Problem creating thumbnails for uploaded images
Check out the Atari Forum Wiki
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Mon May 10, 2010 9:23 am
I've just uploaded a 320x200 PNG for this page:
wiki/index.php/Torment
and I got these errors:
Warning: escapeshellarg() has been disabled for security reasons in /home/atariforum/domains/atari-forum.com/public_html/wiki/includes/GlobalFunctions.php on line 1321
and the image does not display. Is there a problem with the wiki at the moment ?
PaulB
Re: Problem creating thumbnails for uploaded images
Postby PaulB » Mon May 10, 2010 1:11 pm
Looks like the php function that deals with PNG images has been switched off. Possibly ImageMagick or GD needs to be installed for that. Try it with a .GIF or .JPG instead. Should work fine then. If not, it may be your image is too large and without ImageMagick or GD installed it cannot be resized to fit the screen.
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Mon May 10, 2010 1:15 pm
PaulB wrote:Looks like the php function that deals with PNG images has been switched off. Possibly ImageMagick or GD needs to be installed for that. Try it with a .GIF or .JPG instead. Should work fine then. If not, it may be your image is too large and without ImageMagick or GD installed it cannot be resized to fit the screen.
GIF is bizzarly not a supported file format, will give JPG a go.
the image is 6k :) and ST LOW resolution :)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Mon May 10, 2010 1:19 pm
Postby Mug UK » Mon May 10, 2010 5:20 pm
I've asked Silver Surfer to take a look when he's free.
PaulB
Postby PaulB » Mon May 10, 2010 5:21 pm
I think someone is going to have to look at the back-end settings for the wiki. Perhaps it's security setting are a little too much, and it has certain PHP functions disabled by default i.e. image functions. Images work fine on the the forum. So... same server, same settings. Unless, the wiki itself has it's own admin section where these setting can be turned off (or off by default).
Postby Mug UK » Mon May 10, 2010 7:00 pm
I had a quick look around and couldn't see anything obvious - your pictures appear OK Spiny but still with those messages at the top of the screen.
I did, however, kill off some spammers :)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Mon May 10, 2010 9:33 pm
Mug UK wrote:I had a quick look around and couldn't see anything obvious - your pictures appear OK Spiny but still with those messages at the top of the screen.
yeah, they show ok in the file management bit, but they are broken if you try and link to them:
Desty
Postby Desty » Thu May 20, 2010 12:18 am
It probably needs ImageMagick or NetPBM (to resize the thumbnail) but the security settings are preventing it from calling any external programs...
At least you can work around it by rescaling the png manually and adding it as a "normal" image (e.g. what I did to the article just now) :)
tá'n poc ar buile!
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Fri Jun 04, 2010 12:08 pm
any update ?
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Wed Jun 30, 2010 8:30 am
any news ? it's not very motivating to add stuff to the wiki when it doesn't work :)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Tue Sep 21, 2010 10:36 am
this is now fixed thanks to silversurfer :)
Return to “Wiki Discussions”
