Amiga SCP copies question
Stefan jL
Postby Stefan jL » Sun May 31, 2015 6:40 pm
Yes a thread were i discuss Amiga SCP copies :wink:
I was wondering about the "Leander" SCP at retrobackup FTP since i cant get them to run on my Amiga 500 (1mb), there is no known problem with those images? The "Ork" images does not work either for me.
JimDrew
Re: Amiga SCP copies question
Postby JimDrew » Sun May 31, 2015 11:09 pm
Both work on a stock A2000. The images also work WinUAE and FS-UAE.
I am the flux ninja
Stefan jL
Postby Stefan jL » Mon Jun 01, 2015 2:59 am
The Leander preview works for me but i guess it does not have any copy protection, i will do some more tests when i get home from work today.
Stefan jL
Postby Stefan jL » Mon Jun 01, 2015 7:18 pm
After a few more tries so is it still not working for me? :shrug:
I also tried Winuae 3.1.0 public beta 18 and both Leander and Ork is not working for me there, i did a try with Amnios also and it only shows the Psygnosis logo and then stops loading... the same thing happen on my Amiga 500 when i write back Amnios to disk.
JimDrew
Postby JimDrew » Mon Jun 01, 2015 11:54 pm
Make sure that you set the Amiga to NTSC, 68000 mode, and use OS1.3 ROMs.
I am the flux ninja
Stefan jL
Postby Stefan jL » Tue Jun 02, 2015 3:06 am
ah.. switching to NTSC in Winuae made it work, my Amiga 500 is a PAL model though and i had no idea games on Amiga was making a difference to NTSC and PAL models... thanks for the info :)
Are all Amiga SCP's on retro backup for NTSC only?
JimDrew
Postby JimDrew » Tue Jun 02, 2015 5:15 am
I am not sure how many images on that Retro Backup site are NTSC vs. PAL, but it really doesn't matter because all Amigas can switch between PAL and NTSC modes via software. Under OS2.04 and later ROMs, you can switch via the boot menu.
I am the flux ninja
Postby AtariZoll » Tue Jun 02, 2015 7:22 am
So, Amiga SW is even more picky with PAL/NTSC settings ? My advice: stick to good old Atari :mrgreen:
JimDrew
Postby JimDrew » Tue Jun 02, 2015 2:25 pm
Not picky, but you can deliberately make something NTSC or PAL only. Later in the life of the Amiga gaming, the manufacturers just made their games auto-switching.
I am the flux ninja
Stefan jL
Postby Stefan jL » Tue Jun 02, 2015 5:15 pm
Yes there are some Atari ST games that only work on USA TOS.
BTW.. could anyone post SCP images of "Utopia" (Amiga PAL) here? :)
dlfrsilver
Postby dlfrsilver » Tue Jun 02, 2015 10:02 pm
Psygnosis games are Zoned. You must have either PAL or NTSC version. Only way to use the NTSC version on a PAL amiga is to install it with whdload.
JimDrew
Postby JimDrew » Tue Jun 02, 2015 10:12 pm
Besides having the OS2.04/3.0 boot menu to select NTSC or PAL before the boot, there are several programs that will reboot your Amiga and lock it in either NTSC or PAL mode for computers with OS1.2/OS1.3.
I am the flux ninja
