3D cube routine example ?
Postby exxos » Sun Jun 07, 2015 9:37 am
Can anyone help code a simple routine in ( resulting in machine code) ? I want to add a 3D test to GemBench , so would need a machine code program I can call and run. Gembench can set the timer before the execution of the code, and just wait for the machine code to exit (maybe after 10 seconds) then I can read the timer again to see how long it took. Though I need someone willing to help code the actual routine. Ideally it would use as many integer divisions as possible to make use of faster CPU speeds.
I'm not looking for anything fancy, just a spinny rotating cube would be ideal. probably geared up for medium resolution, but should also be able to run in other video modes for falcon users who may use higher resolutions or 256 colours etc. I guess it would be ideal if the code would just switch resolution to ST MED RES to prevent some confusion.
There may be some routines out there already, or something in a game menu that could be ripped out I could use. Though need help with all that kinda stuff :)
Re: 3D cube routine example ?
Postby exxos » Sun Jun 14, 2015 9:45 am
I am still hunting for some 3D code. I guess a 3D rotating cube must have been done in assembler at some point ??
Postby AtariZoll » Sun Jun 14, 2015 10:15 am
I saw some simpler 3D sources in past, but need to look after again, because all those sites seem disappeared.
Don't know is medium resolution good idea. I don't know anything done for ST med res. Rotating cube is often done just as playback of prerecorded frames. In case of Ataris (and other oldies) without FPU integer divisions are avoided, even if there is such CPU command, because slowness. Instead it tables with precalculated results are used. Some universal code, for diverse resolutions hardly exists for Ataris, I think.
If you give me some intro (link), I can rip it :D
And something more: for benchmark purpose must remove v-sync from code, otherwise you may experience that rendering time is same on faster CPU .
Postby exxos » Sun Jun 14, 2015 10:28 am
AtariZoll wrote:I saw some simpler 3D sources in past, but need to look after again, because all those sites seem disappeared.
Low res is possible, just app runs in medium res.
I have been trying to find some 3D example in a game menu or demo or something, but not having much luck. It is games like castle master which make use of faster cpu speed. So need something to emulate that type of 3D routine. As you say pre-calculated stuff.. is no good for benchmarking testing.
AtariZoll wrote:And something more: for benchmark purpose must remove v-sync from code, otherwise you may experience that rendering time is same on faster CPU .
yes, I saw that in cyberpaint :D
wietze
Postby wietze » Sun Jun 14, 2015 11:17 am
Have a look at the future minds code in ggns atar master sources. There is a non-precalced 3d there iirc. Otherwise there will be more examples there.
Google for ggn Atari master sources (I have trouble copy pasting on my mobile device, sorry).
Postby AtariZoll » Sun Jun 14, 2015 11:28 am
Here is the source of Alpha Waves. Comments are in French, maybe you are better with it :D
ALPHAWSR.ZIP
Precalculated will work faster with faster CPU and RAM. Multiplication and division speed depends mostly from CPU clock, and barely on RAM speed.
Postby exxos » Sun Jun 14, 2015 11:34 am
wietze wrote:Have a look at the future minds code in ggns atar master sources. There is a non-precalced 3d there iirc. Otherwise there will be more examples there.
https://github.com/ggnkua/Atari_ST_Sources/tree/master/ASM/Futur%20Minds/SOURCES
Is it one of those ?
wietze
Postby wietze » Sun Jun 14, 2015 12:12 pm
Yes. At least a glenz.
Postby exxos » Mon Jun 15, 2015 8:46 am
wietze wrote:Yes. At least a glenz.
I tried the PRG, but just gets stuck on the busy bee icon :roll:
Postby exxos » Mon Jun 15, 2015 12:38 pm
AtariZoll wrote:Here is the source of Alpha Waves. Comments are in French, maybe you are better with it :D
ALPHAWSR.ZIP
Is the PRG a actual runnable program as it crashes for me ?
Postby Cyprian » Mon Jun 15, 2015 12:50 pm
GLENZ.PRG works ok under Steem/Hatari in STE mode
https://github.com/ggnkua/Atari_ST_Sour ... RCES/glenz
MasterOfGizmo
Postby MasterOfGizmo » Mon Jun 15, 2015 1:22 pm
exxos wrote:Is the PRG a actual runnable program as it crashes for me ?
Works nicely on a MiST.
Postby exxos » Mon Jun 15, 2015 1:25 pm
This is all I get. running steem at 128mhz. Just seems to make the bee flicker thats all.
Postby AtariZoll » Mon Jun 15, 2015 1:45 pm
It works fine in Steem, just need to edit few things - like launcher - removing A:\ . But main problem is that some include files missing. Namely: SNDTBL.S - not needed for 3D really, and FILL.S - this is needed. If someone can contact author about it ...
