PCS format
GFA, ASM, STOS, ...
unseenmenace
Re: PCS format
Postby unseenmenace » Mon Feb 25, 2008 11:39 pm
Not quite as impressive but there is also a medium res fullscreen with plasma in Best Part Of Creation from Delta Forces Punish Your Machine
UNSEEN MENACE
Lynx 2 and Jaguar with JagCD
Nyh
Re: PCS format
Postby Nyh » Fri Feb 29, 2008 12:22 pm
Cyprian_K wrote:
SoLo2 wrote:More than 4 colors in a medium resolution screen for Atari ST are found in the presentation logotype of
Asteroids by Sinister Developments,
for example.
I could count more than 8 colors!
and you can find much more colours in this production:
http://www.pouet.net/prod.php?which=12237
Nice one! I wrote a converter for the format.
Hans Wessels
earx
Re: PCS format
Postby earx » Fri Feb 29, 2008 1:42 pm
nice one, ni! feel free to share this source with us :)))
ra's mode is much more suited to regions with edges and lines. and less to more smooth regions. as i could already see at outline2004 where it was released. hint: come to outline this year ;)
Nyh
Re: PCS format
Postby Nyh » Fri Feb 29, 2008 1:52 pm
earx wrote:nice one, ni! feel free to share this source with us :)))
I just dumped a lot of format information in the Atari Wiki. Now there is data on the following formats:
NEOchrome *.NEO
NEOchrome Animation *.ANI
DEGAS *.PI? ? = 1, 2, 3 (4, 5, 6)
DEGAS Elite *.PI? ? = 1, 2, 3
DEGAS Elite (Compressed) *.PC? ? = 1, 2, 3
DEGAS Elite block *.BL? ? = 1, 2, 3
DEGAS Elite icon *.ICN
CrackArt *.CA? ? = 1, 2, 3
ArtDirector *.ART
Tiny *.TN? ? = 1, 2, 3, Y, (4, 5, 6)
Spectrum 512 *.SPU
Spectrum 512 (Compressed) *.SPC
Spectrum 512 (Smooshed) *.SPS
Spectrum 512 Extended *.SPX
Photochrome *.PCS
QuantumPaint *.PBX
Art Director *.ART
C.O.L.R. Object Editor Mural *.MUR
Doodle *.DOO
Cyber Paint Sequence *.SEQ
Animatic Film *.FLM
Animaster Sprite Bank *.ASB
STOS *.MBK
GEM Bit Image *.IMG
STAD *.PAC
Imagic Film/Picture *.IC? ? = 1, 2, 3
IFF *.IFF
RGB Intermediate Format *.RGB
ComputerEyes Raw Data Format *.CE? ? = 1, 2
HighresMedium *.HRM
Overscan Interlaced *.PCI
Picture Packer *.PP1? ? = 1, 2, 3
MacPaint *.MAC
PackBits Compression Algorithm
But because you asked so nice about the HRM:
int find_hrm_index(int x, int c)
  x+=80;
   if(c==0)
     return -1+4*(int)((x+0)/80);
   else if(c==1)
     return 0+4*(int)((x-8)/80);
   else if(c==2)
     return 1+4*(int)((x-40)/80);
  return 2+4*(int)((x-48)/80);
HGLOBAL convert_hrm(unsigned char* gfx)
  HGLOBAL dst;
  unsigned char *data;
  dst=create_dip(&data, 640, 400, 24, 0, NULL);
  if(dst != NULL)
    long y;
    unsigned char*p=data;
    for(y=0;y<400;y++)
      unsigned char* q=gfx+(399-y)*160;
      unsigned char* cp=gfx+64000L+(399-y)*70;
      int x;
      for(x=0;x<40;x++)
        unsigned int plane0;
        unsigned int plane1;
        int i;
        plane0=*q++;
        plane0<<=8;
        plane0+=*q++;
        plane1=*q++;
        plane1<<=8;
        plane1+=*q++;
        for(i=0;i<16;i++)
          int color;
          color=(unsigned char)((plane1>>14)&2);
          color+=(unsigned char)((plane0>>15)&1);
          plane0<<=1;
          plane1<<=1;
          color=find_hrm_index(x*16+i, color);
