Files samples for ACE
Saturnin51
Postby Saturnin51 » Thu Oct 07, 2010 8:36 pm
I am looking for files samples for ACE in order to try understanding how this tracker runs. Thank you.
Falcon 030-14 Mo - FDI Steinberg -Soundpool Analog 8 - SMP24 - Cubase Audio Falcon 2.06 dongle - SC55 - SG64 - Yamaha CBX-T3
Re: Files samples for ACE
Postby Dal » Thu Oct 07, 2010 11:22 pm
Never used ACE but I imagine any *.MOD file should be accepted by it?
If so, you will get more than enough here:
http://fading-twilight.atari.org/
Saturnin51
Postby Saturnin51 » Fri Oct 08, 2010 7:28 am
Thank you.
nativ
Postby nativ » Fri Oct 08, 2010 7:49 pm
check the Newbeat site for samples and patches
Regards
yerzmyey
Postby yerzmyey » Thu Oct 14, 2010 7:28 am
ACE is a virtual synthesizer, it doesn't read MODs at all.
You can add samples to it but they're only as "additional help" because normally all sounds are generated in real-time there.
You can contact authors about format of the samples (here You can find their addresses:
http://nb.atari.org/main.php?page=contactus ), however I am not sure if they can help because a year or 2 ago, I was asking them about sample-format of their FlexTrax editor (whether 8bit only, or maybe also 16bit samples in extended FLX mode?) and the guy answered he doesn't remember, after years.
Hm.
Anyway I wish You luck and I hope You will upload Your ACE songs if they're ready.
Greetz,
Yerz
http://ym-digital.i-demo.pl/ ATARI 520ST music-band
http://ay-riders.speccy.cz/ ZX Spectrum music-band
http://yerzmyey.i-demo.pl/ ZX/A500/A1200/ST/XL music
https://soundcloud.com/yerzmyey ZX/A500/A1200/ST/STE/F030 music
http://z80.i-demo.pl/ MP3 archive of Z80 chip music
No good deed will escape unpunished.
Postby Dal » Thu Oct 14, 2010 7:34 am
Thanks for clearing that up yerzmyey - the OP used the word Tracker which to me means MOD files. Didn't realise ACE is a V-synth.... also quite impressed that a v-synth existed for the Atari! I must check that out myself
nativ
Postby nativ » Thu Oct 14, 2010 8:02 am
Dal_1978 wrote:Never used ACE but I imagine any *.MOD file should be accepted by it?
Yep Flextracker is abke to load *.MOD's 4/6/8 Channel and apply reverb and delay to all or selected sounds. I think it does work with 16 bit sounds but will still load 8 bit.
Ace is much more than a tracker! And has a novel but very useable interface.
I get on best running ACE in 32Khz in 6 Channel, on my 4MB Falcon.
Regards
Postby Dal » Thu Oct 14, 2010 8:31 am
I shall be the proud owner of a Falcon later so this will be one of the first things I check out once I've set up the OS, shell, boot selector, desk accessories, preferences, file structure etc..... :roll:
