Saint in 320x200 or 320x240 fullscreen?
filevans
Postby filevans » Sun Apr 29, 2012 12:21 pm
hello all,
does anyone please know if it's possible to run saint in 320x200 or 320x240 fullscreen in 60hz?
as i haven't been able to do it so far
thanks to everyone for their help
leonard
Re: Saint in 320x200 or 320x240 fullscreen?
Postby leonard » Tue Nov 05, 2013 10:21 pm
sorry for the late reply :)
No SainT needs at least 800*600 PC resolution to run, because it supports fullscreen ( 384 width screen ) AND medium resolution ( so 768 pixels width are required in the worst case scenario )
On today machine, new SainT always use your desktop resolution in fullscreen (supposed to be the largest one). The new CRT screen emulation requires "big" PC resolution to looks good, so don't be afraid to run saint in 1920*1200, it's fast with today GPU. ( SainT use pixel shader for CRT emulation )
Leonard/OXYGENE.
alexh
Postby alexh » Wed Nov 06, 2013 3:08 pm
Any chance of SainT supporting 120Hz monitors with LightBoost? The code has been implemented in MAME and WinUAE and really does add super smooth scrolling for those lucky enough to have those monitors.
http://www.blurbusters.com/zero-motion-blur/lightboost/
leonard
Postby leonard » Sat Nov 09, 2013 9:14 pm
hi alex!
Oh yes I added lightboost beta support long time ago but never release it :) Do you have light boost hardware? If you want I can PM you a beta version so you can test it. ( I also supported the light-boost black frame).
Leonard/OXYGENE.
Return to “SainT”
