Cannot Config CosmosEx
DOB
Re: Cannot Config CosmosEx
Postby DOB » Wed Aug 13, 2014 7:41 am
Just got your posts Jookie,
I will check my TT tomorrow. But I do remember the TT detecting the CosmosEx and installing the driver. I will have to check to see if had driver can see it.
I'm not sure what a SCP client is. Is that like SSH?
Cheers,
dOb
Jookie
Postby Jookie » Wed Aug 13, 2014 7:48 am
DOB wrote:Just got your posts Jookie,
Well, I guess it won't work in this state even with the PrgFlags, ggn is looking at the issue as he has a TT and I don't...
DOB wrote:I'm not sure what a SCP client is. Is that like SSH?
SCP is a protocol and might also be a client, I'm using WinSCP, which looks like this: http://www.reed.edu/cis/help/software/images/winscp_interface.png
artik-wroc
Postby artik-wroc » Sat Aug 16, 2014 10:14 am
I noticed something. Maybe it doesn't matter.
My setup:
ID0 UltraSatan 1
ID1 UltraSatan 2
ID2 CosmosEx SD
ID3 CosmosEx translate
ID4 CosmosEx raw
CosmosEx found on ACSI ID: 3
CosmosEx SD card works fine,
but if ID0 and 1 is skipped, and driver is loaded from CosmosEx SD:
CosmosEx found on ACSI ID: 2
When I run the driver (CE_DD.PRG) manually from the desktop is the same. If driver is on UltraSatan or floppy, CosmosEx found on ACSI ID: 3, if driver starts from CosmosEX SD, CosmosEx found on ACSI ID: 2.
Jookie
Postby Jookie » Sun Aug 17, 2014 11:57 pm
DOB,
there's and update on the TT issues, and also a description how to update your device to get it working, here:
http://www.atari-forum.com/viewtopic.php?f=103&t=26842&p=256961#p256961
Please try that and report how it works for you...
DOB
Postby DOB » Mon Aug 18, 2014 11:54 pm
Hi Jookie,
I SSh'ed into the CosmosEx and updated it. Now I can access Drive O. After configuring, I can boot from my SD card!
Thank you so much.
Cheers,
dOb
Jookie
Postby Jookie » Wed Aug 20, 2014 8:00 am
DOB wrote:I SSh'ed into the CosmosEx and updated it. Now I can access Drive O. After configuring, I can boot from my SD card!
Thank you so much.
Finally some good news (after the avalanche of the bad news)... Anyway, thank ggn for those TT fixes, I couldn't do it myself...
DOB
Postby DOB » Sun Oct 12, 2014 12:02 am
Hi Jookie,
I am having problems updating to the newest version. Tried the ce_config.prg, but it can't find the cosmosEx. I don't have PRFLAGS.PRG to set the flags, do you have a copy you can send me?
I also tried to ssh into the cosmosEx, I run the update and then try to use ce_start.sh and this is what I get:
Starting cesuper.sh...
root@ce:/ce# restarting app
Possible command line args:
reset - reset Hans and Franz, release lines, quit
noreset - when starting, don't reset Hans and Franz
llx - set log level to x (default is 1, max is 3)
test - some default config for device testing
Log level: ERROR
app is running, sleeping
It keeps looping this.
Cheers,
dOb
Jookie
Postby Jookie » Mon Oct 13, 2014 10:33 am
DOB wrote:I am having problems updating to the newest version. Tried the ce_config.prg, but it can't find the cosmosEx. I don't have PRFLAGS.PRG to set the flags, do you have a copy you can send me?
One copy (from my DropBox) can be found here:
https://www.dropbox.com/s/ude2y2zwzqqfa ... S.PRG?dl=0
It was downloaded originally from here:
http://soziale-opposition.de/atari/PRGFLAGS.PRG
DOB wrote:I also tried to ssh into the cosmosEx, I run the update and then try to use ce_start.sh and this is what I get:
This is the correct behavior - the supervisor script is watching if the app (Main App) is running, and if it is, it tries that again after a while. But this is OK. Try that PRGFLAGS, check your ACSI cable, and report how it goes.
Return to “CosmosEx”
