STOS BASIC CURRENT NEWS & INFORMATION 2015
Re: STOS BASIC CURRENT NEWS & INFORMATION 2015
Postby Eero Tamminen » Tue Feb 03, 2015 8:24 pm
exxos wrote:Yeah, though STOS Hatari never runs anything I try to run on it. I have been trying the Falcon STOS examples, they mostly work in steem, though when it comes to DSP stuff, like playing audio, It has to be done on Hatari. Though on there, it just plays audio for a second then crashes with bus error :roll: I don't think I have ever got anything to run in Hatari for that matter. Stuff works a fraction better with TOS404 than EMUTOS, but still same result. So I doubt anyone would be doing anything STOS related unless they use a real Falcon.
Which version of Hatari you're using and can you point to a Falcon STOS program that doesn't work on Hatari?
Are you sure that stuff really works on real Falcon? I'm quite doubtful that something like that wouldn't work because of issues in Hatari 030 emulation... Have you e.g. tried running it from floppy image, or with different amounts of memory?
Postby exxos » Tue Feb 03, 2015 9:15 pm
Eero Tamminen wrote:Which version of Hatari you're using and can you point to a Falcon STOS program that doesn't work on Hatari?
Its the DSP tracker example in the STOS falcon pack I put on my site. It works on a real falcon (but not tried it for some years). The old extension used the CPU to play tracker mods, later extension version used the DSP. I think it played about 3 seconds of the music then crashed. but im not sure if it sounds right, sounds like the speed is varying in the music as its playing.
Postby exxos » Tue Feb 03, 2015 9:21 pm
I turned off all the options, and it sounded properly, it played for a few more seconds with "24 bit addressing" turn off, but still crashed.
darkhog
Postby darkhog » Tue Jan 12, 2016 12:09 pm
Any chances for image files that will work with Hatari emulator? Would like to play around with it and I can't afford actual hw.
Postby exxos » Tue Jan 12, 2016 12:49 pm
darkhog wrote:Any chances for image files that will work with Hatari emulator? Would like to play around with it and I can't afford actual hw.
You don't need image files, just create a hard drive folder and copy the files into that. Though I would suggest you use steem emulator instead of Hatari.
darkhog
Postby darkhog » Tue Jan 12, 2016 1:14 pm
Is it better? May try it then, thank you. It's just that Hatari was the first result I got when googling for Atari ST emulator.
Postby exxos » Tue Jan 12, 2016 1:34 pm
darkhog wrote:Is it better? May try it then, thank you. It's just that Hatari was the first result I got when googling for Atari ST emulator.
Better for STOS yes. If you read up some posts I had issues with Hatari and STOS, with just about everything so gave up with it. Steem will work better with STOS and I don't have any issues with it.
http://ataristeven.exxoshost.co.uk/
darkhog
Postby darkhog » Tue Jan 12, 2016 1:52 pm
One last thing, So I've launched STOS on Steem and trying to follow manual's tutorial (that animals.mbk thing).
So I've copied accessories disk to HDD folder (along with STOS as you suggested), typed in STOS shell load "animals.mbk", it loaded, shows in listbanks, but when I do next part and write sprite 1,100,100,1 nothing happens.
I'm using STOS 3.0 and TOS 1.02 (UK), but same thing happens with 2.06. Probably my own stupidity, but I want to make some atari st stuff.
Postby exxos » Tue Jan 12, 2016 2:09 pm
You are probably in mode 1 which doesn't display sprites, type in MODE 0 and try again.
If you need anymore help please open up a new topic in the STOS section as this thread is for STOS news not a general help topic :)
darkhog
Postby darkhog » Tue Jan 12, 2016 4:56 pm
OK.
Lando_C
Postby Lando_C » Sun Mar 18, 2018 10:15 pm
Hm. The 2014 pack from http://www.exxoshost.co.uk/atari/STOSFLOPPY/index.htm won't run on a mega ST 4 with tos 1.02.. is this a known issue with a too old tos?
UK 1040 STF, SE kbd, SE tos 1.04, gotekHxC+floppy B internally, ATX psu on the side
DE Mega 1
SE Mega 2, no keyboard
SE Mega ST 4
Megafile 20 with 2 MFM drive mechanisms (80+20 meg) in hacked case, ATX psu on the side
Megafile 30
Megafile 60
SH 204
SM124, SM125, Samsung SyncMaster 930mp 19 inch 4:3 lcd tv rgbscart and VGA for STHIgh
PC Intel i5 8G ram many disks
5xRaspberry pi
ozy2000
Postby ozy2000 » Sun Oct 27, 2019 7:24 am
I want to thank Exxos, Petari and anybody else who made this great site.
My dream has always been to program Gauntlet properly for the Amiga but I have recently seen, and after MANY hours of messing about finally played, the mono version of Gauntlet on Macintosh. I think the graphics are beautiful, does chug a bit on the Mac (more than Gauntlet in 16 colours on the ST with software samples!) but it's so nice I wanted to try and do a demo level of it in STOS.
The very long and annoying (you can not remap the keys for control and the choices are poo 8 way joystick position patterns on keyboard and pressing two keys does not get you diagonal either) of screen capping vMac emulator whilst failing badly at this game to get the graphics and anims ripped and work on it from there....one day...but now it's possible to try and write it for my 520STM and see what happens (I also have a couple of Mega STEs so there is 16mhz and a blitter to help alleviate the 'not coded in 68k machine code' factor).
Yes I am mad about Gauntlet, I absolutely love that game and if the controls were better I'd source a 512k old Mac to play it on real hardware....luckily for my bank balance the controls are not re-definable so no need to go beyond emulation.
But once again thank you, it is great preservation sites and updates to old software like this that make my [sure to fail] long gone teenage dreams of writing something nice in STOS for once still possible now in retirement haha
Return to “STOS”
