MiST core and firmware changelog
slingshot
Re: MiST core and firmware changelog
Postby slingshot » Thu Jan 10, 2019 10:57 pm
firmware_190110
- Don't hardcode settings for Vid:0079, Pid:0011 controllers
- Safety checks for mounted file reads/writes
jotego
Postby jotego » Fri Mar 01, 2019 10:01 pm
I will be releasing the 1943 new arcade core by the end of March. This is another vertical shooter. I would like to request a firmware feature added:
Support for vertical OSD menu, on vertical games.
Maybe we can enable it with a letter in the config screen. Apart from 1942 and 1943, I will also release soon Commando, Gun Smoke, Avengers... all of these are vertical games.
I know that the obvious is to ask for me to rotate the game screen. It's not trivial. I don't have enough RAM to do it in the FPGA and the SDRAM driver cannot handle that right now. Plus, it adds one frame lag, which is not nice.
Please firmware developers, consider it.
My Patreon page here.
slingshot
Postby slingshot » Sat Mar 02, 2019 1:40 pm
jotego wrote:I will be releasing the 1943 new arcade core by the end of March. This is another vertical shooter. I would like to request a firmware feature added:
It's a good idea, I already thought about it some weeks ago. But never touched the OSD code, will investigate the possibilities. The best would be to render directly rotated, post-rotating can have RAM issues in the ARM firmware, too.
Gehstock
Postby Gehstock » Sun Mar 03, 2019 2:15 am
:D
jotego
Postby jotego » Sun Mar 03, 2019 10:19 am
I have merged your new OSD code (not firmware but verilog) and it works like a charm. I will be releasing the new binaries for 1942 with rotated OSD later.
slingshot
Postby slingshot » Sun Mar 03, 2019 10:40 am
Looked into the OSD code I realized that the FPGA already has the whole OSD in BRAM, and rotating is just a matter of how to display it. Looking foward to 1943!
Gehstock
Postby Gehstock » Sun Mar 03, 2019 1:44 pm
Nice Work :cheers:
slingshot
Postby slingshot » Sun Mar 03, 2019 4:49 pm
Gehstock wrote:Nice Work :cheers:
Nice :)
slingshot
Postby slingshot » Sun Mar 03, 2019 4:50 pm
firmware_190303
- Ini option to upload custom rom files
- Read/write FDC and CMOS RAM upload for Archimedes
Higgy
Postby Higgy » Sun Mar 24, 2019 3:16 pm
I'm I correct that there is a new Firmware to fix the MINIMIG issues introduced with Firmware 190303 but a complied version has not yet been released?
Discussion on Firmware changes here:
http://www.atari-forum.com/viewtopic.php?f=115&t=34865&start=50
retrofun
Postby retrofun » Sun Mar 24, 2019 4:56 pm
A new compiled firmware is available in a pull request (see your linked thread) but this wasn't merged into the mist-binaries repo.
Maybe the firmware maintainers take care of the 3 new pull requests I created on Friday... :wink:
slingshot
Postby slingshot » Sun Mar 24, 2019 7:08 pm
retrofun wrote:A new compiled firmware is available in a pull request (see your linked thread) but this wasn't merged into the mist-binaries repo.
As the phrase of "active maintanerS" is bit funny, but I'll look at them soon.
DrOG
Postby DrOG » Mon Mar 25, 2019 4:55 am
slingshot wrote:As the phrase of "active maintanerS" is bit funny, but I'll look at them soon.
Thanks in advance! :cheers:
Higgy
Postby Higgy » Mon Apr 15, 2019 7:51 am
I am not too familiar with what 'pull requests' are, so was firmware_190303 re-compiled & uploaded or is there still a new version waiting in the wings? (to solve the Minimig config issues).
thecaver99
Postby thecaver99 » Mon Apr 15, 2019 3:39 pm
is there any work going on for joypads as I have one that mapper under mapper but the A button doesn't get recognised.
I can supply any info required.
slingshot
Postby slingshot » Tue Apr 16, 2019 9:32 am
All my 2 USB joysticks are fine, so I don't know what to work on. Is your A button recognized on the input test in the OSD? (And please don't start three threads for one question).
thecaver99
Postby thecaver99 » Tue Apr 16, 2019 5:11 pm
slingshot wrote:All my 2 USB joysticks are fine, so I don't know what to work on. Is your A button recognized on the input test in the OSD? (And please don't start three threads for one question).
No its not recognised on the input test with or with out the ini file, apologies I wasn't starting a second thread I was just posting it in here as a bug report, was unsure where to put the info to add reports.
and the other thread was a duplicate post that I edited and removed as when I submitted the post it didn't look like it has gone through.
slingshot
Postby slingshot » Thu Apr 18, 2019 6:36 pm
firmware_190418
- Update current joystick status in OSD USB status screen
- Debounce virtual joystick keyboard with more than one USB joystick
- Add Speedlink SL-650212 Competition Pro Extra USB to known devices
- IKBD keyboard mouse emulation and pause/unpause fix
- New ini option: joystick_emu_fixed_index
- Buffer addressing fix and max. line length increase to 90 in ini_parser
Gehstock
Postby Gehstock » Thu Apr 18, 2019 11:00 pm
Thanks for your Work on the Firmware
DrOG
Postby DrOG » Fri Apr 19, 2019 4:37 am
THX! :cheers:
Lroby74
Postby Lroby74 » Thu May 16, 2019 8:42 am
In some lastest cores (C64, C16, Amiga) port 2 joystick test is not working anymore,
when i go on that choice, OSD closes automatically.
In other cores it works fine (so i think that it's not a firmware issue but cores bug)
slingshot
Postby slingshot » Fri May 17, 2019 6:27 am
Ah, it was a stupid firmware bug. I wonder why I did what I did there...
firmware_190517
- Fix Amiga CD32 pad configuration
- Fix Joystick 2 test OSD screen
brunosilva
Postby brunosilva » Fri May 17, 2019 12:01 pm
hi
not possible to add zip compression like mister? :)
or at least _folders to organize cores in menu? :)
Lroby74
Postby Lroby74 » Fri May 17, 2019 12:21 pm
slingshot wrote:Ah, it was a stupid firmware bug. I wonder why I did what I did there...
firmware_190517
Thank you!
slingshot
Postby slingshot » Fri May 17, 2019 12:29 pm
brunosilva wrote:hi
In a 64K microcontroller?
Good luck for that :)
How should it work?
