KryoFlux - Write what you want!
mr.vince
Postby mr.vince » Fri Oct 10, 2014 9:40 pm
It's been some time... and we said we'd make it happen one day. So without further ado... here it is:
KryoFlux v2.50 with write support for STREAM files. Just dump a disk and write it back. No analysation (which we still recommend) required.
Here is the changelog: http://forum.kryoflux.com/viewtopic.php?f=2&t=205&p=7946#p7946
If you have a KryoFlux, just go straight to the downloads: http://kryoflux.com/?page=download
Ports are being worked on.
If you don't have a KryoFlux... go figure. ;)
kodak80
Re: KryoFlux - Write what you want!
Postby kodak80 » Sat Oct 11, 2014 4:39 am
This is good news. Time to get my Kryoflux board out again and give this a test.
Atari STF Remake H4 | Atari Falcon 030 | Atari 1040 STE | Atari 1040 STFM | Atari 1040 STF | Kryoflux & Supercard Pro Flux boards | MiniCosmosEx
mr.vince
Postby mr.vince » Sat Oct 11, 2014 1:22 pm
Yes please, the future development of this feature depends on community feedback.
Postby DrCoolZic » Sat Oct 11, 2014 4:39 pm
Thanks excellent nesw and seems to work in many cases :)
mr.vince
Postby mr.vince » Sat Oct 11, 2014 5:26 pm
You know how to submit stream images - please send a few that do not work; if you already see in the GUI, that the index is off, or there is NFA... no need to supply those. ;)
Brume
Red eyes
Red eyes
Postby Brume » Sat Oct 11, 2014 8:29 pm
Very great news!
Thank you very much, I was waiting for this feature since the first day I heard about KF :cheers:
Time to roll up my sleeve... time finalize my old project... These new feature is really motivating!
mr.vince
Postby mr.vince » Sat Oct 18, 2014 4:24 pm
So, how's it going? ;)
kodak80
Postby kodak80 » Mon Oct 20, 2014 2:35 pm
Not sure if it is my floppy drives (I have tried a couple and both get the same error), but I regularly get the following error when writing back a stream Kryoflux capture to disk:
08.0 : Control command rejected by the device
Here are a couple of screen grabs for Marble Madness. The STX file created by AUFIT 0.2c from the Kryoflux stream capture works in Hitari.
Sometimes when I try the write again, it writes without the error but not for this one.
When I open the stream capture with AUFIT track 08.0 looks normal:
The testing so far works with non-protected disks but I have not managed to get any games to write back with a stream capture. I need to do some more testing though.
I am not an expert on the types of protections used on Atari disks so am not sure if my testing is of much use. I should add that I am using Windows 8.1 64 bit and was using the 64 bit DTC program.
The capture was done with the command:
DTC -fMarbleMadness -i0 -i2 -i4
I moved the RAW files into a folder called Marble and wrote back using:
DTC -fMarble\MarbleMadness -w
Hope this information is useful.
FYI DrCoolZic, AUFIT 0.4c doesn't seem to open Kryoflux RAW folders but 0.2c does. Again, not sure if this is because I'm running x64 Win8.1.
kodak80
Postby kodak80 » Mon Oct 20, 2014 2:44 pm
I have also converted the Marble Madness Stream files to a RAW file using the Kryoflux GUI and this works in Hitari as well.
Does the Kryoflux GUI support writing back to floppy?
IFW
Postby IFW » Mon Oct 20, 2014 8:55 pm
Can't see any image you posted...
It sounds like there is a problem with the drive or connection.
Could you post on the official KF forum please?
IFW
Postby IFW » Mon Oct 20, 2014 8:59 pm
kodak80 wrote:I have also converted the Marble Madness Stream files to a RAW file using the Kryoflux GUI and this works in Hitari as well.
