amstrad cpc 6128
DrOG
Re: amstrad cpc 6128
Postby DrOG » Fri Jul 14, 2017 4:43 am
First of all, thanks for the developer for his sustained and devoted work!
Since months this is the only core which is still actively and continously debugged and enhanced.
Tested the latest core (amstrad_170713_r005.8.14.4e.rbf), in 15kHz mode it's just perfect, even the green OSD mode is working well (see screenshot #1).
But in scandoubler enabled mode, it's compatibility is still moderate (see screenshots #2 and #3, 'Nem támogatott üzemmód' means 'Unsupported Format'). Screenshots #1 and #2 taken from my Samsung LE40B650's framebuffer, #3 from my BenQ BL912, which says signal is 800x600@73Hz.
vebxenon
Postby vebxenon » Wed Aug 16, 2017 6:23 pm
Well, FreeMac still believes in MiST and he still works in improving his core:
https://github.com/mist-devel/mist-bina ... es/amstrad
[Amstrad] r005.8.15 : arnoldemu's first FDC tesbench applied.
Core updated 5 days ago.
It's great to see new updates in our still living hardware.
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Postby vebxenon » Wed Aug 16, 2017 6:42 pm
Now, for example Street Fighter II Beta works! :cheers:
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Postby DrOG » Thu Aug 17, 2017 3:47 am
Nice work!!!
RobeInie
Postby RobeInie » Sat Aug 19, 2017 7:16 pm
This is one of my favourite cores and I am happy because it have a lot of updates , !
In VGA the core goes at 60Hz and in Scart at 50Hz, is right ? Would it be at 50hz on VGA ?
(perhaps overclock option like the Spectrum core has?)
And I have read that will be able to load CDT , would be nice to see real time tape loading :)
DanyPPC
Postby DanyPPC » Sat Aug 19, 2017 8:41 pm
In VGA the vertical frequency is set on 72Hz if i don't i wrong.
DrOG
Postby DrOG » Sun Aug 20, 2017 5:01 am
I remember 73Hz, which is a pity, 72 or 75Hz would be much more compatible. But in SCART mode (50Hz) it's awesome!!!
DanyPPC
Postby DanyPPC » Mon Sep 18, 2017 7:13 pm
New Update r005.8.16c3 - Z80 instruction timing effort (MEM_slow=slow):
+Using T80se.T2Write=1 better scores at WinAPE plustest.dsk testbench Z80 instructions timing
+MEM_wr=slow (theory value, quick is a hacked value accelerating MEM_wr)
+Still Rising demo : less garbage pixels, can be run completly using MEM_wr=slow
+Logon's run - 3D meets the aging bits : better, can be run completly using MEM_wr=slow
nightshadowpt
Postby nightshadowpt » Mon Sep 18, 2017 9:36 pm
Great to see another update for this amazing core.
Thank you for your effort. It is highly appreciated.
DrOG
Postby DrOG » Tue Sep 19, 2017 12:23 pm
Thanks for your continuous and exhaustive work!
DanyPPC
Postby DanyPPC » Wed Sep 20, 2017 8:54 pm
Another release candidate 4 (amstrad_170918_r005.8.16c4.rbf):
Instructions using 5T during M1 cycle does need 2 WAIT_n insertion. Problem is that I don't know exactly when inserting them,
Resulting WinAPE plustest.dsk testbench Z80 instructions timing border effect (previous instruction tested saying "I'm incorrect" but it was a correct one)
Still Rising demo : no more garbage pixels in plasma using MEM_wr=slow
30YMD : you can now use the main menu "cursor" using MEM_wr=slow
DrOG
Postby DrOG » Thu Sep 21, 2017 4:14 am
Awesome!!! :cheers:
vebxenon
Postby vebxenon » Thu Oct 19, 2017 3:02 am
New releases! As always, our friend Freemac is working hard on it :) :cheers:
A fork of r005.8.16c3 (r005.8.16c4 is invalidated)
A Principe Of Concept applied to correct instruction timing one per one (I just applyed it to 2A instruction, that is them ok under plustest.dsk - "testbench 5")
Removed "MEM_wr:slow|quick" and replaced by "VGA:vram72Hz|scandb50Hz".
scandb50Hz is a merge of a strong very old work (rOO5.0c18 2015) around scandoubler, now I have enougth place to put both implemented (PS : mode TV is still here, see scandoubler in mist.ini)
I don't like personnaly scandoubler with CPC, because it doesn't run fine with basic mode 2.