          color=(cp[color*2]<<8)+cp[color*2+1];
          *p++=colortable[color&0xf]&0xff;
          *p++=colortable[(color>>4)&0xf]&0xff;
          *p++=colortable[(color>>8)&0xf]&0xff;
    GlobalUnlock(dst);
  return dst;
HGLOBAL hrm(char *fileName, char *errorText, char *compressionText)
{ /* medium res interlaced high color */
  FILE* f;
  long int len;
  unsigned char *file;
  HGLOBAL h=NULL;
  file=malloc(93000L);
  if(file==NULL)
    sprintf(errorText, "Out of memory.");
    return h;
  f=fopen(fileName, "rb");
  if(f==NULL)
    sprintf(errorText, "Can not open file!");
  else
    len=packed_fread(file, 93000L, f);
    fclose(f);
    if(len!=92000L)
      sprintf(errorText, "This is not a HRM file!");
    else
      h=convert_hrm(file);
      if(h==NULL)
      else
        sprintf(compressionText, "HRM picture");
  free(file);
  return h;
I will do a full code release next week. I still have some testing to do because I did some heavy editing without testing in the source.
Hans Wessels
bjw66
Re: PCS format
Postby bjw66 » Sat Mar 01, 2008 2:40 am
Nyh wrote:I just dumped a lot of format information in the Atari Wiki. Now there is data on the following formats:
        IFF                                     *.IFF
Hans Wessels
Just some slight corrections on the ST version of DPaint which uses the VDAT SUB-chunks... . You didn't state in the Wiki that there may be several VDAT SUB-chunks within the BODY chunk (actually, there probably "always" are). The BODY chunk by itself is perfectly valid. But there are several VDAT SUB-chunks within it. Each with their own "VDAT" identifier and with their own size longs, one for each plane. But, most importantly, DPaint uses a compression type of 2, which indicates the use of VDAT sub-chunks. Until ST DPaint created that sub-format, "0" meant uncompressed, "1" meant compressed (which was always PackBits). ST DPaint added "2", meaning their own "vdat compression". Every file that is vdat-compressed has compression type 2.
Either way, feel free to use whatever information I sent you by email to add to this Wiki.
bjw66
Re: PCS format
Postby bjw66 » Sat Mar 01, 2008 2:54 am
As for the information I sent you through email, regarding ST's IFF compression 2 format, and regarding the animated "4, 5, 6" extensions, you can use that information to add to the wiki without any restrictions. Common courtesy might require a mention of my contributions, but I really don't care. Use whatever information I sent you through private email. No need for acknowledgements. I got much more from your contributions than you got from mine. Thanks again, Hans. :)
xdelatour
Re: PCS format
Postby xdelatour » Sun Mar 02, 2008 11:24 pm
I found this source code to display PCS pictures. I hope it will help you.
*                   'PCS' display module               *
*               (C) 1992  Douglas Little             *
   OPT   O+,W-
Devpac2_Pro      ; if this option does not work, take it out!
         ; (Devpac2 Pro's dcb.? command is back to front and
         ; can cause problems. If the assembler jams up,
         ; comment this option out and try again.
