Postby exxos » Sun Nov 09, 2014 9:19 pm
TOS104 now working :)
I did a overlay of TOS206 on the right also
Postby Cyprian » Sun Nov 09, 2014 11:33 pm
AtariZoll wrote:So, you expect that blitter chip can work stable at 16 MHz ? I guess that some may, like it is case with FDC (WD1772) chip, but likely most will be not able.
In case of 16 MHz mod, blitter works faster from simple reason: there is less time for wait that CPU finishes his "turn" :D
So, blitter can work 67% time instead 50%. In HOG mode there would be no speed boost.
actually, I think that assumption isn't correct.
In nonHog mode the blitter doesn't counts its internal cycles before it does next blitting pass, but it counts the memory bus accesses used by the CPU. The blitter takes control over the bus when the CPU do 64th memory bus access.
Therefore, whether blitter works on 16MHz or 8MHz it needs to wait 256 cycles (8Mhz CPU ) because of 64 * 4 cycles ST RAM access.
Frank B
Postby Frank B » Mon Nov 10, 2014 12:22 am
Do you have a test case for this? It would be good to clear it up.
Postby exxos » Mon Nov 10, 2014 11:04 pm
As a small progress update..
I have found we need to add more code to the GALs to allow blitter operation. The problem being the blitter has access to the CPU and TOS which may or may not be running at 16mhz. Then the blitter has access to RAM which needs 8mhz. Problem being there is a mash up of speeds which need sorting out.
This shouldn't be to hard since all we need to do is make sure the CPU is running at 8mhz when the blitter has control of the bus. While that probably doesn't make sense, the CPU clock is linked to the blitter clock, while that may not make sense either, the blitter cannot run on 8mhz because the CPU and TOS run at 16mhz, so its a mismatch in speeds which ever way you look at it.
Once we get the CPU and blitter operating at 8mhz, We will program in that the blitter can run at 16mhz when talking to the CPU or TOS only. If the blitter requests control of the bus, then we will have to assume its talking to RAM and switch it to 8mhz.
It might be easier to run separate clocks for the blitter and CPU, but unfortunately we do not have any more free pins on the frequency control GAL. In anycase, the blitter can talk to the CPU and TOS at higher speeds. Though I don't know if the blitter does anything like shifting data around its internal registers ? As when the blitter hasn't got control of the bus, it could be clocked at 16mhz or 8mhz. Of course there is no point clocking it at 16mhz if its not actually doing anything internally...
qq1975b
Postby qq1975b » Tue Nov 11, 2014 7:31 am
:thumbs:
CPU&blitter at 16MHZ looks like a great improvement. It is a pity the ST Ram bottleneck. Why did they solved this on the Mega STe? adding the cache?
And would it be necessary a specific test program to see it it is reliable and stable? or are those expected 16MHZ operations few and it won't get hot/freezed in any case?
Trying to learn...
Postby exxos » Tue Nov 11, 2014 8:43 am
qq1975b wrote::thumbs:
I think speed boost was the cache on the mega, i never had one of those machines anyway..
16mhz uses 16mhz CPU and 16mhz capable TOS so nothing is overclocked there. Blitter will be, but i doubt it will be running 16mhz constantly, so while it may get a little warmer, it shouldn't be a problem.
Like the WD1772, OK totally different chip, but that overclocked to 16mhz. Though I found a lot of upgrades ran it at 16mhz as the basic frequency, so it was running 16mhz when no floppy access. So it just got hot doing nothing. My kit only ran 16mhz when HD floppy was accessed, so everyone variation of 1772 would work at 16mhz, but the "norm" is you need a 02-02 or AJAX , but its not true. Of course blitter needs to be tested at high speeds for reliability, if it does not work, we will leave it at stock speed. Or offer 2 variations of GAL code for people to try faster blitter..
qq1975b
Postby qq1975b » Wed Nov 12, 2014 10:59 am
I will run the test on a MGSTE...with and without blitter and at 8&16MHZ. I think it is not possible to disable the cache...
Just to have a reference and for curiosity.
Trying to learn...
Postby AtariZoll » Wed Nov 12, 2014 8:15 pm
I was talking about case when CPU is clocked to 16 MHz. As may see from "there is less time for wait that CPU finishes his "turn" " .
Postby AtariZoll » Wed Nov 12, 2014 8:27 pm
exxos wrote:I think speed boost was the cache on the mega, i never had one of those machines anyway..
16mhz uses 16mhz CPU and 16mhz capable TOS so nothing is overclocked there. Blitter will be, but i doubt it will be running 16mhz constantly, so while it may get a little warmer, it shouldn't be a problem. ...
