MI-3: Image format converter and slideshow
Postby rockyone » Fri Jun 26, 2015 4:12 pm
24_09-2019
MI-3.PRG : http://www.mirari.fr/GuGa
Floppy disk 1440 Ko : http://www.mirari.fr/Uar6
Floppy disk 720 Ko : http://www.mirari.fr/iaAj
All files : http://www.mirari.fr/uAWC
DPF File in french : http://www.mirari.fr/5cGa
Tested on Steem v3.02 and Hatati 2.00 with the TOS FR 1.02, 1.04, 1.06,1.62, 2.05 and 512 Kb of RAM
Tested on Hatati 2.1.0 in STE mode with the TOS 1.62 FR, in mode MEGA STE with TOS 2.05 FR and 512 Kb of RAM
Image,Image,Image,Image
Image,Image,Image
Art-Director color cycles are not converted to other formats.
Converting a maximum cycle of eight Neo or Degas colors to Art Director is supported.
MI-3 can load the files ".PL1" and .PL2 -on the original plane- and save them again.
You can also open or save a file by clicking on the left side of the screen
Do not confuse the extensions
ART of: Artistic Director, GFA-Artist, The ArtiST
PG1-3 of: Graphics Processor with PG0-2 from Paintwork, Anivision and Apaint that are not loaded.
Re: picture format converter
Postby rockyone » Sat Jun 27, 2015 2:24 am
New file
I Had forgotten a code compilation
Accelerated conversion of Omikron "Pi1" to "RGH"
Postby rockyone » Sun Jun 28, 2015 11:28 pm
New files
Conversion optimization.
Postby rockyone » Tue Jun 30, 2015 9:07 am
this one is not finished and can not convert many format
Open:
art neo mi1 mi2 pi1 pi2 pc1 pc2 rgh sd0 sd1 spd spu
Save
art neo mi1 mi2 pi1 pi2 rgh sd0 sd1
operates in low resolution and medium resolution for all these formats.
would you have routines for the other format?
Postby rockyone » Wed Jul 01, 2015 11:41 am
Strange, the RGH files (ZZ-ROUGH) created by DALI-4 have one byte extra rehearsal
Postby rockyone » Mon Jul 06, 2015 3:10 am
I wanted to post anything because I did not have much free time right now,
I corrected the resolution change.
and add loading image Tiny (in basic for the moment)
Postby rockyone » Mon Jul 06, 2015 10:52 am
DALI is ZZ-ROUGH,
The LPK files and RGH have an amazing similarity.
Apart from a different file header and zero bytes totally useless, these two formats are identical cuts. (I use the RGH display routine for displaying LPK).
Bytes and control data's image are compressed in a totally identical way, but with a slight Difference all the same.
DALI adds a null byte at the end of the bytes of control data and a false image corresponding image data in late ???
It's bytes are not read by Dali and Zz-rough !!
He did the same for the images he converted RGH. (Hence my previous post).
Postby rockyone » Tue Jul 14, 2015 8:42 pm
Adding the loading and saving compressed files DALI LPK, MPK, HPK
TNY opening low , medium and high resolution(ASM 68000)
Postby rockyone » Mon Jul 20, 2015 9:07 pm
I am looking for some moving pictures Degas Elite format, Neo, tny ....
Added PNT uncompressed format and compresed format low and medium resolution
for high- resolution images, start the progam in high resolution .
FedePede04
Postby FedePede04 » Mon Jul 20, 2015 10:42 pm
rockyone wrote:I am looking for some moving pictures Degas Elite format, Neo, tny ....
Added PNT uncompressed format.
hi
do you mean graphic moving pictures or color cycles pictures?
if you mean color cycles pictures i have a few of the most widespread ones, but you probably already have those, but i can upload them for you.
I always love to see that others also are making things for the ST, keep it up :)
Maartau
Postby Maartau » Mon Jul 20, 2015 10:57 pm
In French : tu cherches des images avec rotation des couleurs comme celles de -Degas Elite- ?
