CosmosEx - updates
Jookie
Re: CosmosEx - updates
Postby Jookie » Thu Dec 29, 2016 11:28 am
Main app - 2016-12-29
- improved network hostname saving on Raspbian, also network settings saving
- CE_TSTHD has now more options to test hard drive interface, shows more stuff
- CE_DD.PRG has been refactored - by nanard
- install script added for ffmpeg, code merged for mp3 playback - by nanard
Hans - 2016-12-29
- timeout for reading to SD card extended from 0.5 second to 3 seconds
- added some commands, which are used by CE_TSTHD - for detecting SD card inserted, retrieving SD error count for reading and writing
Jookie
Postby Jookie » Tue Jan 03, 2017 4:11 am
Main app – 2017-01-03
- added setting core_freq=250 into /boot/config.txt – this fixes communication issues between RPi 3 and CE on Raspbian. After successful update leave the device on for a minute, turn it off, wait 5 seconds, turn it on, and run the CE_TSTHD.TOS – option ‘D’ or ‘C’ to check if the transfers are now OK.
- fix for bad compare sign in install_ffmpeg.sh script
Jookie
Postby Jookie » Wed Apr 26, 2017 8:16 am
Main app – 2017-04-13
- some fixes to CE STiNG – by nanard
- code refactoring (clean up, less polling, …) – by nanard
- fix / improvement for longer transfers than 1 MB
- extended key joystick functionality – see this for info: http://joo.kie.sk/?page_id=793 — by mikro
- toggle USB Keyboard exclusive access with RCTRL+RALT+LALT+LCTRL – by nanard
- disable auto login in console, disable ctrl+alt+delete restart of RPi
Hans – 2017-04-13
- support for longer transfers than 1 MB
Franz – 2017-04-13
- detection if RPi communicates, and if not, doing IKBD passthrough to ST instead of sending it to RPI
Return to “CosmosEx”