*   STANDARD HARDWARE EQUATES                     *
LineADD      =   160
PHYS_MED      =   $FFFF8201
PHYS_TOP      =   $FFFF8203
COLOUR      =   $FFFF8240
FREQ         =   $FFFF820A
MFP         =   $FFFFFA00
ENABLE_A      =   MFP+$07      ; int enable A
ENABLE_B      =   MFP+$09      ; int enable B
PENDING_A      =   MFP+$0B      ; int pending A
PENDING_B      =   MFP+$0D      ; int pending B
IN_SERVICE_A   =   MFP+$0F      ; int in-service A
IN_SERVICE_B   =   MFP+$11      ; int in-service B
MASK_A      =   MFP+$13      ; int mask A
MASK_B      =   MFP+$15      ; int mask B
VECTOR      =   MFP+$17      ; MFP vector base
CTRL_A      =   MFP+$19      ; MFP timer A control
CTRL_B      =   MFP+$1B      ; MFP timer B control
DATA_A      =   MFP+$1F      ; timer A data
DATA_B      =   MFP+$21      ; timer B data
HBI_VEC      =   $68         ; Hblank timer
VBI_VEC      =   $70         ; VBI
KBD_VEC      =   $118         ; IKBD
TIMER_A      =   $134         ; General timer
TIMER_B      =   $120         ; Raster timer
BLIT         =   $FFFF8A00
halftone      =   BLIT+00   16*16 pattern mask
src_xinc      =   BLIT+32   increment of next source word (-128 -> +127)
src_yinc      =   BLIT+34   increment of next source line (-128 -> +127)
src_addr      =   BLIT+36   source data address
endmask1      =   BLIT+40   mask for first word in line (or only word)
endmask2      =   BLIT+42   mask for middle words in line
endmask3      =   BLIT+44   mask for last word in line
dst_xinc      =   BLIT+46   increment of next dest. word (-128 -> +127)
dst_yinc      =   BLIT+48   increment of next dest. line (-128 -> +127)
dst_addr      =   BLIT+50   destination screen address
x_size      =   BLIT+54   x-size   (number of words to go)
y_size      =   BLIT+56   y_size   (number of lines to go)
HOP         =   BLIT+58   halftone operation...
blit_op      =   BLIT+59   logic operations
blit_stat      =   BLIT+60   blitter chip status registers
skew         =   BLIT+61   offset bit shift (byte, 0 > +-15)
*   USEFUL MACROS                           *
push   macro
   move.\0   \1,-(sp)
   endm
pop   macro
   move.\0   (sp)+,\1
   endm
pushall      macro
   movem.l   d0-d7/a0-a6,-(sp)
   endm
popall      macro
   movem.l   (sp)+,d0-d7/a0-a6
   endm
delay   macro               ; wait for #n VBI's
   lea      TIMER(pc),a5
   move.w   #\1,(a5)
.wz\@   tst.w      (a5)
   bne.s      .wz\@
   endm
sync      macro            ; clock-cycle timing macro
      IFEQ      NARG-1   ; please don't read this, especially
      IFD      Devpac2_Pro
      dcb.w      \1,$4E71   ; if you are a fan of high level
      ELSEIF
      dcb.w      $4E71,\1
      ENDC
      ELSEIF         ; coding!
      IFLT      \1-3-3
      IFD      Devpac2_Pro
      dcb.w      \1,$4E71
      ELSEIF
      dcb.w      $4E71,\1
      ENDC
      ELSEIF
      move.w   #(\1-3)/3-1,\2
.wc\@      dbra      \2,.wc\@
Calc      set      (\1-3)-((\1-3)/3)*3
      IFGT      Calc
      IFD      Devpac2_Pro
      dcb.w      Calc,$4E71   ; if you are a fan of high level
      ELSEIF
      dcb.w      $4E71,Calc   ; if you are a fan of high level
      ENDC
      ENDC
      ENDC
      ENDC
      endm
CODE:         bra.s   START
VARIABLES:
TIME:         ds.w   1      ; number of seconds to display picture
DATA:         ds.l   1      ; source file
BIT1:         ds.l   1      ; screen 1 address
PAL1:         ds.l   1      ; palette 1 address
BIT2:         ds.l   1      ; screen 2 address
PAL2:         ds.l   1      ; palette 2 address
OLD_SCR      ds.l   1
TIMER:      ds.w   1
INTERLACE:      ds.b   1
HERZ:         ds.b   1
OLD_PAL      ds.w   16
VECTORS:      ds.b   40
START:lea      VARIABLES(pc),a6
   move.w   d0,(a6)+
   move.l   a0,(a6)+
   move.l   a1,(a6)+
   move.l   a2,(a6)+
   move.l   a3,(a6)+
   move.l   a4,(a6)+
   bsr      EMPTY_BUFFER         ; clear keyboard buffer
   bsr      INIT_VECTORS         ; store old vector setup
   bsr.s      DISPLAY_PCS            ; show off fancy piccy
   bsr      RESET_VECTORS
   bsr      EMPTY_BUFFER
   rts
*   DISPLAY 'PCS' ROUTINES START HERE                  *
DISPLAY_PCS:            ; show one of my own snazzy 'PCS' pics.
