NEW IDE Controller & TOS 2.06 board (with extras)
Re: NEW IDE Controller & TOS 2.06 board (with extras)
Postby DarkLord » Tue May 05, 2015 4:13 am
Exxos (Chris) on the board here has a store that sells HD kits, IIRC:
http://www.exxoshost.co.uk/atari/last/floppy/index.htm
HTHs.
roninfourseven
Postby roninfourseven » Tue May 05, 2015 9:05 pm
Darklord, thanks for the link, I probably should have specified that I have an STE with TOS2.06 and have HD FDD support built in, and have soldered the link to make it live.
So I guess the question should be, how do I fit an HD FDD in an STE that has HD mode enabled i.e. option is visible in GEM format disk dialog? And I guess where can I get a drive from, or can I use a standard HD FDD?
Thanks to all for your help on here BTW :)
Postby DarkLord » Wed May 06, 2015 12:08 am
In that same link, Chris recommends this floppy drive:
Sony MPF920
and he also details various mods that might have to be
done.
As far as "fitting", if you're talking about the faceplate
differences, most people do a little creative engineering
and modify it to accept the new drive. That's what I did
with my STacy when I added a 1.44 drive.
HTHs.
qq1975b
Postby qq1975b » Thu May 07, 2015 7:59 am
Yes, Sony MPF920 is ok. I have tested it on an STe and on a Falcon too.
viewtopic.php?f=15&t=10873
Trying to learn...
roninfourseven
Postby roninfourseven » Thu May 07, 2015 9:42 pm
Thanks all, I'll go back and re-read the article, as I confess it was a bit of a skim read :oops:
I'll look into the MFP 920, I may even have one lying around.
Trouble is, I binned a load of kit when I moved house last August, so I'm not 100% sure.
TBH, it's an STE housed in a STFM case that's already heavily modified, so I'm not beyond getting the tools out to do some mre case mods.
Since I want to mod the case to allow access for my CF card connected to AlanH's IDE adapter, I'll just add it to the to do list :D
Sven
Postby Sven » Tue May 12, 2015 6:41 pm
Hi all,
I´m new to this forum and I´m about to order the IDE Controller for my Atari. Some questions left, I would like to ask them here....
Actually I´m using an 520ST with an old harddrive solution via the ACSI port (2 RLL drives with each 10MB and an Omti controller).
1--Now with the new IDE drive I would like to know if it is possible to use both drives at a time to copy/move all files from the old hdd to the new IDE hdd or CF card ??
2--Am I´m right that the one cable from the IDE controller that has to be attached to pin 10 on the ASCI port is only necessary if I want to have boot capability from the IDE drive ??
3--Without TOS 2.06 I have to boot from floppy ??
Maybe someone has the answers to my questions.... :-)
Thanky a lot
Sven
Postby joska » Wed May 13, 2015 6:58 pm
Sven wrote:1--Now with the new IDE drive I would like to know if it is possible to use both drives at a time to copy/move all files from the old hdd to the new IDE hdd or CF card ??
Yes, no problem.
Sven wrote:2--Am I´m right that the one cable from the IDE controller that has to be attached to pin 10 on the ASCI port is only necessary if I want to have boot capability from the IDE drive ??
That depends on the harddisk driver I believe. With HD-Driver it's true.
Sven wrote:3--Without TOS 2.06 I have to boot from floppy ??
Floppy or your external harddisk.
Sven
Postby Sven » Wed May 13, 2015 7:34 pm
Hi joska,
thank you for the good news :D
Sven
roninfourseven
Postby roninfourseven » Thu May 14, 2015 9:50 pm
So, I've had another play around tonight, and got some good results. I'm using CBHD as my driver,and I am gobsmacked at just how much faster it is to format and partition that AHDI.
I have a dual CF/IDE adapter connected to AlanH's IDE adapter, into which I had a 1GB card. This is in my STE 4MB.
Tonight I pulled that and successuly dropped in my 16GB card,which formatted ok with CBHD, partitioned up fine into 4 256Meg slots, and installed the driver. (I'm gettting the hang of CBHD now, even if it is in German!)
