NEW IDE Controller & TOS 2.06 board (with extras)
Fujiyama
Re: NEW IDE Controller & TOS 2.06 board (with extras)
Postby Fujiyama » Wed Oct 23, 2013 12:32 pm
After a LOT of struggle I finally managed to insert the IDE board into my Mega STe. It took a lot of wiggling with a needle and even removing the CPU a couple of times.
Unfortunately the computer doesn't power up any longer and I've removed the IDE board w/wires just to make sure its not causing the trouble.
The internal SCSI hard drive powers up and boots, so I know it's getting power, but there's nothing on the screen, no floppy drive booting etc. I suspect the CPU having contact issues but having tried to wiggle the pins back many times it's still a no go.
I'm going to continue trying it out but how hard is it to replace the PLCC socket? Is it just a matter of desoldering (hopefully it'll be soldered to just the bottom side of the PCB)?
I figure that if I replace the PLCC socket I might as well put the CPU into the socket first, then the IDE board and finally solder the socket (with CPU/IDE board inserted) to the Mega STe motherboard.
If I decide to do that, are there other, better suited sockets that allow stacking of PCBs as with the IDE board, or should I just replace it with a similar IC socket?
Are you a good person?
alanh
Postby alanh » Mon Oct 28, 2013 7:14 pm
Oh dear, sorry to hear that.
The best way to fix it, is to take the CPU back out. Use the pin and pull the legs from the bottom as they are upside-down U shaped. Pull them out by around 1mm or so and then push the CPU back in and check it boots up first.
Then try revisiting the IDE board.
KLund1
Postby KLund1 » Tue Oct 29, 2013 5:06 am
alanh wrote:If you look at the very first pictures of this thread, that's the prototype in my STacy.
So these do working a Stacy. Are these for sale yet? I was looking through the thread but I might have missed a link
Nice work on this, by the way. Very cool.
alanh
Postby alanh » Tue Oct 29, 2013 9:54 am
The STFM, MegaST and STacy are all the same IDE boards. They need to be soldered onto the 68000, preferably soldering a socket first, then plugging the IDE board on.
TOS 2.06 is the tricky part. As the STacy needs manual work for that.
Guest
Postby Guest » Sat Nov 02, 2013 12:32 am
ive got lots of ttl buffers etc ttl some lots
just ask perhaps i can fill a chip gap??? all smd soic etc
ask ill list
Postby DarkLord » Sat Nov 02, 2013 4:32 am
alanh wrote:TOS 2.06 is the tricky part. As the STacy needs manual work for that.
Just curious Alan - what would it take to get your board to work with a stock
STacy, and give it TOS 2.06?
alanh
Postby alanh » Sat Nov 02, 2013 8:40 am
EDITED...
Not much. The STacy uses 1001 32 pin chips already, so it's probably just a case of getting the new CE pin across to them from the IDE board.
I should give this a try at some point, but my office is upside-down at the moment.
Postby DarkLord » Sat Nov 02, 2013 9:05 pm
Okay, as I said I was just curious. :)
Oh, BTW - congrats - HDDriver v9.0 is out and according to the
news release it now specifically supports your device (its even
mentioned there). :cheers:
alanh
Postby alanh » Sat Nov 02, 2013 11:52 pm
It was mentioned in the 8.46 notes too.
But 9.0 supports the STFM boards ability to now stack them, so it can support 8 IDE devices.
The STE board doesn't support this as it's not stackable. I need to get Uwe to correct this on the notes.
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Sun Nov 03, 2013 9:29 am
ooh v9 is nice :)
I might make some time to re partition my Ultra as i've gained a collection of cards since I last played with it.
In theory, it should 'see' a 4gig card and let me make 8 512k partitions yes ? or is there a limit on the cards capacity ? I'm only checking as I have a 6gig IDE drive in my mega thats got a load of 500meg partitions and works a treat.
cheers :)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Tue Nov 05, 2013 9:40 pm
to answer my own question, yes it does :)
jomor58
Postby jomor58 » Fri Nov 15, 2013 5:44 pm
The posty delivered my ST IDE and ROM upgrade boards today, quicker than I expected.
