zDesk
ldv-01
Re: zDesk
Postby ldv-01 » Tue Mar 05, 2013 4:24 pm
Great ! And what about the "eye candy" department (namely icons) ?
ldv
Zorro
Re: zDesk
Postby Zorro » Sat Mar 09, 2013 7:21 pm
ldv-01 wrote:Great ! And what about the "eye candy" department (namely icons) ?
ldv
As you can see on the first video, I have spent a fair bit of time working on the icons.
Well, to be honest, a few are completely "stolen" from deviant art( like the trashcan) others are modified version of existing icons but many of these ones have been drawn "by hand".
So, I want to keep this set. However, If you want to complete the icon's list or change the 2 or 3 icons "stolen", you are welcome. Especially to add well known applications' icons :wink:
Re: zDesk
Postby shoggoth » Sat Mar 09, 2013 8:24 pm
It seems you focused quite a lot on the stuff usually lacking in Atari application; ergonomics, response to user interaction. Complete this application and we have a major contribution to the platform. I love Thing, but I really appreciate having a choice.
I've browsed the zDesk sources, and I like your coding style and have great confidence in the way you write your stuff. I'm looking forward to a release where I can actually start applications :)
If there's a possibility to use bitmaps for stuff (window backgrounds, desktop backgrounds), I wouldn't mind if you added the possibility to allocate the memory for those bitmaps in video RAM on supported hardware using ct60_vmalloc() (this call should work equally well on both the SuperVidel and Radeon/CTPCI). It means blits will be carried out from vram<>vram rather than some other way, and should hence be a bit faster. Just be sure to free that memory (also using ct60_vmalloc()) when the application finishes, because it isn't freed by the OS when the process terminates (ct60_vmalloc() is an XBIOS extension and is untouched by FreeMiNT etc. Personally I'd like to see an extension to Mxalloc() instead, but so far it seems I'm the only one who appreciate the need for that).
OL
Re: zDesk
Postby OL » Sun Mar 10, 2013 9:47 am
shoggoth wrote:It seems you focused quite a lot on the stuff usually lacking in Atari application; ergonomics, response to user interaction. Complete this application and we have a major contribution to the platform. I love Thing, but I really appreciate having a choice.
I send to Zorro my routine using it with good binding of function because it was a little bit tricky to work when I include it in MyAES
OL
OL
ldv-01
Re: zDesk
Postby ldv-01 » Sun Mar 10, 2013 2:20 pm
ldv
Thank you for the reply. So Icons will reside in the zDesk main resource file and will be in the standard 2/16/256 Atari format.
May be this is more an AES related question. Any plans to support True Color icons or at least with a 256 color optimized (adaptive) palette ?
ldv
OL
Re: zDesk
Postby OL » Sun Mar 10, 2013 5:33 pm
ldv-01 wrote:
ldv
ldv
This will be perhaps my job, MyAES support true color icon, the problem there is no tools for save RSC file with true color icons, I'm currently trying to do it but it's not easy and crash at this time. If it work I will try this RSC file under XaAES, probably it will not recognize the true color icon but I hope it not crash and will take the 256 color version, if it crash I will do a patch in XaAES.
OL
OL
Zorro
Re: zDesk
Postby Zorro » Sun Mar 10, 2013 9:02 pm
Thanks for you comment :wink:
shoggoth wrote:If there's a possibility to use bitmaps for stuff (window backgrounds, desktop backgrounds), I wouldn't mind if you added the possibility to allocate the memory for those bitmaps in video RAM on supported hardware using ct60_vmalloc()
Yes I will do that.
I have just 4 questions:
1) I need to know if, like Malloc(), there is risks of memory fragmentation if I use this function for every MFDBs( there will be a lot).
2) Do you have a way of knowing if a Radeon is on system?( cookie, etc...)
A clean and system friendly way, of course.
3) Is this function thread safe?
4) I think yes but to be sure: The memory reserved si global? Roughly speaking, can I send the memory pointer to another thread or process?
Zorro
Re: zDesk
Postby Zorro » Sun Mar 10, 2013 9:34 pm
ldv-01 wrote:Thank you for the reply. So Icons will reside in the zDesk main resource file
No, I think that the icons will be in a separate ressource file.
ldv-01 wrote:and will be in the standard 2/16/256 Atari format.
Yes and no.
The icon will be in the standard format but Olivier is working on MyAES to support the TC icons in the rsc files.
ldv-01 wrote:Any plans to support True Color icons or at least with a 256 color optimized (adaptive) palette ?
As long as XAAES doesn't support that, only for MyAES.
But even with a limited palette, good looking icons can be done :wink:
red point: Icons "stolen" from the web.
green point: same that the red point but substantially modified.
The others ones are originals( or almost).
The icons with the red point need to be replaced. if there are volunteers....
Re: zDesk
Postby shoggoth » Mon Mar 11, 2013 8:26 am
Zorro wrote:I have just 4 questions:1) I need to know if, like Malloc(), there is risks of memory fragmentation if I use this function for every MFDBs( there will be a lot).
Yes there is. ct60_vmalloc() is comparable to Malloc() except that memory isn't freed automatically on process termination.
I don't know how to detect the Radeon, but the SuperVidel is detected by checking for th "SupV"-cookie. If it's present, you have a SuperVidel, and ct60_vmalloc() is available.
It's just like any other XBIOS function. AFAIK it should be thread safe (since the kernel is supposed to single-task in supervisor mode, and the trap handler executes in supervisor).
... make sure to get a 2nd opinion on this however, since this is just me speculating.
Yes. The kernel has no concept of video RAM at all, since this is a low level thing and not part of GEMDOS. However, I guess someone could in the future implement some extra flags in Mxalloc() to allow allocation of video ram.
