Back in Black..
This is the gallery. It's where we put the pictures upon pictures of us all showing off our dens and collections.
Back in Black..
Postby DarkLord » Sat May 30, 2009 1:05 am
Wheee, I get to be first (is there a reward for being first with a pic?)... :D
Here is my 256 megs FastRam, 95mhz CT60 powered Falcon, recased in
a Wizztronics rack mount, CTCM, Falcon original keyboard, upgraded
with TT-Touch, Freekeys, and a LiteOn DVD reader/writer. Oh, its also
had the motherboard mods done to it (accelerated bus, DSP, videl, etc).
I love it....
techie_alison
Re: Back in Black..
Postby techie_alison » Sat May 30, 2009 1:13 am
Actually yes, there's a prize. Let's spice things up a bit shall we. :-)
You win the 1st prize for May, for being first. And at the end of each month, someone will win a prize. The next prize is at the end of June, UNLESS there's a mad rush in these 2 last days of May. :D
What would you like Ronald? One of the up-to-date PeSTs perhaps? A diagnostic cartridge (that I'll design and make over the next few weeks)? That wallpaper of yours definitely deserves a prize. :P
Aly :)
ps. I think djbase deserves a prize too, for starting this off, don't you?
If I don't answer or appear to have forgotton then email again, I'm scatty! :)
http://www.logicsays.com/ = Updated Site
http://www.logicsays.com/index1 = Older Site (with more Atari)
Re: Back in Black..
Postby DarkLord » Sat May 30, 2009 3:33 am
techie_alison wrote:Actually yes, there's a prize. Let's spice things up a bit shall we. :-)
Aly :)
Well, I'll take a PeST, if you want, but you know what I'll do with it... I sense another monthly prize at:
T H E D A R K F O R C E ! B B S
:D
Absolutely!
PS Oh! I had the machine turned off when I snapped that pic - should have had it turned on, eh? Here is
what my desktop looks like (I'm using Thing and MiNT).
Desty
Re: Back in Black..
Postby Desty » Tue Jun 02, 2009 1:06 pm
DarkLord, that machine is hot as hell! Looking good indeed :)
:ehum:
tá'n poc ar buile!
Re: Back in Black..
Postby DarkLord » Tue Jun 02, 2009 6:42 pm
Desty wrote:DarkLord, that machine is hot as hell! Looking good indeed :)
:ehum:
Thanks! A lot of others are even hotter - take a look at Didier's machine (Aniplayer author and much more):
http://translate.google.com/translate?h ... %26hl%3Den
and click the Falcon link on the left side panel (down some). Its freaking water-cooled! :D
If you've not been to my web site, follow it from the URL in the sig below and you can see the
internals on my Falcon.
Re: Back in Black..
Postby wongck » Wed Sep 09, 2009 3:02 pm
DarkLord wrote:PS Oh! I had the machine turned off when I snapped that pic - should have had it turned on, eh? Here is
What software did you used to snap that pic?
Re: Back in Black..
Postby DarkLord » Wed Sep 09, 2009 8:04 pm
wongck wrote:What software did you used to snap that pic?
I believe it was ImageCopy. Last version, IIRC.
Re: Back in Black..
Postby wongck » Thu Sep 10, 2009 2:50 pm
I will try it. Some others (of which I can't remember the name) saves the file in IMG format and cannot be easily attached here.
HollisterHawtie
Re: Back in Black..
Postby HollisterHawtie » Thu Sep 10, 2009 6:24 pm
very kewl setup
Kiss me and i'll see stars ...love me and i'll give them to you!
aftermarket exhaust
mustang parts superstore
Re: Back in Black..
Postby DarkLord » Thu Sep 10, 2009 8:09 pm
wongck wrote:Thanks. I will try it. Some others (of which I can't remember the name) saves the file in IMG format and cannot be easily attached here.
Hmm, can't remember - been quite a whlle ago. If it did, I'm sure I used something
under Linux like the Gimp to convert it to something that would upload here.
Re: Back in Black..
Postby DarkLord » Fri Sep 11, 2009 1:17 am
HollisterHawtie wrote:very kewl setup
Thanks! I put a lot of time, effort and resources into it,
but it was well worth it.
Now if I can just get my STacy as tricked out. :)
Return to “Gallery”