I cant wait to get these beauty's installed in my STFM, unfortunately that's not going to be until after Christmas.
Is there a guide for fitting the IDE board in a STFM? I've seen one for the megst and ste but not the STFM.
Many thanks to protek for recommending this project to me when I posted pictures, on AmiBay, of the installation of exxos's 4MB simm adapter.
John
Actually arrived yesterday, taken for ever to get this, my first post, approved.
Guest
Postby Guest » Sat Nov 16, 2013 11:34 pm
add a signals port please
something missing from just about any design i found
and documented
this way a port can be formed for other stuff
who knows!!!!
burningman
Postby burningman » Mon Nov 18, 2013 6:34 pm
Hi alanh,
I would like to order an IDE controller & TOS 2.06 board. Unfortunately, I'm new here and can not send a PM.
How can I order the IDE controller & TOS 2.06 board?
Regards Burkhard (the Burning_Man)
alanh
Postby alanh » Tue Nov 19, 2013 10:05 am
Just FYI folks.
I'm currently out of stock of the STE boards, so I'm collecting pre-orders for a new batch.
LuckyOldMan
Postby LuckyOldMan » Tue Nov 19, 2013 7:09 pm
Hi Alan,
please count me in for 1 piece - thanks!
Is the ST-version still available?
LOM
260ST: TOS 1.0.4/1MB
520STM: TOS 1.0.2/1MB
520STM: TOS 1.0.4/4MB/AT-Speed C16 Rev.2
520ST+: TOS 1.0/1MB
1040STFM: TOS 1.06/1MB
1040STF Tower: KAOS TOS 1.4.2/4 MB/HDD 105S+730S/Toshiba CD-Rom/ZipDrive/AT-Keyboard
4160STE: TOS 2.06/1.62/4 MB
MegaSTE: TOS 2.06/4MB/HDD 103S -
TT030: TOS 3.06/10MB/64MB/Quantum 210S/Megavision300
alanh
Postby alanh » Tue Nov 19, 2013 7:39 pm
Yes, I still have STFM/MegaST boards available.
LuckyOldMan
Postby LuckyOldMan » Tue Nov 19, 2013 8:57 pm
Hi Alan,
thanks for your answer!
Hopefully you'll get enough orders for the STE-version soon so the new batch can be started. :)
520ST+: TOS 1.0/1MB
alanh
Postby alanh » Wed Nov 20, 2013 1:28 pm
jomor58 wrote:The posty delivered my ST IDE and ROM upgrade boards today, quicker than I expected.
John
Hi John,
Hope it goes well. Exxos did a bit of a write up when he installed his STFM version here....
http://exxos.www.idnet.com/IMPULSE/atar ... /index.htm
badak
Postby badak » Tue Dec 03, 2013 9:54 am
alanh wrote:Just FYI folks.
hello
I am interested too, how to preorder?
Bastien
Robotech Collections, Varitechs, et Mechas
http://www.robotechcollections.fr
alanh
Postby alanh » Tue Dec 03, 2013 7:57 pm
PM me your email address, and I'll add you to the list.
artik-wroc
Postby artik-wroc » Sat Dec 07, 2013 9:00 am
Does anyone use this controller with PAK ?
It is generally known that PAK "doesn't like" IDE devices :)
alanh
Postby alanh » Thu Dec 12, 2013 8:24 pm
No reason why it shouldn't. I do have a couple of PAK's though. So I can try it.
Postby DarkLord » Fri Dec 13, 2013 8:16 am
Hmm, I'm wondering about room with both devices installed...
delvis
Postby delvis » Fri Dec 13, 2013 2:30 pm
That is what I ran into with the Marpet 8 Meg Ram board and the IDE Doubler. Couldn't put the lid back on the Mega ST. Finally just removed the Marpet and lid closed fine.
Delvis
Atari User since 1982
400 / 800/ 1200XL / 800XL /65XE / 130XE
520ST / 1040ST / MegaST4