I then popped the 16GB card into slot 2, the original 1GB card into slot one, and powered back on. Once booted, I installed devices, and got another 4 drives visible.
Copying between the two devices was quick and seemingly worked very well.
So, all good, I have 2 good working drives. Next bit of tinkering will determine just how much of that 16GB I can actually use, and some messing around with partition sizes. I know TOS 2.06 can happily deal with 512MB, but I've read that TOS > 2.XX can support 1GB, so has anybody tried that at all, or am I just misleading myself with bad info from the internet?
alienkidmj12
Postby alienkidmj12 » Sat Jul 25, 2015 4:37 pm
how do i get one :)
alanh
Postby alanh » Mon Jul 27, 2015 7:27 pm
You probably want to look at the MonSTer thread now.
catmando
Postby catmando » Tue Oct 20, 2015 9:57 pm
Finally got round to installing the rev2 (with the primary fix applied) I bought years ago in my STE (Tos 1.62/2.06).
I'm attempting to use an IDE to CF adapter with a 2GB CF card using the CBHD drivers.
However I'm hitting a stumbling block, CBHD appears to detect everything correctly but it seems I am only able to make one partition, for some reason clicking on any arrows on the adjustment bars has no effect on increasing the partition size except for bar 0 (zero)
Is this a problem anyone else has come across?
Atari STFM
Postby joska » Wed Oct 21, 2015 9:35 am
CF-cards can be tricky. Try HD-Driver instead, it specifically supports CF-cards. There is a demo available on Uwe's website.
catmando
Postby catmando » Wed Oct 21, 2015 9:58 am
joska wrote:CF-cards can be tricky. Try HD-Driver instead, it specifically supports CF-cards. There is a demo available on Uwe's website.
I did try HD Driver but it was version 8.13 (2 bombs loading driver, 4 bombs using auto driver configure)
Atari STFM
catmando
Postby catmando » Wed Oct 21, 2015 3:05 pm
All working now with HD Driver 8.13. Had to swap to an IDE to SD adapter (CBHD still wanted to only make one partition though when I tried it)
Atari STFM
Postby joska » Wed Oct 21, 2015 7:12 pm
catmando wrote:Had to swap to an IDE to SD adapter (CBHD still wanted to only make one partition though when I tried it)
That's what I'm using too. Works with all IDE-aware drivers I've tried so far. I'm actually using AHDI 6 on all machines (STM, STE and Mega) as it's free and I really doesn't need all HD-Driver features on those machines.
diamondspringwater
Postby diamondspringwater » Sun May 15, 2016 6:00 pm
Can you use an external ultrasatan with this installed.
Postby joska » Sun May 15, 2016 7:16 pm
Yes, ACSI is not affected in any way by this card. But you need a harddisk-driver that knows the difference between ST-RAM and alt-RAM. HD-Driver between 7.6-something and late 8.x has a bug that causes data corruption on ACSI-devices when alt-RAM is in use. I have used AHDI 6.06 without any problems.
diamondspringwater
Postby diamondspringwater » Mon May 16, 2016 12:57 am
Thank you joska
I have hd driver 9.07 so that should work.
alienkidmj12
Postby alienkidmj12 » Sat Jun 04, 2016 10:17 pm
sounds like a great project, how much would this cost ?
athensnet
Postby athensnet » Tue Oct 25, 2016 2:00 pm
Any news on producing new boards ?
alanh
Postby alanh » Wed Oct 26, 2016 8:25 am
These older IDE boards are not produced by me anymore. I now do the MonSTer board instead.
Ragstaff
Postby Ragstaff » Wed Oct 26, 2016 10:16 am
alanh wrote:These older IDE boards are not produced by me anymore. I now do the MonSTer board instead.
Maybe you could edit the original post and note this somewhere (in bold?!) to let people know ;-)
alanh
Postby alanh » Wed Oct 26, 2016 10:46 am
Should probably just close the thread.
frank.lukas
Postby frank.lukas » Wed Oct 26, 2016 11:31 am
Sad because the only IDE Board where useful for a PAK68 with TOS 3.06 on it. The MonSTer only works with TOS 2.06 on the PAK ...