But as it permits showing the background flying 1943 airplane on "Logon's run - 3D meets the aging bits 2017" demo, it's cool to keep this feature.
It will certainly also permits to progress with graphicals testbenchs also.
+ scandoubler green
It's still in progress, but some would have lot of fun playing with scandb50Hz.
r005.8.16c15 and r005.8.16c16 are the same, c16 is the one with "scandoubler green" implemented on it in fact.
r005.8.16c20 does pass all plustest's 5th testbench, but is not enough mature for me yet.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Postby DrOG » Thu Oct 19, 2017 4:48 am
Yes, this is the only computer core on MiST since a long time which is continuously updated and debugged.
Unfortunately VGA 'vram72Hz' is still 800x600@73.
But 'scandb50Hz' is 720x576@50Hz, this may be a nice option if you have a tolerant display which handles non-standard VGA signals as well.
Anyway, many thanks to the developer who is still working on it! :cheers:
Gryzor
Gryzorator
Gryzorator
Postby Gryzor » Thu Oct 19, 2017 8:00 am
Ι think I'm plugging in my MiST this weekend for some much-needed love...
If only there was a MegaDrive core... :D
Reality is that, which, when you stop believing in it, doesn't go away. --P.K.Dick
http://gryzor.info
DrOG
Postby DrOG » Thu Oct 19, 2017 4:54 pm
Gryzor wrote:Ι think I'm plugging in my MiST this weekend for some much-needed love...
Actually we have a Sega Genesis/Megadrive core already:
https://github.com/mist-devel/mist-bina ... es/fpgagen
It's a beta version with some metastability issues, but most games work on it!
Gryzor
Gryzorator
Gryzorator
Postby Gryzor » Thu Oct 19, 2017 5:12 pm
WAT!!!
Please tell me it also does save states :D
Hope I'll try it this weekend thanks so much for the heads up!
http://gryzor.info
DrOG
Postby DrOG » Thu Oct 19, 2017 6:55 pm
WAT!!!
As far as I know it does not support save states, and has some graphic glitches also.
You can read more about the Genesis core in it's own topic:
viewtopic.php?f=115&t=31029
Gryzor
Gryzorator
Gryzorator
Postby Gryzor » Fri Oct 20, 2017 7:24 am
Cheers, just dropped by :)
http://gryzor.info
SuperBabyHix
Postby SuperBabyHix » Fri Oct 20, 2017 2:29 pm
Scandb50 works great, thanks so much for the update. I did notice that scanlines don't seem to work in that mode, but that's not a big deal.
DanyPPC
Postby DanyPPC » Fri Oct 20, 2017 3:57 pm
I confirm, thanks for this update.
SuperBabyHix wrote:Scandb50 works great, thanks so much for the update. I did notice that scanlines don't seem to work in that mode, but that's not a big deal.
vebxenon
Postby vebxenon » Wed Oct 25, 2017 5:26 am
MiST Board need more community members like Freemac, supporting MiST instead of elitist forks.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Postby Sorgelig » Wed Oct 25, 2017 7:15 am
vebxenon wrote:instead of elitist forks.
and less jerks with chicken memory.
ericgus
Postby ericgus » Thu Oct 26, 2017 5:18 am
vebxenon wrote:MiST Board need more community members like Freemac, supporting MiST instead of elitist forks.
It is sort of unfortunate that it has distracted the MiST developer community .. Glad to see Freemac still doing great work..
vebxenon
Postby vebxenon » Thu Oct 26, 2017 6:50 am
Oh, yes, great great work. Every little change makes this core better :).
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
