Postby DrOG » Fri Dec 22, 2017 5:45 pm
Thanks!!!
Can test only tomorrow morning, looking forward to it!
NegSol
Postby NegSol » Fri Dec 22, 2017 6:06 pm
Cheers!! :cheers:
NML32
Postby NML32 » Fri Dec 22, 2017 6:10 pm
Thanks for the update. :cheers:
Gehstock
Postby Gehstock » Fri Dec 22, 2017 7:25 pm
Add partially MBC2
Starting Games
    ARETHA
    Ayakashi no Shiro
    Dragon Ball Z
    Dragon Slayer Gaiden
    Fastest Lap
    Golf
    Hercules Eikou
    Jikuu Senki Mu
    Jinsei Game
    Jissen Mahjong Kyoshitsu
farvardin
Postby farvardin » Fri Dec 22, 2017 7:41 pm
Thank you Gehstock!
DanyPPC
Postby DanyPPC » Fri Dec 22, 2017 7:42 pm
It feels good :)
No sound in Castlevania, partially in Adventure Island. :cheers:
Postby Newsdee » Fri Dec 22, 2017 10:09 pm
Thanks a lot Gehstock!
DrOG
Postby DrOG » Sat Dec 23, 2017 5:23 am
Hi!
Tried quickly 6 GBC games, using the latest (second) core from Gehstock with the following results (see attachments also):
1. Bomberman Quest: loads title screen, but does not start.
2. Chessmaster: Working flawless.
3. Earthworm Jim - Menace 2 the galaxy: freezes at 'Nintendo' logo
4. Ghosts 'N Goblins: Works frawless.
5. Mortal Kombat 4: Does not start.
6. Pocket Bomberman: Flawless.
The compatibility is circa 50%, this is very good for the first attempt!
Thanks your work again: Gábor
SuperBabyHix
Postby SuperBabyHix » Sat Dec 23, 2017 5:41 am
This is awesome, thanks so much. Game Boy is one of my favorite systems. I actually just finished adding a backlight to my original model. Not sure how much it helps, but one way to identify what GBC games are backwards compatible with the original GB is that they have a black cartridge shell compared to the clear shell of GBC only games. No way to tell from a file, but you could always do an image search for the cart.
DrOG
Postby DrOG » Sat Dec 23, 2017 5:52 am
Hi!
I used Wiki's "Backward Compatible" column:
https://en.wikipedia.org/wiki/List_of_G ... olor_games
I downloaded the ROMs from the net, as did never have GameBoy or other handheld console. Here in the eastern bloc these were unfortunately less common than in the capitalist western (or far eastern) countries...
Gehstock
Postby Gehstock » Sat Dec 23, 2017 4:46 pm
Better Compitablity - more Mappers partially added
vebxenon
Postby vebxenon » Sun Dec 24, 2017 4:29 am
Outstanding work!! Thanks very much! :D
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Postby DrOG » Sun Dec 24, 2017 5:08 am
Gehstock wrote:Better Compitablity - more Mappers partially added
Hi!
Nice progress!
Found an interesting bug: tried 'space invaders (u) [c][t1][h1].gbc', and the first (crack) screen is shaking, but the game itself is perfect (see attachments).
Thanks for perfecting this (and other) core(s)!
Gábor
vebxenon
Postby vebxenon » Thu May 31, 2018 6:27 am
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
MasterOfGizmo
Postby MasterOfGizmo » Thu Sep 20, 2018 5:45 pm
The fact that some gbc games run on the classic gb may be a nice starting point for gbc support in the core.
I wonder if these games differentiate between the two machines at all or if they e.g. just setup color registers which then just don't do anything on the classic gb.
However, i'd expect those games to not use all gbc features so they might be a good start, anyway.
Televicious
Postby Televicious » Sun Feb 03, 2019 9:58 pm
Anyone have a copy of the last gameboy core? The one on mist page is from like 2015 and lsdj doesn't work. gehstock link is broken.
Nevermind I found the gehstock backups and tried the newer one, but it doesn't work with VGA. Just keeps flashing a black screen. Hear the start screen bleep and then it just flashes out of range.
DrOG
Postby DrOG » Mon Feb 04, 2019 5:48 am
Dupe, deleted.
DrOG
Televicious wrote:Nevermind I found the gehstock backups and tried the newer one, but it doesn't work with VGA. Just keeps flashing a black screen. Hear the start screen bleep and then it just flashes out of range.
The VGA-compatibility of this core is not so super, but it definitely works on less picky displays, like BenQ BL-912. My Samsung TV does not like it also.
Televicious
Postby Televicious » Tue Feb 05, 2019 12:51 am
Hmm, maybe a scan quadrupler. I doubt it's displaying in 320x288 or 160x144. Wonder what it's configured to display as. Will try different screens and see if anything works. Thanks for the tip.
