PH Easy Remote Print - RAW, LPD, Google Cloud Print & parallel port redirector
Re: PH Easy Remote Print - GEM lpr client
Postby wongck » Thu Nov 22, 2012 4:08 pm
Updated PH Easy Remote Print v1.01
- fixes crash on selecting edit field consecutively.
- add pherpde.rsc file ( but it is still in English, German translation on the way).
- removed small bug by adding 2 space to name of program.
Get it from Probe House Software
Postby wongck » Thu Nov 22, 2012 4:12 pm
joska wrote:I noticed a small bug - the menu/nice-name is missing the two preceding spaces.
This looks like a way to hide apps from the drop down.
Is there any way to hide it from Taskbar ?
Postby joska » Thu Nov 22, 2012 9:13 pm
wongck wrote:This looks like a way to hide apps from the drop down.
Yes, by violating the specifications for menu_register() ;). Please don't do that, you never knows how this is handled in the future. Maybe a future AES (or version of XaAES) decides not to accept an application doing this?
wongck wrote:Is there any way to hide it from Taskbar ?
Yes, you drag it's button to the trashcan. Or right-click on the button and select "Configure" from the popup.
Postby wongck » Fri Nov 23, 2012 1:04 am
joska wrote:Yes, by violating the specifications for menu_register() ;). Please don't do that, you never knows how this is handled in the future. Maybe a future AES (or version of XaAES) decides not to accept an application doing this?
In my case, it is really an oversight on the 2 spaces. No intention to hide it, and it is fixed now.
Only seems like a possible root-kit type of capability so that the process don't show up normally. Of course doing a PS will show it still.
joska wrote:Yes, you drag it's button to the trashcan. Or right-click on the button and select "Configure" from the popup.
I mean programmable, like by violating the specs for menu_register(). Again, possible root-kit idea. :mrgreen:
Postby joska » Fri Nov 23, 2012 7:31 am
wongck wrote:I mean programmable, like by violating the specs for menu_register(). Again, possible root-kit idea. :mrgreen:
Only by modifying Taskbar's configuration file.
Ektus
Postby Ektus » Fri Nov 23, 2012 6:49 pm
I did a test on MagiC With MagiCNet. It works (sort of).
- pherp will terminate after a minute or so with 68k exception
- configuration works
- sending the test page to the printer did produce a result, but I had to cancel the print as the printer was waiting for more data.
- :megaphone: I got a print: :cheers: :D
Test Print out from    PH Easy Remote Print
Client = CT2_FALCON
LPD server = 192.168.0.100
printer name = lp
Test Print out time 19:34:2
The second digit of the seconds is missing.
Nevertheless, this is the very first time I was able to print something from my Atari to the network printer.
Very good!
Sending a file over that was printed via NVDI works and prints out okay, but I have yet to find a printer driver and setting that matches my printer.
Regards
Ektus.
Postby wongck » Sat Nov 24, 2012 5:43 am
Ektus wrote:I did a test on MagiC With MagiCNet. It works (sort of).
Great job!! :D
I never got it to work on MagiC... I do not know why.
Ektus wrote:Nevertheless, this is the very first time I was able to print something from my Atari to the network printer.
Sound great..... a good step forward :D
Did you just drag & drop the file to PH ERP or did the folder watch?
Ektus
Postby Ektus » Sat Nov 24, 2012 6:40 am
I did drag and drop the file immediately after starting pherp. Folder watch is disabled and no folder set.
Regards
Ektus.
Postby wongck » Sat Nov 24, 2012 7:39 am
Ok. I thought it was the folder watch that kills it.
Looks like it is something else.
I hope to make it run on my MagiC, it is freezing on mine.
Postby wongck » Sat Nov 24, 2012 9:19 am
Guess what... I tried to run PH Easy Remote Print on my MagiC and this time it did not hang... !!!
it did hang for me previously.
But now I have a TCP error, that say host cannot be found on my MagiXnet. :(
Well, I know that I have not really installed it properly. Too much time spend making apps.
Ektus wrote:pherp will terminate after a minute or so with 68k exception
And yes, I can simulate this error now. :wink:
May be a quick workaround that you can do now to get you going.... before I release an revision. :D
1. Keep the "activate watch folder" to off
2. Make a folder that is empty on your drive. Any name will do, just keep it empty.
3. Under configuration, select your watch folder to be the above folder you just made.
4. Save. It should not crash now.
It seems to be crashing if the folder is not there. Only happens in MagiC, it seems to work OK in Mint.
I could not test this earlier as it was not working in MagiC. I think I may have mixed architecture again during testing time.
Ektus
Postby Ektus » Sat Nov 24, 2012 12:43 pm
wongck wrote:Guess what... I tried to run PH Easy Remote Print on my MagiC and this time it did not hang... !!!
Okay, so no need to send you the exception processing output from my CT63. There, the behaviour is exactly the same.
wongck wrote:May be a quick workaround that you can do now to get you going.... before I release an revision. :D
Okay, done, and seems to do the trick. Thank you very much!
