NEED 1040STFM POWER SUPPLY - U.S.
JimDrew
Postby JimDrew » Fri Jan 03, 2014 6:16 pm
Well, I made a rookie mistake today. I swapped the TOS1.2 to TOS1.6, tested it, turned off the power and when moving the metal shield over top of the power supply (to put it back in place) I apparently touched the tops of the caps and/or other parts with the shield and there was a neat flash of light and lots of smoke. The fuse blew too. I forgot to pull the A/C plug. New fuses blow instantly. So, now I have a dead 1040ST. So, does anyone have a power supply for one of these that is located in the U.S.?
I am the flux ninja
