the atari ST screen resolution
FedePede04
Postby FedePede04 » Fri Mar 09, 2012 10:41 am
i don't know if this is the right forum, feel free to move it.
I have a question.
what was atari screen resolution when you removed the 4 screen borders in low res.
could the borders also be remove for mid res and high res. if yes what was the resolution in mid and high res.
Best Regards
Peter
Re: the atari ST screen resolution
Postby exxos » Fri Mar 09, 2012 2:29 pm
I'm not totally sure, but I think you got about 30px on vertical, maybe extra 50 or so left and right ? I have not seen this done in any other res, not sure if it can be done, maybe someone else here can help you better.
Though its not a simple removal of borders, it switched between 50hz and 60hz constantly to get the bottom border removed, but this takes up a lot of CPU time. I assume it has not been done in med res as there are more pixels at work so its possible the CPU just isn't fast enough. I think removing all the borders will take up most of the CPU time anyway.
In anycase, the more borders you "remove" the more cpu time it will take, You end up with very little CPU time after a full removal. HTH.
Postby Cyprian » Fri Mar 09, 2012 2:50 pm
as far as I remember it was 416 x 276 for ST LOW
FedePede04
Postby FedePede04 » Fri Mar 09, 2012 4:24 pm
Thanks guys.
i think that i have found another way to skin the cat.
The thing is that i am thinking of making a drawing program for the Atari, but on the PC.
so insted of a fixed resolution for the no border mode, i think i will make it, so you can chose a custom screen size.
but thanks again.
Best Regards
Peter
Postby Cyprian » Fri Mar 09, 2012 5:08 pm
try GraphFx2 on pc or atari
FedePede04
Postby FedePede04 » Fri Mar 09, 2012 7:44 pm
Cyprian_K wrote:try GraphFx2 on pc or atari
i try it a couple of years ago, there were some things that I did not like. it was something with palettes, and some other small things.
i also think that the program missing some features.
but thanks for the heads up :cheers:
Best Regards
Peter
Return to “Discussion”
cron