Regards
Ektus.
P.S.: The printer in use is a Brother MFC-7820N laser multi-function device. I was able to print a document from Signum!4 using HPLASER.TRB
Postby wongck » Sat Nov 24, 2012 1:58 pm
Great that the workaround worked. Enjoy :-)
Actually, reading the code, if you make that a watch folder it should also work.
Ektus wrote:P.S.: The printer in use is a Brother MFC-7820N laser multi-function device. I was able to print a document from Signum!4 using HPLASER.TRB
Yes, most of the printers till today still understands HP PCL standard.
So long as you can make the Atari side output PCL standard (most HP laserjet do) you will be able to make print out.
Both Postscript and HP PCL works great.
I tried to do colour printout, using HP Deskjet PCL, but I was not successful.
MadMax2023
Postby MadMax2023 » Sun Nov 25, 2012 1:33 pm
I am just discovering your new program, how lucky we are :D
If i understood well it allows an Atari computer to use a printer connected on a PC through network?
Postby wongck » Sun Nov 25, 2012 11:25 pm
MadMax2023 wrote:I am just discovering your new program, how lucky we are :D
Just drop by the website every now & then to check for something new.
But that's probably all the apps for this year, May be some more next year.
We all are lucky so far.
I want to try out USB for the rest of the time before 26 Dec 2012 (or whatever the date is).
Let's see if we are still lucky....
MadMax2023 wrote:If i understood well it allows an Atari computer to use a printer connected on a PC through network?
Yes and not only that.
So long as it runs lpd on the device, it can also print directly to a multi-function-device, like a photocopier with a printing function. :D I have done that during my testing.
Postby wongck » Sat Dec 01, 2012 4:38 pm
PH Easy Remote Print v1.02
- German translation by Latz.
- fixes the MagiC crashes on no watch folder defined.
Get it from the old location :mrgreen:
Sorry for the delay in releasing this, but Win 8 driving me crazy with metro, charm etc.... my advice in general.... if you don't have to, don't upgrade to Win 8. :roll:
christos
Postby christos » Sat Dec 01, 2012 5:06 pm
There is a classic start menu program for win8. It's much more practical than metro UI for some uses.
Ektus
Postby Ektus » Sat Dec 01, 2012 6:45 pm
Even on windows 7, it's so much more familiar using http://classicshell.sourceforge.net/ :D
Regards
Ektus.
Postby wongck » Sun Dec 02, 2012 1:16 am
christos wrote:There is a classic start menu program for win8. It's much more practical than metro UI for some uses.
Ektus wrote:Even on windows 7, it's so much more familiar using http://classicshell.sourceforge.net/
Thanks guys.
This is exactly what I installed and make it more bearable.
I will also be installing the Gadgets, just deciding which method to use.
Overall, my PC seems slower to boot to the desktop. I think Win 8 is assuming every PC to be 100% on-line and tries to get stuff for the metro so wasting time for timeout. Anyway, classicshell will skip them which is great.
I wonder if I can skip the clock screen before log-on screen. Kinda of stupid of Microsoft to think that you turn on your computer to look at the time. :lol: :lol:
Re: PH Easy Remote Print - GEM lpr client éèé
Postby wongck » Sun Jan 27, 2013 5:25 am
test - please ignore.
Postby shoggoth » Sun Jan 27, 2013 9:19 am
This seems to be a very useful and much needed utility! Great job!
Postby wongck » Sun Jan 27, 2013 11:16 am
I hope it is useful for at least a few people. :D
I wasn't bumping this up but was using this to test my new app.
Paolo
Postby Paolo » Sat Feb 09, 2013 9:31 am
Hi, all!
I haven't been visiting AF for a while, but I just found this amazing program!!! I can't believe we finally have a remote printing system.
I would try it right now, but unfortunately I fried my EtherNat and I am waiting for a SvethLana...
Neverthless, GREAT JOB!
jfl
Postby jfl » Sat Feb 09, 2013 12:23 pm
wongck wrote:I wasn't bumping this up but was using this to test my new app.
If your new application allows you to post on atari-forum you got me intrigued :D
Jean-François
GEMDict – GEMClip
Postby wongck » Mon Feb 11, 2013 12:12 pm
I don't jump the gun yet.
Not this program yet. :wink:
Paolo
Postby Paolo » Mon Jul 15, 2013 1:17 pm
WOW!
It worked at first launch! woo-hoooo!!!
I manages to send a document from Papyrus to my wireless printer (HP8500) using the NVDI driver for the most advanced driver available (HP890 IIRC...) using drag&drop.
I would like to use the watchfolder, now, but it didn't work.
So, let's see if I did something wrong:
I made a folder somewhere
I pointed to it with the configure dialog
I sent the printout to that folder setting the path-to-file from within NVDI dialog box (I checked: the print file was there)
nothing happened
Second try:
I pointed to the NVDI spool folder
nothing happened
Hmmm...