   bsr      SAVE_SCREEN_SETUP   ; init screen for piccy, saving old one
   move.l   DATA(pc),a0      ; get address of file
   bsr      UNPACK_PCS      ; unpack picture onto screen(s).
   delay      8         ; wait for 10 vbi's (in case of 50/60Hz
   bsr      ENHANCED_DISPLAY   ; switch). Turn on display interrupt.
   move.w   TIME(pc),d1
   mulu      #50,d1
   subq.l   #1,d1
.loop   cmp.b      #57,$FFFFFC02.w   ; wait for
   beq.s      .out
   lea      TIMER(pc),a6
   addq      #1,(a6)      ; wait for 1 VBI
.wtv   tst.w      (a6)
   bne.s      .wtv
   subq.l   #1,d1         ; decrement wait-counter.
   bpl.s      .loop
.out   bsr      STANDARD_DISPLAY   ; when done, remove display interrupt.
   bsr      KILL_PALETTE
   bsr      REPLACE_SCREEN_SETUP
   rts
SAVE_SCREEN_SETUP:
   lea      COLOUR.w,a0      ; store old colours
   lea      OLD_PAL(pc),a1
   moveq      #8-1,d0
.lp   move.l   (a0)+,(a1)+
   dbra      d0,.lp
   move.l   $FFFF8200.w,d0   ; store old screen address
   lsl.w      #8,d0
   and.l      #$00FFFFFF,d0
   lea      OLD_SCR(pc),a0
   move.l   d0,(a0)
   bsr      KILL_PALETTE   ; black screen
   move.l   BIT1(pc),a0      ; clear screen 1
   bsr      CLS
   move.l   BIT2(pc),a0      ; clear screen 2
   bsr      CLS
   rts
REPLACE_SCREEN_SETUP:
   bsr      CLS
   bsr      CLS
   move.l   OLD_SCR(pc),d0
   lsr.w      #8,d0
   move.l   d0,$FFFF8200.w
   lea      OLD_PAL(pc),a0
   lea      COLOUR.w,a1      ; store old colours
   moveq      #8-1,d0
   dbra      d0,.lp
   rts
*   UNPACK A 'PCS' PICTURE                        *
         rsreset
PCS_width      rs.w   1   ; usually 320 for now
PCS_height      rs.w   1   ; usually 200 for now
PCS_interlace   rs.b   1   ; PCS-ST/E = 0 : SuperHam and Pchrome <> 0
PCS_ste      rs.b   1   ; uses ste palette? 50/60Hz?
PCS_start      rs.b   0   ; end of file header
;      bit list...    (PCS_interlace)
;      bit 0      :   if clear > XOR screen1 with screen2
;      bit 1      :   if clear > XOR palette1 with palette2
;      bit 2      :   if set   > interlace on, use bits 0+1,
;               otherwise ignore bits 0+1.
;   1.   if bit 2 is CLEAR then ignore bits 0+1.
;   2.   if bit 2 is SET and bit 0 is CLEAR then XOR
;      screen 1 with screen 2 after decompression. (delta-compression)
;   3.   if bit 2 is SET and bit 1 is CLEAR then XOR
;      palette 1 with palette 2 after decompression.
;      bit list...    (PCS_ste)
;      bit 0      :   if set > use 50Hz otherwise use 60Hz
;      bit 1      :   if set > then pic uses STE palette of 4096.
;   1.   if bit 0 is SET then the picture requires 50Hz,
;      otherwise set to 60Hz (STE or not)
;   2.   if bit 1 is SET, then piccy uses 4096 colour palette.
;   There are 2 or 4 compressed chunks in each file - 1 bitmap and
;   1 palette for each screen, with 2 screens if it's interlaced.
;   The body of a chunk is a 2-byte value (not necessarily on a word
;   boundary) holding the number of control bytes in that compressed
;   chunk. This is followed by a big list of control bytes and data.
;   The bitmaps are horizontally byte-run compressed (like Degas)
;   but wrap around the screen instead of terminating on each scanline
;   (unlike Degas, more like Tiny). The screen planes are compressed
;   entirely separately, (the whole of plane 0 followed by the whole
;   of plane 1 etc.) without a break in the compression. It is just
;   one big string of data. If the screen was empty, the entire data
;   would consist of a control byte 0 (get a word), a control word
;   of 32000 (number of repeats), and a byte of 0 (byte to repeat).
;   The palette is compressed the same way, but using compressed words
;   instead of bytes.
;       For a given control byte, x: (as Tiny standard)
;     x < 0   Absolute value specifies the number of unique bytes/words to
;             fetch directly (from 1 to 127)
;     x = 0   1 word is taken which specifies the number of times to repeat
;          the next data byte/word fetched (from 128 to 32767)
;     x = 1   1 word is taken which specifies the number of unique
;          bytes/words to be fetched directly (from 128 - 32767)
;     x > 1   Specifies the number of times to repeat the next byte/word
;             fetched (from 2 to 127)
UNPACK_PCS:
   lea      INTERLACE(pc),a5
   sf      (a5)
   lea      PCS_start(a0),a1   ; get past file header
   move.l   a0,a6         ; keep for later
   lea      HERZ(pc),a5
   clr.b      (a5)         ; set to 60Hz for now
   btst.b   #0,PCS_ste(a6)   ; check real picture frequency,
   beq.s      .hz60         ; if 60Hz, then leave as it is
.hz50   move.b   #2,(a5)      ; otherwise must be 50Hz
.hz60   move.b   (a5),FREQ.w      ; set up freq.
   move.l   BIT1(pc),a0      ; get dest address of bitmap 1
   bsr.s      UNPACK_BITMAP   ; unpack it onto screen
   move.l   PAL1(pc),a0      ; same with palette
   bsr      UNPACK_PALETTE   ; unpack it.
   tst.b      PCS_interlace(a6)   ; check for interlaced mode
   beq.s      .done         ; if not, skip past it
   st      (a5)         ; set INTERLACE to TRUE.
   move.l   BIT2(pc),a0      ; now unpack second screen and
   bsr.s      UNPACK_BITMAP   ; palette in the same way
   move.l   PAL2(pc),a0
   bsr      UNPACK_PALETTE
   bsr      XOR_BITMAP      ; do delta-decompression if needed
   bsr      XOR_PALETTE      ; on bitmap2 or palette2
.done   lea      PAL1(pc),a5
   add.l      #32,(a5)      ; skip past first 16 colours
   lea      PAL2(pc),a5
   add.l      #32,(a5)      ; in palette banks (used in top border)
   rts
UNPACK_BITMAP:            ; decompress a bitmap.
