Floppy Disk Stream Image Repository
Moderators: DrCoolZic, Brume
kodak80
Re: Floppy Disk Stream Image Repository
Postby kodak80 » Sat May 19, 2018 11:08 am
Thanks Jean. I now have the sync set up via the Mega client.
Postby DrCoolZic » Sat May 19, 2018 3:09 pm
kodak80 wrote:... When I try Mega client software says I need Full Access to sync your share. :( ...
Does it work for you now :)
Apparently 21 files have been definitively removed ? Is that you ? should I put them back ?
Also many files have been updated ???
Mega indicate that you have removed lots of files 41 + 55 + 38 +52 + 4 = 190
Don't remember when I did last sync but compare indicates 21 removed, 168 updated, 108 added
I am now resync with MEGA after lots of update but still missing 21 files
Postby DrCoolZic » Sat May 19, 2018 3:46 pm
Not sure what you are doing on your side but this is getting strange.
Meanwhile I am going to reload the 21 files that have disappeared
Postby DrCoolZic » Sat May 19, 2018 3:51 pm
kodak80 wrote:Thanks Jean. I now have the sync set up via the Mega client.
Hum may this is the problem. You have to realize that now if you remove files from the sync directory this will be removed from the repository.
So normally you should only add new things in the sync directory 8O
So now it looks like you have created new version of about 153 files that takes up 5.24 GB on the repository.
I hope I am doing the right thing I am going to remove the old versions ...
Done all gone
Now list is 529 titles but still 21 you removed to upload
And for security I now backing up on 3 machines.
Update: 528 one was exact duplicate
kodak80
Postby kodak80 » Sun May 20, 2018 1:26 am
I did not intentionally remove any but I sync'd to the folder where I had been downloading manually to save having to download everything again in the Mega client syncing. Hopefully now I am sync'd this won't happen again.
Looks like a few of my dumps were removed in the sync process. I have added these back now.
Also, the two copies of Wind Walker look to be mine. The Wind Walker [Boxed].7z contains only SCP dump, the one I added contains both SCP and KF so the Wind Walker [Boxed].7z one can be removed.
Postby DrCoolZic » Sun May 20, 2018 8:14 am
No problem I figure out that it was a problem of synchronization. As I said I found that somehow several images were not uploaded so they are currently slowly loading (I had to cut my server for the night). 19 to go 8)
I can see that you are still uploading new files :cheers:
It would be nice if Brume could also upload some files as he seems to have a large collection
Seems like we are uploading the same files. Somehow my MegaSync has a list of some of your files you removed and that you are now re-uploading. The problem is that I dont know where it maintain this list so I am not sure I will be able to stop it to upload?
kodak80
Postby kodak80 » Sun May 20, 2018 8:30 am
I can add (KDK) to the end of the filenames I am adding. This should then stop the conflicts with files. You may need to login to Mega in a browser to see the conflicts data. I can see a hidden "rubbish" folder on my computer in the sync'd share folder which has dated folders with some of the files in.
Yes, it would be good if Brume or others can add their dumps. :D
Postby DrCoolZic » Sun May 20, 2018 9:04 am
I think we are getting close to a stable repository. I still have 18 files uploading (that for some reason where removed)
I can see that you have updated 10 files and added 30 files. So the total should be around 574-575
You can remove the "rubbish" directory. From Mega Transfer Manager click on + Add ... click Settings click advanced and here you will see the button to remove the rubbish ... you can also set the scheduler for cleaning rubbish
Do you still have more to upload?
Once it is stable we can see if can be consolidated.
I removed "Wind Walker [Boxed]"
Wont be able to do much today as we have family home :D
dma
Postby dma » Sun May 20, 2018 9:09 am
Great to see such a repository being built. :)
kodak80
Postby kodak80 » Sun May 20, 2018 10:03 am
248 dumps uploaded. Pretty much all I have in my software collection. May have a few more but I can hold-off for now.
Postby DrCoolZic » Sun May 20, 2018 4:30 pm
Many thanks for your help Rob this is a great collection 8)
I hope people having different images will add to this 575 titles (some titles have many images from different people ...)
The current list and MD5 values are posted here viewtopic.php?f=104&t=28228&p=276419#p276419
Postby DrCoolZic » Tue Jun 05, 2018 7:49 am
Note that many images have not been tested. Therefore there are probably some unusable images. If you find one please report.
Kodak80 has found a problem with my GauntletII.7z dump. There is a new version Gauntlet II (KDK).7z dump accessible at
https://mega.nz/#!4B4BXR7K!zxmXfrS_ZBCK ... gpCxv3ZLVA
So current list contains 577 images. I will remove the faulty image
bandit
Postby bandit » Sat Jun 09, 2018 6:38 pm
if you want you can use: www.climatics.com/filerun now space/ul/dl limits etc.. i can create users for you...
Postby ijor » Tue Jun 12, 2018 7:33 pm
bandit wrote:if you want you can use: http://www.climatics.com/filerun now space/ul/dl limits etc.. i can create users for you...
IMHO. That would be much better than using Mega. Mega is not the right place for this kind of stuff, and not only because of the bandwidth limit.
bandit
Postby bandit » Wed Jun 13, 2018 5:21 am
I switched from the web client to a FTP Server. since the Filerun web client was very unstable.. Let me know what you would like. 1. put this stuff under my normal archive with a few users which have write access or a closed group?
bandit
Postby bandit » Wed Jun 13, 2018 9:13 am
some one needs to ul everything:) I have a mega 5 gb limit:(
kodak80
Postby kodak80 » Wed Jun 13, 2018 12:44 pm
I have started uploading my dumps to the FTP site. :D
kodak80
Postby kodak80 » Thu Jun 14, 2018 9:57 am
SecretofMonkeyIsland.7z - Disk 4 seems to be incomplete and only has first 4 tracks. My copy "SecretOfMonkeyIsland (KDK).7z" is complete. :D
bandit
Postby bandit » Thu Jun 14, 2018 11:40 am
can you replace it?
kodak80
Postby kodak80 » Fri Jun 15, 2018 8:28 am
bandit wrote:can you replace it?
That one is DrCoolZic's. I have already uploaded my copy (KDK) which has all 4 disks in the dump.
bandit
Postby bandit » Fri Jun 15, 2018 8:53 am
now everything should be there..
Postby DrCoolZic » Fri Jun 15, 2018 11:15 am
Hello sorry for the late reply I was travelling.
First Bandit thanks for offering space.
Feel free to upload (you or Kodak80) anything from the Mega repository.
I have uploaded the images so anyone can access them.
Postby DrCoolZic » Fri Jun 15, 2018 11:18 am
kodak80 wrote:SecretofMonkeyIsland.7z - Disk 4 seems to be incomplete and only has first 4 tracks. My copy "SecretOfMonkeyIsland (KDK).7z" is complete. :D
I will have a look at it and recreate a new image. I need to create a todo list ...
Seems like my SCP board is repaired and shipped back to France :)
Postby DrCoolZic » Fri Jun 15, 2018 11:28 am
Does not seems to work?
bandit
Postby bandit » Fri Jun 15, 2018 11:46 am
ftp.climatics.com
