EasyAraMint : a modern OS for Aranym
Faucon2001
Re: EasyAraMint : a modern OS for Aranym
Postby Faucon2001 » Sun Apr 24, 2016 2:23 pm
Rudis, you are right the console is defined into etc/ttytab, but I have modified the boot script in order to be able to switch automatically from Xaaes to MyAES and also deal with different versions of Mint. This script autogenerates etc/ttytab at boot.
If you want to deactivate this feature: modify etc/rc.d/rc
Comment out everything between #Set AES Path until Echo "AES path..." almost at the end of the rc script
Modify etc/ttytab as you want.
Reboot and you should be ok
Philippe
Marakatti
Postby Marakatti » Sun Apr 24, 2016 7:06 pm
Awesome looking project! I'm already dreaming that one day Hatari could be integrated to this system to have ST and Falcon030 compatibility :ehum:
Must try this new USB version on my iMac next week. Keep up the great work!
Playmobil
Postby Playmobil » Mon Apr 25, 2016 11:20 am
Thanks Philippe ! I will try that !
highway
Postby highway » Mon Apr 25, 2016 2:10 pm
Hello
I'm doing additionnal tests according to our discussions :)
I'll post the solution here... when we'll find it !
Faucon2001
Postby Faucon2001 » Mon Apr 25, 2016 4:51 pm
Marakatti wrote:Awesome looking project! I'm already dreaming that one day Hatari could be integrated to this system to have ST and Falcon030 compatibility :ehum:
Thanks Marakatti, that's the idea down the road and my setup is like that at home. I just want to be sure that everything is booting well on various PC before releasing a more complex setup.
Philippe
Faucon2001
Postby Faucon2001 » Tue Apr 26, 2016 3:19 am
I have opened a new thread for BeeKey : viewtopic.php?f=8&t=29835
Philippe
Lostboysix
Postby Lostboysix » Fri May 27, 2016 11:49 pm
Hi Philippe,
thank you very much for your awesome distribution and all your efforts!
Luckily I found EasyAraMint and was able to set up everything according to my needs.
Thanks to you it´s the first time I have NVDI running on Aranym and can use many of the apps I used to work with back in the days, together with new ones, which give everything a nice modern touch and feeling.
The only thing I still couldn´t figure out is connecting Aranym to my network.
I created a tap connection and called it "tap0"1.3
It has the fixed IP: 192.168.1.3
Standardgateway is: 192.168.1.1 (which is the IP of my router)
Subnetmask: 255.255.255.0
In the config-file are the following settings:
[ETH0]
Type = bridge
Tunnel = tap0
HostIP = 192.168.1.1
AtariIP = 192.168.1.4 (also tried it with 192.168.1.3)
Netmask = 255.255.255.0
But it doesn´t work. Netsurf can´t resolve any dns.
Do you have any hint for me?
I am also definitely checking out BeeKey btw. :=)
Please keep up the great work. You are making many users very happy!
Greetings from good old germany!
Lostboy
Lostboysix
Hi Philippe,
[ETH0]
Type = bridge
Tunnel = tap0
Lostboy
Playmobil
Postby Playmobil » Sat May 28, 2016 12:37 am
Sorry again & again &again for my english
Wich OS you use ?
Under windows some tips are needs before... Needs to make a gataway first.
Lostboysix
Postby Lostboysix » Sat May 28, 2016 12:45 am
I am using windows 8.1
Thank you very much for your help!
Postby wongck » Sat May 28, 2016 3:56 am
On the windows you need ICS - internet connection sharing.
Look at my website https://sites.google.com/site/probehous ... /using-ics
rather old and on the Atari part, instead of STING use MINTNet.
Lostboysix
Postby Lostboysix » Sat May 28, 2016 9:47 am
Does this also work, If you are using only wifi to connect to the modem? So only one network interface?
Thank you very much for the clarification.
Postby wongck » Sat May 28, 2016 9:58 am
Yes, you can share your single wireless as the ICS.
But there must be another network adapter in your wintel to use ICS.
This will be the Aranym software adapter.
Playmobil
Postby Playmobil » Sat May 28, 2016 11:15 am
Protos had make a how-to for sharing connection here : viewtopic.php?p=227166#p227166
And more detailled but in french here : http://www.yaronet.com/topics/154795-fi ... nym#post-5
Postby shoggoth » Sat Jun 11, 2016 5:32 pm
0.5 gig, that's a fairly big file. Perhaps it would make sense to distribute this as a torrent as well?
DavidS
Postby DavidS » Fri Sep 16, 2016 1:48 am
Very nice work. Networking gave me a bit of a headache with Aranym though once that gets sorted (giving another try today) EasyAraMint will become my primary Operating Environment. I am giving the networking setup another try today, on a Raspberry Pi 3B running Raspbian (BeePi I could not get to do anything close to attempting to connect).
Thank you for your effort.
DavidS
Postby DavidS » Fri Sep 16, 2016 2:53 pm
Ok I still can not get networking going :( .
Any help would be appriceated.
Playmobil
Postby Playmobil » Fri Sep 16, 2016 3:36 pm
You need to edit the file "host in E:/etc" something like that...
Try contact Faucon2001, it's a cool guy, and give you the solution...