There is a separate GUI program for writing:
http://forum.kryoflux.com/viewtopic.php?f=2&t=569
kodak80
Postby kodak80 » Wed Oct 22, 2014 10:34 am
I have had success in writing back the streams for the following Atari ST game disks:
Hisoft 1st Basic https://www.dropbox.com/s/so25886u7i2v2h5/HiSoft%201st%20Basic.7z?dl=0
Mega Lo Mania Disk 1 https://www.dropbox.com/s/rumle8flkuffccl/MegaLoMania-D1.7z?dl=0
Mega Lo Mania Disk 2 https://www.dropbox.com/s/qgy58n1w1q5y572/MegaLoMania-D2.7z?dl=0
TRIAD Volume3 Complication - Blood Money Disk 1 https://www.dropbox.com/s/pp4cvd4ilktea2w/TRIAD3-BloodMoney-D1.7z?dl=0
TRIAD Volume3 Complication - Blood Money Disk 2 https://www.dropbox.com/s/veo3aju7a04d1rw/TRIAD3-BloodMoney-D2.7z?dl=0
The following games work when the stream is converted to CT Raw and loads in Hitari but they do not work when the stream is written back to floppy disks:
Marble Madness https://www.dropbox.com/s/vgnoishrg0h5ji1/MarbleMadness.7z?dl=0
James Pond 2 Codename Robocod https://www.dropbox.com/s/ribf6qdmjddtjuj/JamesPond2CodenameRobocod.7z?dl=0
Hope this helps.
IFW
Postby IFW » Wed Oct 22, 2014 10:43 am
So the connection/drive (?) issue has been resolved?
What was the cause?
IFW
Postby IFW » Wed Oct 22, 2014 11:29 am
Can't see any reason, so it would be useful to dump the disks written if there is any problem.
kodak80
Postby kodak80 » Wed Oct 22, 2014 11:32 am
IFW wrote:So the connection/drive (?) issue has been resolved?
What was the cause?
I used the wildewutz GUI and set the option for stepping to neutral. This helped.
kodak80
Postby kodak80 » Wed Oct 22, 2014 1:12 pm
I managed to get Marble Madness working. Just wrote the stream back to floppy and it worked this time.
Still having issues with James Pond 2. The stream from the disk I created is here and looks messy compared to the original stream I captured:
https://www.dropbox.com/s/qnwfmpxwv3qe7 ... ng.7z?dl=0
It's getting late here so I will try another floppy disk tomorrow in case it is the disk that is the problem.
IFW
Postby IFW » Wed Oct 22, 2014 2:03 pm
What was the cause?
Well, that's the default selected by DTC, so chances are it was something else... anyway, glad that it works for you now :)
IFW
Postby IFW » Wed Oct 22, 2014 2:09 pm
kodak80 wrote:I managed to get Marble Madness working. Just wrote the stream back to floppy and it worked this time.
Disk is identical to the original and is error free, just checked with our analyser.
If you convert it to CTR it runs in Hatari as well, you just have to wait a bit during loading probably for decryption and/or decruncher.
Maybe clean the drive in your ST used for testing?
kodak80
Postby kodak80 » Wed Oct 22, 2014 9:24 pm
It hadn't occured to me to clean the ST's drive. Will do this. Have already cleaned the drives used for capturing the streams.
Postby DrCoolZic » Fri Oct 24, 2014 7:26 am
One thing I have noticed is that for me it becomes difficult to find floppies I can write on reliably (especially on PC). SCP provide a test to check floppies and in most of he cases the floppies (some just out of a box of unused diskettes) are just not writable correctly?
Even on ST floppies I can read and image without problem cant be written successfully?
So it would be nice that KF writer could perform a verify after writing?
IFW
Postby IFW » Fri Oct 24, 2014 12:13 pm
Yes, verify is planned - testing the disk is completely useless, since write result does not depend on the test result. Each attempt must be treated as an individual thing: you cannot say that just because a previous write of uniform cells succeeded a new one would - there are many contributing factors.
If you want to do something like that though, you could simply write an ADF file with verify enabled to a disk to see if it is good or not.
Much more reliable than just writing a simple empty pattern and the verification is real at the data level.
But in this case the disk written is actually good and the original sample is good as well, so the most likely weak spot is the drive in ST.
kodak80
Postby kodak80 » Sun Nov 23, 2014 9:45 am
Return to “Kryoflux”
