mikro wrote:When sending stuff TO Falcon, I'm getting about 790 - 830 KB/s
jury wrote:but only when sending smaller files like up to 50MB. When sending larger files like 700MB my average transfer drops to 400KB/s. Did you notice anything like that with your setup?
mikro wrote:... is actually pretty goodI wanted to ask about/confirm following numbers. When sending stuff TO Falcon, I'm getting about 790 - 830 KB/s but when sending FROM Falcon, it's about 3.7 MB/s. Is this normal? This is my custom code, nearly no hassle around, just pure send/recv from mintlib, Linux on the other side, again just recv/send calls.
mikro wrote:Also, once, when sending from Falcon a 15 MB big file, I saw two errors like "buf_alloc RX failed, 1718", is this ok? (too bad I forgot to check file integrity in that case).
mikro wrote:Thank you for those numbers, Evil! So there is some discrepancy between upload and download. I'm wondering whether the culprit is mintlib/freemint or it's something inside the FPGA/driver code? (yes, hoping to get 3.5 MB/s in both ways)
shoggoth wrote:mikro wrote:Thank you for those numbers, Evil! So there is some discrepancy between upload and download. I'm wondering whether the culprit is mintlib/freemint or it's something inside the FPGA/driver code? (yes, hoping to get 3.5 MB/s in both ways ;))
I got the impression from the Nature guys that there was something funny in mintnet which limits the performance of the svethlana driver.
mikro wrote:shoggoth wrote:mikro wrote:Thank you for those numbers, Evil! So there is some discrepancy between upload and download. I'm wondering whether the culprit is mintlib/freemint or it's something inside the FPGA/driver code? (yes, hoping to get 3.5 MB/s in both ways)
Although we would have understood it in a single post, too, after second thought I have my doubts -- if mintnet/freemint was the culprit, wouldn't it affect all the network drivers? I mean when using the good old EtherNEC, I got 300 kB/s in both ways. On the other hand, this symptom can be visible for high (>1 MB/s let's say) speeds only. Too bad my EtherNAT doesn't work anymore, so I could verify this
Only from my memory I don't remember any discrepancies but my memory is not exactly the best.
