Issues known with CTR files
Re: Issues known with CTR files
Postby Steven Seagal » Mon May 19, 2014 7:44 pm
Thx for those explanations, I see the problem now.
If i just don't unlock the tracks, the game loads, maybe it's simpler so. So capsimg dll and not Steem is housekeeping the random seeds and it will unlock all the tracks at once I guess, best of two worlds.
Mercifully the loader is very slow, as the chiptunes and the title screen are the best aspects of this game.
npomarede
Postby npomarede » Mon May 19, 2014 8:31 pm
I use CAPSLockImageMemory in Hatari to load the whole IPF/CTR in one go, and never had any problem with this.
Memory print will not be that high (for IPF, it's often less than STX where tracks and sectors are all dumped), and as IFW told, you get seamless access in case a game needs to load a lot of tracks for realtime audio/video and your PC doesn't respond fast enough.
Postby DrCoolZic » Thu Nov 06, 2014 6:04 pm
Quick question for IFW on CTR
With dtc it is possible to create ctr from raw stream but of course the reverse is not possible :(
Maartau
Re: Steem & CTR files
Postby Maartau » Thu Nov 06, 2014 6:29 pm
Mug UK wrote:Outrun also left the disassembly labels inside the main program in case you really want to go sniffing around and see what's happening in their protection code :)
Have you that version with labels inside MUG ? :cheers:
IFW
Postby IFW » Fri Nov 07, 2014 1:51 pm
DrCoolZic wrote:Quick question for IFW on CTR
There is no guarantee on how the CTR file was made in the first place, so while this is possible, it's not supported.
Postby DrCoolZic » Fri Nov 07, 2014 1:59 pm
ctr is device independent? so would not be possible to get back to device dependent format like draft?
IFW
Postby IFW » Fri Nov 07, 2014 6:02 pm
I wouldn't want to convert JPG to PNG ;)
Return to “Kryoflux”