Re: zDesk
Postby wongck » Mon Mar 11, 2013 11:17 am
I did a small program that automatically disable/enable the NVDI driver SYS files based on whether the ATI Radeon is running or not.
The Radeon detection routine I used is as attached here.
ati.zip
It needs to have PCI Bios library. It's pretty simple, jsut check the PCI IDs.
It seems to work well on my CT63/CTPCI but I am the only user of this program (it's not release to the community).
I removed most of the code of my program leaving only the detection code only.
(mainly to avoid you having to use a bucket while looking at it :oops: )
I hope I did not over-remove the codes. plus I did it like 2-3 years ago, so I cannot remember every line.
Zorro
Re: zDesk
Postby Zorro » Mon Mar 11, 2013 11:11 pm
shoggoth wrote:...Yes. The kernel has no concept of video RAM at all, since this is a low level thing and not part of GEMDOS. However, I guess someone could in the future implement some extra flags in Mxalloc() to allow allocation of video ram.
Thanks you for your answers.
If I need more informations, I will contact Didier.
Zorro
Re: zDesk
Postby Zorro » Mon Mar 11, 2013 11:15 pm
wongck wrote:...
Thanks for the code sample, I will look inside.
Zorro
Re: zDesk
Postby Zorro » Wed Mar 27, 2013 2:01 pm
New video added.
Re: zDesk
Postby Dal » Wed Mar 27, 2013 2:17 pm
It's gorgeous. :)
vido
Re: zDesk
Postby vido » Wed Mar 27, 2013 2:52 pm
This is jut great!!!
Cant wait to use it on my FireBee ... :)
Re: zDesk
Postby wongck » Wed Mar 27, 2013 3:12 pm
Looking great !!! :thumbs:
Can't wait to see it on my Atari.
jvas
Re: zDesk
Postby jvas » Wed Mar 27, 2013 3:36 pm
Zorro wrote:New video added.
Super!
For those, who are dumbs like me, the video is added to the first post ...
rudis
Re: zDesk
Postby rudis » Wed Mar 27, 2013 6:38 pm
gorgeous :o
CiH
Re: zDesk
Postby CiH » Wed Mar 27, 2013 6:46 pm
Yep, got my attention :cheers:
Hopefully the issue with some incompatible or snowed out animated gifs on zView will be fixed too.
lschafroth
Re: zDesk
Postby lschafroth » Wed Mar 27, 2013 7:12 pm
All I can say is WOW.
paul92706
Re: zDesk
Postby paul92706 » Wed Mar 27, 2013 8:24 pm
oh wow!!!! so cool!!
Zorro
Re: zDesk
Postby Zorro » Wed Mar 27, 2013 8:27 pm
I'm glad to read your comments so, first of all, thank you all for that :wink:
CiH: About zView.
As I have already said to Miro - the skillful coder who has maintained zView during my absence - this application is quite outdated, so for me, the current version is dead.
zDesk will owns an image browser and technically, it will be much much better, by far, that zview.
For that reason, zView "2" needs to be redone from scratch:
Remove the image browser, add image operations( crop, resize, contrast, luminosity, etc..) and concentrate the efforts on the speed, the PDF reader and above all, the "lightness"( I don't want a white elephant as is currently the case).
But one thing at a time. For the moment, all my spare time is dedicated to zDesk.
jfl
Re: zDesk
Postby jfl » Wed Mar 27, 2013 8:47 pm
I won't repeat what everybody said above since I agree with them all. I will only add this: the animated busy bee within the window tabs? Pure brilliance. I'm speechless. Such a cool idea. Who would have thought of that? Well, you have. And that's quite something. I bow before the master.
Jean-François
GEMDict – GEMClip
calimero
Re: zDesk
Postby calimero » Thu Mar 28, 2013 12:00 am
really crazy poo !!! :) :) :)
http://www.youtube.com/user/zorro270?feature=watch
I LOVE IT! :)
especially that it is inspired with Mac OS X:
- there is no "OK" or other confirmation button in "information dialog"
- toolbar menus
- resize thumbs slider in bottom of window... very nice!
btw
- what library/framework do you use for programming zdesk?
- how CPU usage almost never jump when you resizing or drag windows (but only when you add items to toolbar)?? coz of Aranym?
- what OS (AES) do you use?
- so zDesk is multithreaded (every windows will keep doing it's work, like creating thumbnails)?
- just please, please, please, please keep in mind keyboard shortcuts! : made it possible to browse thorough file system and to copy/move files with keyboard only!
zDesk is single most astonishing piece of software for Atari! :) hope we will add soon zDesk in voting pool at:
viewtopic.php?f=28&t=24624
Zorro
Re: zDesk
Postby Zorro » Thu Mar 28, 2013 6:27 pm
calimero wrote:- what library/framework do you use for programming zdesk?
I don't use any library other than the MiNTLIB/GEMLIB.
calimero wrote:- how CPU usage almost never jump when you resizing or drag windows (but only when you add items to toolbar)?? coz of Aranym?
There is a bug in zTask. Its CPU monitor stops to work after a while( another thing on my to-do list).
And I use Aranym in full MMU mode and without JIT, so the speed is "only" close to a CT60@80mhz.
calimero wrote:- what OS (AES) do you use?
I use a basic MiNT/XAAES configuration.
calimero wrote:- so zDesk is multithreaded (every windows will keep doing it's work, like creating thumbnails)?
Currently, only the image related functions are on another thread/process.
But when the first version of zDesk will be released, no action will be blocking and even with several operations at the same time, the desktop should be smooth.
calimero wrote:- just please, please, please, please keep in mind keyboard shortcuts! : made it possible to browse thorough file system and to copy/move files with keyboard only!
Of course :thumbs:
And thank you all again for your comments, I will try not to disappoint you :wink:
