Atari file system support for Linux ?
Re: Atari file system support for Linux ?
Postby DarkLord » Sun Nov 23, 2014 9:57 pm
I use mtools to transfer files back and forth between my kubuntu box and my Atari
formatted SD cards with no problems.
frank.lukas
Postby frank.lukas » Tue Apr 28, 2015 9:29 am
I have Ubuntu 15.04 and I can not mount a Atari CF card with a partition C:\ (500MB) and D:\ (500MB) and a ext2 partition E:\ ...
AdamK
Postby AdamK » Tue Apr 28, 2015 9:42 am
Works for me on Ubuntu 15.04.
frank.lukas
Postby frank.lukas » Tue Apr 28, 2015 2:13 pm
Does the automount work or work it manually ?
Galvez
Postby Galvez » Tue Apr 28, 2015 2:41 pm
frank.lukas wrote:I have Ubuntu 15.04 and I can not mount a Atari CF card with a partition C:\ (500MB) and D:\ (500MB) and a ext2 partition E:\ ...
Was the CF card partitioned through Falcon's IDE port with an adapter?
frank.lukas
Postby frank.lukas » Tue Apr 28, 2015 3:11 pm
I setup the 4GB CF card with HDDriver 9 on a Atari Mega ST with the dual IDE Interface from Alan.
Atari TOS BGM 500MB C:\ and D:\ and on E:\ a ext2 MiNT Volume.
Gparted says that the card has no partitions on it at all !?!
Galvez
Postby Galvez » Tue Apr 28, 2015 3:17 pm
frank.lukas wrote:I setup the 4GB CF card with HDDriver 9 on a Atari Mega ST with the dual IDE Interface from Alan.
Is Alan's IDE interface swapping bytes as Falcon's does?
alanh
Postby alanh » Tue Apr 28, 2015 3:37 pm
As far as I know the Falcon is the same as the ST and TT for IDE partitioning.
Basically Atari's IDE implementation byte swapped and it's required this way for your boot disk.
In HDDRIVER when partitioning under "Compatibility" you can select "Byte Swapping" which will convert back so you can use the disk in your PC.
But remember using "Byte Swapping" means you can't boot from it on your IDE port.
frank.lukas
Postby frank.lukas » Tue Apr 28, 2015 3:54 pm
I use a 256MB second CF card in my dual CF Adapter with the HDDriver TOS/Windows (byte swapping) format without any problems, that is not the case. Data transfer is not my problem, I use NFS too.
I would use my boot CF card with this three paritions on it on a Linux/Ubuntu PC ...
Galvez
Postby Galvez » Tue Apr 28, 2015 4:19 pm
frank.lukas wrote:I use a 256MB second CF card in my dual CF Adapter with the HDDriver TOS/Windows (byte swapping) format without any problems, that is not the case. Data transfer is not my problem, I use NFS too.
Then you would need the Linux kernel to swap bytes when reading the card, I don't know if this is possible.
alanh
Postby alanh » Tue Apr 28, 2015 4:35 pm
That's correct. You'd need to get Linux to byte swap instead if you are using your "boot" disk from the Atari from the IDE port.
mfro
Postby mfro » Tue Apr 28, 2015 6:10 pm
You can always make a byte swapped image of your card (dd if=<device> of=image conv=swab) which you can then mount as loop device. The same way back after you finished modifying the image.
Unfortunately, there is no option for loop devices to do this on the fly.
To avoid the double copy, I usually just register the disk device as hard disk image in Aranym with the "ByteSwap" flag set to "yes". This will give you direct access (provided you get the geometry right).
frank.lukas
Postby frank.lukas » Tue Apr 28, 2015 7:37 pm
... good but too complicated !
I make a test and it will not work, because I was thinking that the CF Card has three partitions on it, two TOS BGM and a Atari ext2 partition. I think it will work with a little single complete TOS partition on the hole card.
a CF Adapter PCB with Byte Swap (Twisted Datalines) would be fine
Postby AtariZoll » Tue Apr 28, 2015 8:43 pm
frank.lukas wrote:... good but too complicated !
That will not work. Because it will swap control byte too.
frank.lukas
Postby frank.lukas » Wed Apr 29, 2015 9:16 am
I try this morning a 2GB SD Card with four BGM Partitions on it, no luck ...
christos
Postby christos » Wed Apr 29, 2015 4:53 pm
There is no good solution for this as far as I can tell. However Aranym can be used as an intermediary. It's not the best workflow but it does work nicely for that.
Basically you setup Aranym so as to read the SD card and you map your atari directory as hostfs for Aranym. Then you can easily transfer files back and forth. For this to work you need to run aranym as root. The method will not work on windows because of two reasons:
a. I don't know how to set it up
b. Aranym expects to see external disk devices as a file (/dev/sdx) and windows doesn't have that capability. Also windows will not assign a drive letter on an atari disk.
My Atari blog
mfro
Postby mfro » Wed Apr 29, 2015 6:05 pm
christos wrote:For this to work you need to run aranym as root.
That's not necessary. It's enough if your user is in a group with sufficient device access permissions (e.g. "disk" on Ubuntu).
christos
Postby christos » Wed Apr 29, 2015 9:54 pm
I only have one user in my system (and guest). I guess I shouldn't say as root but run with sudo. How can I check if my user doesn't have disk permission?
P.S. Most of my linux skills I learned through MiNT so I don't really know much :D
My Atari blog
mfro
Postby mfro » Thu Apr 30, 2015 5:13 am
christos wrote:How can I check if my user doesn't have disk permission?
It must be a member of the "disk" group:
mfro@thinkpad:~$ id
uid=1000(mfro) gid=1000(mfro) Gruppen=1000(mfro),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),108(lpadmin),124(sambashare)
mfro@thinkpad:~$
If it's not, you can add it to the group:
sudo adduser mfro disk
Group membership will then be active for you after the next login:
mfro@thinkpad:~$ id
uid=1000(mfro) gid=1000(mfro) Gruppen=1000(mfro),4(adm),6(disk),24(cdrom),27(sudo),30(dip),46(plugdev),108(lpadmin),124(sambashare)
mfro@thinkpad:~$
christos
Postby christos » Thu Apr 30, 2015 8:31 am
Thanks for this information. I didn't know about that :)
My Atari blog
Postby DarkLord » Thu Apr 30, 2015 2:11 pm
If it helps, my normal user is a member of "disk" here. You might be on to something
there with permissions.
jotego
Postby jotego » Sun Sep 25, 2016 10:52 am
AdamK wrote:Works for me on Ubuntu 15.04.
Could someone detail the exact mount command line they are using? My kernel is supposed to support Atari file system but I cannot get mount to work. :?
My Patreon page here.
mfro
Postby mfro » Sun Sep 25, 2016 1:46 pm
LaurentS wrote:...
- use df command to determine which hard drive is the CF card (generally /dev/hd(n) or /dev/sd(n) n is a,b,c,d,...)
- umount it if it is already mounted
- use the following command to copy the image to the CF card :
dd if=image4Go.img of=/dev/hdn
nb: replace the image4Go.img by the file you need (regarding to the capacity of your CF card). It takes a long time to write the image (several minutes).
Then, if you use IDE, you have to write the little 8K image. The command is :
dd if=imageIDE.img of=/dev/hdn
You can even save your time and directly "connect" Aranym to your CompactFlash card on your Linux machine. Just define the disk device instead of an image file in the PARTITIONX section of your config file:
[PARTITION0]
Path = /dev/sdb1
Present = Yes
PartID = BGM
ByteSwap = 1
Read Only = No
You can than read and write the partition, Aranym will do the byte swap for you on the fly.
If you have correctly set up host networking, you can even do direct scp's to and from the image.
Postby AtariZoll » Thu Nov 30, 2017 2:47 am
AtariZoll wrote:There is Atari partitioning support in Ubuntu Desktop 14.04 .
I need to add here some things. I guess that I did not test it well enough years ago. Especially because Atari file system support seems same in Ubuntu 17 as in 14 .
TOS (AHDI) partitioning support is pretty much limited. Only small (under 32MB) partitions are mounted and accessible. And they are actually same as TOS type partitions in that case. So, all what Ubuntu has as Atari GEMDOS filesystem support is recognizing AHDI type MBR and GEM, but not BIGGEM partitions.
I made self compiling of some old Linux v. in past, some 10 years ago. With included Atari fs. support. And it worked with BIGGEM too, of course. Question is what of current distros still has that option, if it is possible to compile self kernel now ?
Not simple for users - old OS works not on new HW, and versus.
Anyone still interested in subject ?
Postby simonsunnyboy » Thu Nov 30, 2017 5:23 pm
A FUSE based userland driver might be interesting to have. I never had success with the existing Linux kernel support for Atari partitions.