16 KB cache is pretty much for Atari ST SW, so may give pretty big speed up. But not when huge RAM areas need to move, because RAM access time is still same as by 8 MHz ST(E) . It is well visible in scroll tests, when is faster only some 12%.
Actually, all TOS versions can work on faster clock. TOS 2.06 is not designed specially for 16 MHz. It just works fine at. But same is with TOS 1.04, etc.
TOS 2.06 has support for 68010 CPU, Fast RAM, IDE hard disks. + Desktop is much improved.
Considering blitter at 16 MHz: I would not expect some bigger speed-up from simple reason: it must go back to 8 MHz when accessing RAM. And because way how it works - almost all time accessing RAM, and % of internal cycles is very low, speed up will be very small.
Example: IDE hard disk access with blitter is faster some 15-20% than via CPU.
With CPU we have: move.l (a0),(a1)+ - where 4 T goes for opcode fetch, then 4+4+4+4 for read, write . So, 1/5 of time is wasted on opcode fetch.
By blitter all cycles do RAM access, so will transfer 4 bytes in 16 cycles instead 20 .
16 MHz blitter may be faster with Fast RAM, but that seems not much useful, as it can not hold screen.
mc6809e
Postby mc6809e » Wed Nov 12, 2014 8:29 pm
The mistake is believing that the blitter always gets 50% of the time in shared mode. The 50% figure is an upper bound only reached when the processor is touching main memory every 500 ns.*
Of course a faster processor running out of standard memory is more likely to trigger a restart of the blitter while cache and non-mmu controlled memory will tend to idle the blitter for longer periods of time.
*Excepting the case where the CPU is made to manually restart the blitter, of course.
Postby exxos » Wed Nov 12, 2014 10:02 pm
AtariZoll wrote:Considering blitter at 16 MHz: I would not expect some bigger speed-up from simple reason: it must go back to 8 MHz when accessing RAM. And because way how it works - almost all time accessing RAM, and % of internal cycles is very low, speed up will be very small.
I am still working on the blitter, but I found it needs its own clock, so I am talking to rodolphe about adding another GAL to control blitter clock. Problem is, when blitter have control of the bus, the CPU is going to 8mhz with the blitter, so the CPU is getting slowed down when it should be running at 16mhz. At current tests, machine actually run slower with blitter enabled, because it is slowing CPU. But blitter does show 1% speed gain so it is doing something good, this is nothing really, but results are tainted by CPU running slower.
The current results are this, but the blitter does seem capable of 16mhz operation. of course it has to slow to 8mhz for RAM access, but so does CPU. We may get 10% speed boost on blitter when work is completed..
qq1975b
Postby qq1975b » Wed Nov 12, 2014 10:53 pm
If it can be useful, I am testing a MSTE with QINDEX. I can post results tomorrow morning for 8-16mhz w/wo blitter and w/wo cache.
Trying to learn...
Frank B
Postby Frank B » Thu Nov 13, 2014 3:56 am
I'm not convinced the cpu needs to be hitting memory to use up its bus cycles. I think this needs to be tested
qq1975b
Postby qq1975b » Thu Nov 13, 2014 10:31 am
Here are the results on a MGSTE. There are some strange...like 16Mhz No Blitter Yes cache vs 16MHZ Yes Blitter Yes Cache...
8MHz No Blitter No Cache:
8MHz Yes Blitter No Cache:
16MHz No Blitter No Cache:
16MHz No Blitter Yes Cache:
16MHz Yes Blitter No Cache:
16MHz Yes Blitter Yes Cache:
Trying to learn...
Postby exxos » Thu Nov 13, 2014 11:55 am
Looks like the cache is boosting RAM speed, which is to be expected. It boosts it a fair bit which is good really.
mc6809e
Postby mc6809e » Thu Nov 13, 2014 1:18 pm
Frank B wrote:I'm not convinced the cpu needs to be hitting memory to use up its bus cycles. I think this needs to be tested
Counting CPU read/writes does seem to be unnecessarily complicated. A simple internal counter should be enough.
Hmm. Maybe you're right:
(From http://paradox.atari.org/files/BLIT_FAQ.TXT)
    ? Tried but it still seems corrupted, especially the interrupt services
      are getting out of sync very often.
    ! Please note that in BLiT mode, the BLiTTER will always arbitrate for
      the bus after 64 cycles of idle time, no matter what the CPU is doing.
      It will interfere with the interrupt service routines. If the timing
      of the interrupt service routines is critical, the BLiTTER should only
      be used with great care and in HOG mode where appropriate.