FedePede04 wrote:do you mean graphic moving pictures or color cycles pictures?
I think he's looking for color cycles pictures (what I wrote in French).
rockyone wrote:I always love to see that others also are making things for the ST, keep it up :)
+1 :thumbs:
Postby rockyone » Tue Jul 21, 2015 12:08 am
yes, I do not ais .
In French,: c'est ce genre d'image que je recherche.
I just added the loading PNT compressed pictures in low and medium resolution.
Maartau
Postby Maartau » Tue Jul 21, 2015 3:32 am
Here's one : mountains + water using colors cycling (PI1 - 32,066 as Degas Elite) :) .
@FedePede04 : Yes, that's it 8) .
FedePede04
Postby FedePede04 » Tue Jul 21, 2015 4:35 am
i just had a fast look through the Atari pictures that, and i have and found a few,
so i hope other can help you with more pictures.
Cycles Pictures.rar
Postby rockyone » Tue Jul 21, 2015 5:48 am
thank you for your images.
there are also images with a color cycle , medium and high resolution?
FedePede04
Postby FedePede04 » Tue Jul 21, 2015 5:56 am
hi
as i know it, you can't do it in hires, but i think to remember that Degas support it both in low and midres.
you can use my drawing program for windows to make a medium degas picture with color cycles.
http://www.atari-forum.com/viewtopic.php?t=23971
Neo is only for low res, though the file header support Mid and Hi res.
Postby rockyone » Tue Jul 21, 2015 3:08 pm
Very nice work FedePede04
FedePede04
NEO only low resolution ... my confusion comes this page
http://phoenix.inf.upol.cz/~opichals/libhyp/hypview.cgi?url=http://jaysoft.atari.org/docs/ataripf.hyp&index=33
Image :)
FedePede04
Postby FedePede04 » Tue Jul 21, 2015 3:25 pm
rockyone wrote:Very nice work FedePede04
Many Thx
rockyone wrote:
FedePede04
NEO only in low resolution ... , my confusion is due to this page.
the neo header support mid and high res, but i don't think that any program from the 90' supported that,
but i am use it, so you can save Neo mid and high res in my drawing program, i am also using the width and the height for custom pictures size.
btw i think that you can, run into problems converting Degas colors cycling picture, into Neo colors cycling picture.
Degas have 4 colors animators where Neo only have one.
Postby rockyone » Wed Jul 29, 2015 12:00 am
lp
Postby lp » Sat Aug 08, 2015 5:26 pm
Can someone tell me what drawing program creates mi1, mi2, and mi3 files?
Postby rockyone » Sun Aug 09, 2015 10:44 am
lp wrote:Can someone tell me what drawing program creates mi1, mi2, and mi3 files?
Format I created for this game http://www.atari-forum.com/viewtopic.php?f=3&t=20361
change the header of the current format. "$FFFF" serat:" $FFF0" or "$FFF1" or "$FFF2" according to the image resolution
This will support CONVERTER former Mi1 ( After leave )
Maartau
Postby Maartau » Sun Aug 09, 2015 12:41 pm
Just discovered your game & can't play for the moment : nearly fully dead laptop :( ... At least downloaded.
Thanks for the link 8) .
lp
Postby lp » Sun Aug 09, 2015 12:58 pm
I wrote a codec for zView (mi1.ldg) to view these. :)
Can be found here:
https://www.dropbox.com/sh/hk65mapqd3fm ... KqQTa?dl=0
Postby rockyone » Sun Aug 09, 2015 6:41 pm
Marrtau :Just discovered your game & can't play for the moment : nearly fully dead laptop :( ... At least downloaded.
I think I forgot to turn off my test "G" key in this version :D
Postby rockyone » Sun Aug 09, 2015 6:49 pm
LP,
good job
What is the minimum configuration for Zwiew
file for ART (Art Director), What is the use of bytes that follow a range of rotation of command line
Return to “Other BASIC”