For me, under Windows7, networking works fine...
Faucon2001
Postby Faucon2001 » Fri Sep 16, 2016 10:20 pm
Humm, I will need more information ; are you on a X86, OSX, Win7, Linux, or a Raspberry Pi3, are you talking of EasyAraMint or BeePi?
Have you seen the instructions on my website?
Beekey, BeePi connects automatically to any network, and needs by default 2 contiguous free addresses : the Host IP 192.168.1.50 and Atari IP 192.168.1.51. Should these addresses be already in use on your network, open Aranym Emulation Setup with 'Alt+F12', select 'Networking', change 'Host and Atari IP', Apply, Save Config file and Cold reboot
Your PC/Raspberry MUST be connected to an Ethernet Cable, Wifi is not supported out of the box. Afterward you can setup the wifi, my Rapi 3 runs with wifi like a charm.
Follow the same logic for new addresses : 192.168.1.10 and 192.168.1.11 for example. These 2 addresses must be, available on your network, contiguous and not directly surrounded by others.
For EasyAraMint, internet bridge works only with DEBIAN distrib. If you use another distrib, please refer to Aranym wiki. If you strictly follow the instructions, it will work. To change the ip addresses, you'll need to modify aranym config file and the script of the bridge.
Have you changed in the bridge script the permissions with your user login?
In general,aranym works better with root privileges.
On a Raspberry Pi3, network under aranym is slow and internet not usable. Good enough for ftp, SMB, mails. You need a PC for that.
Cheers,
Philippe
DavidS
Postby DavidS » Sat Sep 17, 2016 1:18 am
Faucon2001 wrote:Hi,
Cheers,
Raspberry Pi 3B, running Rasbpian (Debian ARM for the Raspberry Pi), also tried with BeePi, on a RPi 2B and RPi 3B. I use only a cable connection, I do have 192.168.1.50 and 192.168.1.51 available on the local network.
Followed all provided instructions in both cases with complete failiar. To make sure my router is not the issue I set my RISC OS up to a static IP of 192.168.1.50 it worked with out problem, did same for testing 192.168.1.51. Still fails with both BeePi and EasyAraMint+Raspbian+Aranym.
DavidS
Postby DavidS » Sat Sep 17, 2016 1:19 am
Cheers,
Faucon2001
Postby Faucon2001 » Sat Sep 17, 2016 6:30 pm
DavidS wrote:Raspberry Pi 3B, running Rasbpian (Debian ARM for the Raspberry Pi), also tried with BeePi, on a RPi 2B and RPi 3B. I use only a cable connection, I do have 192.168.1.50 and 192.168.1.51 available on the local network.
Good. Network connection with Aranym can be tricky, but generally on DEBIAN works well with a simple tuntap bridge.
Aranym Wiki is fairly detailed on it : http://wiki.aranym.org/manual#networking
Beepi is build on MINIBAN ; the linux side negotiates IP with DHCP, in rc.local the bridge is setup to host_ip and atari_ip (defined in aranym "config" file) and owned by root, finally the script to start Aranym is launched.I have been using these scripts for the past 5 years on various DEBIAN distrib, and it has been working for many others too, so I am confident that we will find a solution.
Can you please check on your router that you have reserved part of your addresses for static IP and others for DHCP? On mine 192.168.1.0 to 192.168.1.64 is for static IP, above for DHCP. As a result : linux side IP could be anything above 192.168.1.65, host_ip is 192.168.1.50, atari_ip is 192.168.1.51
Can you please test the following ?
Boot on Beepi. Once on the desktop, Right Click, Shutdown, Cold boot. I have noticed, sometime, that the linux network setup could be timed out ; if a reboot solves your issue, you may need to delay the bridge setup script.
After second boot :
Linux side IP can be found in home/Documents/host_ip.
Right click on the desktop, Start Shell : check ifconfig and route
SSH the linux side with : ssh root@beepi (to do it from another machine use host_ip address instead of beepi)
Check ifconfig and route
ping various address to check
Mine is looking like that :
If you can ping only from the linux side, the bridge may be the issue, if you can ping from the atari side, may be the DNS is the culprit ( I set it to google DNS). If you want to have a look at the scripts, there are stored in /home/.system (activate Show Hidden Files on TeraDesk).
Philippe
Playmobil
Postby Playmobil » Sat Sep 17, 2016 10:31 pm
I always say Faucon2001 is a cool guys !
Youpi !
DavidS
Postby DavidS » Sat Sep 17, 2016 11:47 pm
Did, and yes the static range includes 192.168.1.51 and 192.168.1.50 (DHCP for 192.168.1.5 through 192.168.1.25, static for 192.168.1.26 through 192.168.1.127).
After second boot :
I will do later, need to write out to another SD Card. My Raspberry Pi 3B is my main computer, so can not just switch over to a different computer while testing.
Though not through SSH, I always dissable SSH, I use my computers at the local terminal, not remote.
sashapont
Postby sashapont » Wed Jul 05, 2017 1:11 pm
I downloaded Easymint 1.18 Tos 4.04 install image for Aranym, tos is load^ but mint is not start& How I can fix that?
Atari Falcon, Firebee