Postby Cyprian » Thu Nov 13, 2014 1:56 pm
In that point Paradox are wrong. If I remember correctly in STE split isn't 64/64 CPU bus cycles but 65/64 and 66/64 in case of MSTE and actually depends on CPU bus usage. I'll later provide test case.
Postby exxos » Thu Nov 13, 2014 5:00 pm
I did some more testing with the blitter. It seems when running at 8mhz, it actually runs faster overall by about 4% or so, as opposed to 16mhz.
Below are the results.
Blitter is allowed to run 16mhz only during TOS access, and when blitter does not have control of the bus. This way if blitter does internal operations, it is allowed to run at 16mhz.
When blitter otherwise has control of the bus, IE acess to RAM, it runs at 8mhz.
Overall the results do not make sense. You would expect as blitter has some speed injection to run at 16mhz, that it would run faster. but it does not.
mc6809e
Postby mc6809e » Thu Nov 13, 2014 7:13 pm
exxos wrote:Blitter is allowed to run 16mhz only during TOS access, and when blitter does not have control of the bus. This way if blitter does internal operations, it is allowed to run at 16mhz.
Maybe the problem is that internal operations are occurring between two standard 68K bus cycles, so while the internal operation itself takes half the time, the blitter still has to wait for the next available bus cycle to continue which nullifies the speedup.
Below, 'S'=shifter data, 'B'=blitter data, H=halftone access, 's'=shifter address, 'b'=blitter address, 'w'=added wait.
Standard accesses and interleaving of bus cycles:
--SSBBSSHHSSBBSSBBSSHHSSBBSS--
ss--ss--ss--ss--ss--ss--ss--
--bb------bb--bb------bb--
Sped up blitter:
--SSBBSSH-SSBBSSBBSSH-SSBBSS--
--bb-----bbw--bb-----bbw--
Postby exxos » Thu Nov 13, 2014 7:17 pm
That's the odd thing though, the CPU is mostly running faster anyway, so the next cycle should be faster for the blitter.
qq1975b
Postby qq1975b » Thu Nov 13, 2014 7:20 pm
exxos wrote:I did some more testing with the blitter. It seems when running at 8mhz, it actually runs faster overall by about 4% or so, as opposed to 16mhz.
On a MSTE, Blitter speeds up a little the machin in 16MHZ over 8MHZ as you can see on my earlier post (no cache activated...with cache the results are little strange because blitter seems to slow down the machine).
Trying to learn...
Postby exxos » Thu Nov 13, 2014 7:34 pm
The results are confusing overall really. As Gembench has the option to compare a machine with and without blitter. Thing is, when running the blitter, and ticking the blitter box, it takes away the blitter speeds gains, so the results which are left, should be the CPU & TOS running at 16mhz. But the results are around 50% less than I would have expected them to be.
For example, GEM Dialog Box: 151%, is without blitter. But with the blitter ON, and ticking the blitter box, the result is 135%. This does not make any sense to me. If the blitter gave 80% speed boost, then ticking the box will take away that 80% and you should be left with a stock machine again, but then the CPU and TOS boost should bring it back up to 151% again :? I can only think that the blitter while speeds up graphics, its taking away about 25% speed away from the cpu. While the CPU is normally accessing the bus, the blitter has taken over. So you loose the CPU speed gains in favour for blitter stuff.
I did fix the 4% loss problem just also :) It seems the CPU is still doing stuff like accessing TOS, while the blitter has control of the bus. This is pretty cool actually. I let the CPU access TOS at 16mhz while blitter has control of bus, and the 4% loss vanished. But overall, no speed gain for blitter at 16mhz :roll:
Postby exxos » Thu Nov 13, 2014 9:36 pm
Made some progress :)
Left is the results with the blitter ON, and right is without the blitter. Only a few % drop in speed now, so things are pretty close. I dare say that is probably normal as the blitter will steal some bus time.. but I am still checking...
So the total speed boost for the STFM with blitter is......
qq1975b
Postby qq1975b » Thu Nov 13, 2014 9:38 pm
On a MSTE the CPU gain at 16mhz (without cache) on this GEMBENCH test is 25% (125% against a ST 8mhz no blitter). In your test the result is 133%. In Display, only 9% (109%) without blitter and 135% (235%) with it.
With cache and blitter, the results are 264% on display and 197% on cpu.
Trying to learn...
Postby exxos » Thu Nov 13, 2014 9:47 pm
263% for display, so the current graphics power matches the MSTE then... Your CPU results will be faster because you have cache. 25% CPU gain without cache is lower than my figures now, as CPU is 133%, so assume yours is 125% with 16mhz no cache ?
