PASTI DAT ??
Methanoid
PASTI DAT ??
Postby Methanoid » Thu Apr 02, 2009 1:51 pm
IS there a more current PASTI CLR Mame Pro DAT than 2006? I have a pile of images I was wanting to run through one.... If its TOSEC affiliated it means it will probably be a couple of years out of date you see... :(
Re: PASTI DAT ??
Postby Mug UK » Thu Apr 02, 2009 6:09 pm
Look at Klaz's list of known PASTI dumps and base your collection on that as they're all known to be working ones. If you're missing some, I'm sure others on here could help you out.
Methanoid
Re: PASTI DAT ??
Postby Methanoid » Thu Apr 02, 2009 9:09 pm
Couldnt find a user called Klaz.. I did look!! Is he somewhere else?
Re: PASTI DAT ??
Postby Mug UK » Thu Apr 02, 2009 9:17 pm
Methanoid wrote:Couldnt find a user called Klaz.. I did look!! Is he somewhere else?
Look here: viewtopic.php?f=47&t=16094
Return to “Pasti & VAPI”
