Apple ][+ Core
slingshot
Re: Apple ][+ Core
Postby slingshot » Wed Jan 16, 2019 1:44 pm
rittwage wrote:That version is not what is in your GIT repo. The version in your GIT repo now is the old II+ core.
constant CONF_STR : string := "AppleII+;;S,NIB;O2,Monitor Type,Color,Monochrome;O3,Monitor Mode,Main,Alt;O4,Enable Scanlines,off,on;O5,Joysticks,Normal,Swapped;O6,Mockingboard S4,off,on;T7,Cold reset;";
Then we're in different universes :)
https://github.com/gyurco/apple2efpga/b ... op.vhd#L82
rittwage
Re: Apple ][+ Core
Postby rittwage » Wed Jan 16, 2019 1:47 pm
OK, I see what is wrong. I was pulling "mist-cores" and you have a new repo called apple2efpga. Sorry about that... I've got it now.
slingshot
Re: Apple ][+ Core
Postby slingshot » Wed Jan 16, 2019 2:14 pm
rittwage wrote:OK, I see what is wrong. I was pulling "mist-cores" and you have a new repo called apple2efpga. Sorry about that... I've got it now.
Ahh, no parallel universe then.
slingshot
Re: Apple ][+ Core
Postby slingshot » Sat Jan 19, 2019 8:38 pm
Meanwhile I found the issue with the LORES colors:
https://github.com/mist-devel/mist-bina ... 190119.rbf
rittwage
Re: Apple ][+ Core
Postby rittwage » Sat Jan 19, 2019 8:49 pm
slingshot wrote:Meanwhile I found the issue with the LORES colors:
That's great news- thanks for fixing. About the only other things it needs is support for switching to the older ROMs.
slingshot
Re: Apple ][+ Core
Postby slingshot » Sat Jan 19, 2019 8:59 pm
Yes, I'll add it, but only for the //e ROMS (unenhanced/enhanced). The ][+ ROM is 12K, it's missing 80 the column firmware, no point to support it (it would be alien for a //e anyway).
Overridable keyboard and video roms are more useful, I think.
DanyPPC
Re: Apple ][+ Core
Postby DanyPPC » Sat Jan 19, 2019 9:05 pm
Thanks Slingshot for this fix.
DrOG
Re: Apple ][+ Core
Postby DrOG » Sun Jan 20, 2019 12:06 pm
Thank you!!! This core is almost perfect!
Re: Apple ][+ Core
Postby Newsdee » Mon Jan 21, 2019 4:05 am
Regarding disk and write support, I remembered the CFFA 3000. It doesn't have schematics on the page, but has a logic file for the CPLD it uses. Also the page has some links of similar projecrs (e.g. IDE interface).
http://dreher.net/?s=projects/CFforAppl ... erials.php
Check also the 'logic' section for CPLD files.
May not help directly but could give some ideas.
slingshot
Re: Apple ][+ Core
Postby slingshot » Mon Jan 21, 2019 9:13 am
Newsdee wrote:Regarding disk and write support, I remembered the CFFA 3000. It doesn't have schematics on the page, but has a logic file for the CPLD it uses. Also the page has some links of similar projecrs (e.g. IDE interface).
Checked it, but it's for ATA interface. Is there any SD-Card one out there? (SD-Card emulation is already written for MiST, but no ATA so far).
Upd.: I found this SD-card interface: https://github.com/freitz85/AppleIISd
It's claimed it supports Pro-Dos. Maybe I'll try this. The only drawback the firmware requires the 65C02 CPU.
Re: Apple ][+ Core
Postby Newsdee » Mon Jan 21, 2019 6:26 pm
TBH I'm not sure how useful hard drive support is, versus making disks writeable. I have an original machine but I only ever used floppies and .dsk images (via CFFA 3000) with it. I believe hard drives were mostly used in business software, but I could be wrong.