Postby exxos » Mon Jun 15, 2015 1:48 pm
AtariZoll wrote:It works fine in Steem, just need to edit few things - like launcher - removing A:\ . But main problem is that some include files missing. Namely: SNDTBL.S - not needed for 3D really, and FILL.S - this is needed. If someone can contact author about it ...
hmm, I am trying to run from C: .. but same for running from A:\, it just go right back to desktop in steem. So ALPHAWSR and GLENZ don't work in steem for me :shrug:
I tried GLENZ from A: and get TOS error 35.
Postby exxos » Tue Jun 16, 2015 7:26 am
can anyone who can run those 2 programs take a couple of screenshots so i can see what they actually do ?
Postby Cyprian » Tue Jun 16, 2015 9:28 am
GLENZ.PRG
wietze
Postby wietze » Tue Jun 16, 2015 9:36 am
https://www.youtube.com/watch?v=Mp7zbub9MQ0
mfro
Postby mfro » Tue Jun 16, 2015 9:37 am
exxos wrote:can anyone who can run those 2 programs take a couple of screenshots so i can see what they actually do ?
You probably downloaded incorrectly from git. You need to click until you get to the "View Raw" display, then click that link.
This should give you a .prg file with 13467 bytes. At least this worked for me.
Postby AtariZoll » Tue Jun 16, 2015 9:45 am
Cube/AlphaWaves is game, and as I know, it is first 3D game and only one for Atari ST, which source is published. Of course, it needs plenty of time to go in that code.
Glenz is simple demo, and as I see very suitable for benchmark purpose.
I did some modifications in source, and here are 2 versions:
GLENZBM.ZIP
GLENZB is standalone benchmark, will outprint score at end of demo. What is actually count of 200 Hz interrupts during test. So, lower value is faster machine. Run it from ST medium res. 8MHz ST will give ~ 11228 . 16 MHz Mega STE : 7217 . Falcon : 4552 .
Test is with Vsync waiting off, as recommended earlier. With it on values are little higher: 11275, 7536, 5221 . Note that difference is much higher by faster machines. That's normal, as there is more waiting on them, and this demo uses a lot, 16 screen buffers .
GLENZP is intended to be called from another APP, via Pexec . It will give score, same as above in register d0 (16 bit) at exit, so caller can use it. Will return to medium res at exit too, so should be fine for Gembench.
Postby exxos » Tue Jun 16, 2015 2:12 pm
Looks awesome. I don't think Hisoft has Pexec command, to call a program Rodlphe did was this..
dim tostest%(1000)
BLOAD "TOSMOD.O", varptr(tostest%(0))
code=varptr(tostest%(0))+36
print "calling tos test"
call loc code,1000
print "tos test done"
I enclose the 2 files also. hopefully you can work out how its setup to modify GLENZ ?
TOSMOD.zip
call loc code,1000, where 1000 was the number of loops to do in the program.
Postby AtariZoll » Tue Jun 16, 2015 3:55 pm
Well, it is possible to make it as module, but that's additional complication, and I don't see how to supply result (score) to caller.
If you measure time in caller, it will give not so accurate result, because there is preparation phase.
Pexec is regular GEMDOS command, like command for printing some txt. It must be supported in Basic. Just need to give filename as parameter, and will get score as return value. Really should be not hard.
Postby exxos » Tue Jun 16, 2015 4:12 pm
I just did some testing on real ST.
Score 10162 16mhz machine
score 11232 8mhz machine.
So not a huge jump really around 10% :? I know castle master runs a lot faster in 16mhz than stock machine. So that must use a lot of integer divisions, and assume GLENZ does not ? It looks a really nice test, but if only going to show 10% speed boost at 16mhz then i'm not sure its a good test to include :roll:
Postby AtariZoll » Tue Jun 16, 2015 5:19 pm
I think that you mixed results - lower score is faster.
Division is avoided in good 3D code, because it is slow. There is only few in Glenz, and that's OK. 16 MHz on Mega STE gives good speed gain, as may see. With good 3D code beside CPU speed, RAM speed is relevant too.
If you want CPU division test, we can make special test for that .
Postby exxos » Tue Jun 16, 2015 5:40 pm
Yeah RAM being the bottleneck as normal :roll: There is a integer division test which shows 195% normally. Graphics normally show a boost in speed also at 16mhz. Though I thought as castle master is 3D and runs faster, then another 3D routine would show similar results. But like you say, it depends how it is coded. A lot of GEM/GFX loops are already in GemBench so I am not sure if anymore tests could even be added to show better use of CPU 16mhz. Things which depends on RAM access a lot are not going to work so good, so probably the reason why GLENZ does not show much speed boost. On machines with cache or faster access to RAM then of course GLENZ will show better results. Really it is another RAM speed test loop :roll: So not really sure if any functions will make any good use of 16mhz CPU time ?
Return to “680x0”
