Project announcement: libcmini
mfro
Re: Project announcement: libcmini
Postby mfro » Tue Dec 26, 2017 7:15 am
wongck wrote:Thank you for the excellent small lib.
Sorry for my lack of knowledge on Github, but these are sources and there is no ready to use Lib.
Is that true or am I looking at the wrong place?
Thank you for your interest in libcmini.
Yes. Currently, there is no binary distribution available. I'm still working on it.
There is an automated build process on each check-in using travis-ci already (stolen from EmuTOS), but I don't have a good concept distributing the result yet, need to figure out all that github stuff myself first. Until then, it's just a matter of three commands to build it:
git clone https://github.com/mfro0/libcmini
cd libcmini
make
ThorstenOtto
Postby ThorstenOtto » Tue Dec 26, 2017 10:23 am
mfro wrote:but I don't have a good concept distributing the result yet, need to figure out all that github stuff myself first.
Basically, you have three choices
  1. deploy it to a separate host. This is done e.g. in the EmuTOS repo (deploying to the old SF repo), and in Aranym (deploying to bintray).
  2. deploy it to a different repo, using the same account on github. This is what freemint currently does, but since this it is just another git repo, this will be just a new commit, and the repo will constantly grow even if you delete old images before committing.
  3. deploy it to a separate branch in the same repo. This is what I'm currently doing in my RscView repo (https://github.com/th-otto/rscview). The builds branch there only contains the binaries, not the sources from master. But you have to be careful with the travis settings, otherwise any commit to that branch will trigger another build, resulting in an endless build loop.
Feel free to ask any questions if you need help with this.
mfro
Postby mfro » Tue Dec 26, 2017 10:43 am
Thank you. Actually, I'm aiming for the fourth one ;).
Not really different from what you suggest, but since github appears to create a source archive on release anyway, I'm trying to stuff my binary release in there as well (seems to be the natural choice for a library anyway).
I just need to find a good way to do this.
ThorstenOtto
Postby ThorstenOtto » Tue Dec 26, 2017 11:02 am
mfro wrote:I just need to find a good way to do this.
If you find one, let me know ;) I've already tried this, and it does not seem to be possible, because you don't have direct access to the directories where the repo is stored on the server. And the source archives that appear there are only build when you create a tag, something that you most likely don't want to do for automatic builds.
mfro
Postby mfro » Tue Dec 26, 2017 9:21 pm
This appears to work now as I wanted it. Whenever I do a tagged commit (release), the installation files get deployed into the corresponding github release.
Repository growth avoided, target achieved ;)
Binary files can be found here: https://github.com/mfro0/libcmini/releases
Postby wongck » Tue Dec 26, 2017 11:42 pm
mfro wrote:Binary files can be found here: https://github.com/mfro0/libcmini/releases
WOW... that's quick.
Great stuff !!! Thanks !!!
ThorstenOtto
Postby ThorstenOtto » Wed Dec 27, 2017 10:20 am
mfro wrote:Whenever I do a tagged commit (release), the installation files get deployed into the corresponding github release.
Yes, this was the problem i encountered. You can use it for releases, but not for snapshot builds like eg. used in Freemint or Aranym.
But grats that you found a quick solution for your case ;)
mfro
Postby mfro » Wed Dec 27, 2017 3:37 pm
ThorstenOtto wrote:... You can use it for releases, but not for snapshot builds like eg. used in Freemint or Aranym ...
Maybe that's (one of) the reason(s) we didn't see a new release for both since years? :D
Seriously, for a library project like libcmini, this process seems ideal to me. You'll need to dig out your compiler to do something useful with it anyway, so there isn't much extra effort if you want to update between releases.
Postby mikro » Thu Jan 04, 2018 10:14 am
Btw if you would like your SVN tree, just let me know -- I have a dump of all AtariForge SVN repos.
LuigiThirty
Postby LuigiThirty » Wed Feb 07, 2018 1:03 am
Awesome!
willy
Postby willy » Sat Aug 31, 2019 11:49 am
Hi.
I'm using gcc 8.3 without mintlib (not necessary for assembler), now i want to use libcmini.
I compiled everything but test compilation fails because of missing gem.h
What do i need installed to compile/use libcmini?
CC objs/acctest.o
sources/acctest.c:10:10: fatal error: gem.h: No such file or directory
 #include <gem.h>
How to fix that without installing a whole mint subsystem ?
Thanks in advance.
mfro
Postby mfro » Sat Aug 31, 2019 3:26 pm
willy wrote:How to fix that without installing a whole mint subsystem ?
Thanks in advance.
You do not need the whole 'mint subsystem', gemlib should be enough. If you do not want to install that either, you can still skip the build of the test programs:
make libs startups
should do it.
Note that I didn't test libcmini with gcc 8.3 (only 4.6.4), so here be dragons (although I wouldn't expect too many problems).
willy
Postby willy » Sat Aug 31, 2019 5:13 pm
I'm not afraid of dragons ... but little bugs ;)
make libs startups install-libs install-startup
did the job
willy@willy-mietus ~/src/falcon/libcminitest $ ll
total 12
drwxrwxr-x 2 willy willy 4096 Aug 31 19:02 ./
drwxr-xr-x 9 willy willy 4096 Aug 31 18:39 ../
-rw-r--r-- 1 willy willy 85 Aug 31 18:39 hello.c
willy@willy-mietus ~/src/falcon/libcminitest $ cat hello.c
#include <stdio.h>
int main(int argc, char *argv[])
printf("hello world\n");
willy@willy-mietus ~/src/falcon/libcminitest $ m68k-atari-mint-gcc -m68020-60 -nostdlib $LIBCMINI/startup.o hello.c -o hello.tos -s -L$LIBCMINI -lcmini -lgcc
total 16
-rwxrwxr-x 1 willy willy 3388 Aug 31 19:02 hello.tos*
willy@willy-mietus ~/src/falcon/libcminitest $ m68k-atari-mint-gcc --version
m68k-atari-mint-gcc (MiNT 20190223) 8.3.0
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Thank You. Nice job.
mfro
libcmini: new release 0.5
Postby mfro » Sun Oct 20, 2019 8:30 am
Thanks to diligent contributors (thank you), libcmini received some new functionality and bug fixes which deserve a release. You can find it at the usual place:
Git repository:
Combined Source/Binary release files:
mfro
libcmini: now a member of the FreeMiNT github organization
Postby mfro » Thu Mar 05, 2020 4:28 pm
If you miss libcmini - it's now here:
https://github.com/freemint/libcmini
integrated into the freemint organization
Count
Postby Count » Thu Mar 05, 2020 7:04 pm
Maybe it's time for a minor release 0.51 since some significant bugs have been fixed since the last release.
mfro
Postby mfro » Thu Mar 05, 2020 7:10 pm
Count wrote:Maybe it's time for a minor release 0.51 since some significant bugs have been fixed since the last release.
Yes, why not. But we first need to make sure the CI processes work again.
mfro
Postby mfro » Thu Mar 05, 2020 7:24 pm
Done. Binary release (0.51) can be found here:
https://github.com/freemint/libcmini/releases
Return to “C / PASCAL etc.”
