Internet on Hades under single TOS
Kroll
Postby Kroll » Sat Mar 08, 2014 6:26 pm
HI,
I have question about internet on Hades under single TOS.
Is it possible to get access to the internet under TOS using STING ?
Is there a driver for STING?
Regards
Kroll
rpineau
Re: Internet on Hades under single TOS
Postby rpineau » Sat Mar 08, 2014 6:47 pm
If you have Sting installed you should have thew ENEM.STX (it might not be enable and be named ENEM.STY, rename it to ENEM.STX and reboot) driver which is for ISA NE2000 card on Milan and probably Hades too.
Rodolphe
Kroll
Postby Kroll » Sat Mar 08, 2014 7:12 pm
I have forggotten to add that I have a card on PCI. This is a realtek 8139. I found driver only for mint.
Regards
Kroll
rpineau
Postby rpineau » Sat Mar 08, 2014 8:15 pm
Ok, I see which one you have. I never found any Sting driver for this card (not for me but for a friend who also had an Hades at some point).
Return to “Hades / Milan”
