multi-format floppy - SCP imaging
kodak80
Postby kodak80 » Wed May 20, 2015 11:28 pm
Just wondering how best to do a dump of a floppy disk that has Amiga, PC and ST data on it? The disk is a Public Domain cover disk and has a note on the label "Tri-format disk by Rob Northern Computing". Do I need to do 3 dumps of this disk with Amiga, PC and ST settings or is there another option to just do 1 dump of the disk data?
JimDrew
Re: multi-format floppy - SCP imaging
Postby JimDrew » Thu May 21, 2015 5:36 am
One dump in index mode should work for all formats.
There really aren't different formats with flux.. the disk type really just fills in the number of tracks.
I would like to see the image.
I am the flux ninja
kodak80
Postby kodak80 » Thu May 21, 2015 8:32 am
Here is the dump (5 rev) that I did:
https://mega.co.nz/#!FBECFIbL!hQ0vUG6eY ... LNWOKfERVw
The PC and ST files are all viewable in Steem. When I try and use the SCP file with WinUAE it does not boot up.
Here is the disk layout:
dlfrsilver
Postby dlfrsilver » Thu May 21, 2015 3:21 pm
One hint : the amiga part can only be accessed thru the workbench, it can't be loaded right away.
It contains 4 programs :
-Zeus
-Intuitracker
-Nuke
-backup
JimDrew
Postby JimDrew » Thu May 21, 2015 4:10 pm
Yep, that image is fine and you only need a single revolution. The Amiga compatible portion does not auto boot. It does pop the disk up on Workbench as "Tri-format disk", with the programs mentioned above.
I am the flux ninja
kodak80
Postby kodak80 » Thu May 21, 2015 11:47 pm
Cool. Thanks both. I have learnt something today. :D