   moveq      #0,d6
   move.w   #40,d2
   move.w   #200,d3
   moveq      #5,d4
   move.b   (a1)+,d7
   lsl.w      #8,d7
   move.b   (a1)+,d7
.Main   moveq      #0,d0
   subq      #1,d7
   bmi.s      .esc
   move.b   (a1)+,d0
   bmi.s      .B_block_copy
   beq.s      .W_run_length
   cmp.b      #1,d0
   beq.s      .W_block_copy
   bra.s      .B_run_length
.W_run_length
   move.b   (a1)+,d0
   lsl.w      #8,d0
   move.b   (a1)+,d0
.B_run_length
   subq      #1,d0
   move.b   (a1)+,d1
.run   move.b   d1,(a0,d6)
   addq      #1,d6
   and.w      #1,d6
   bne.s      .ok
   addq      #8,a0
.ok   subq      #1,d2            ; drop 1 line
   bne.s      .fine
   moveq      #40,d2
   subq      #1,d3
   bne.s      .fine
   move.w   #200,d3
   lea      2-32000(a0),a0
   subq      #1,d4
   beq.s      .esc
.fine   dbra      d0,.run
   bra.s      .Main
.esc   rts
.B_block_copy
   neg.b      d0
   bra.s      .nw
.W_block_copy
   move.b   (a1)+,d0
   lsl.w      #8,d0
   move.b   (a1)+,d0
.nw   subq      #1,d0
.blk   move.b   (a1)+,d1
   move.b   d1,(a0,d6)
   addq      #1,d6
   and.w      #1,d6
   bne.s      .ok2
   addq      #8,a0
.ok2   subq      #1,d2            ; drop 1 line
   bne.s      .fin2
   moveq      #40,d2
   subq      #1,d3
   bne.s      .fin2
   move.w   #200,d3
   lea      2-32000(a0),a0
   subq      #1,d4
   beq.s      .esc
.fin2   dbra      d0,.blk
   bra      .Main
UNPACK_PALETTE:            ; decompress a palette
   move.b   (a1)+,d7
   lsl.w      #8,d7
   move.b   (a1)+,d7
.Main   moveq      #0,d0
   subq      #1,d7
   bmi.s      .esc
   move.b   (a1)+,d0
   bmi.s      .B_block_copy
   beq.s      .W_run_length
   cmp.b      #1,d0
   beq.s      .W_block_copy
   bra.s      .B_run_length
.W_run_length
   move.b   (a1)+,d0
   lsl.w      #8,d0
   move.b   (a1)+,d0
.B_run_length
   subq      #1,d0
   move.b   (a1)+,d1
   lsl.w      #8,d1
   move.b   (a1)+,d1
.run   move.w   d1,(a0)+
   dbra      d0,.run
   bra.s      .Main
.esc   rts
.B_block_copy
   neg.b      d0
   bra.s      .nw
.W_block_copy
   move.b   (a1)+,d0
   lsl.w      #8,d0
   move.b   (a1)+,d0
.nw   subq      #1,d0
   lsl.w      #8,d1
   move.b   (a1)+,d1
   move.w   d1,(a0)+
   dbra      d0,.blk
   bra.s      .Main
XOR_BITMAP:                  ; delta decompression on bitmap.
   btst.b   #0,PCS_interlace(a6)
   bne.s      .nox
   pushall
   move.l   BIT1(pc),a0
   move.l   BIT2(pc),a1
   move.w   #32000/4-1,d0
.blop   move.l   (a0)+,d1
   eor.l      d1,(a1)+
   dbra      d0,.blop
   popall
.nox   rts
XOR_PALETTE:                  ; delta decompression on palette.
   btst.b   #1,PCS_interlace(a6)
   bne.s      .nox
   pushall
   move.l   PAL1(pc),a0
   move.l   PAL2(pc),a1
   move.w   #16*(3*199+1)-1,d0
.clop   move.w   (a0)+,d1
   eor.w      d1,(a1)+
   dbra      d0,.clop
   popall
.nox   rts
*   COLOUR SWITCHING ROUTINE                     *
*   This is the actual screen-display interrupt and setup code      *
SCANLINE      =   $700
VIDEO_COUNTER   =   $FFFF8209
STE_HAM:
   btst      #1,FREQ.w
   bne.s      .hz50
   move.b   #32-10,SCANLINE.w
.hz60   pea      SCAN_COUNTER_60HZ(pc)
   bra.s      .done
.hz50   move.b   #62-10,SCANLINE.w
   pea      SCAN_COUNTER_50HZ(pc)
.done   pop.l      HBI_VEC.w
   move.w   #$2100,sr
   pushall
   move.l   PAL2(pc),a0
   lea      2*(1-16)(a0),a0
   lea      2+COLOUR.w,a1
   move.w   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
   move.l   (a0)+,(a1)+
.wait   tst.b      SCANLINE.w
   bne.s      .wait
   move.w   #$2300,sr
.read   btst      #0,$FFFFFC00.w
   beq.s      .out
   move.b   $FFFFFC02.w,d0
   bra.s      .read
.out   lea      TIMER(pc),a0
   tst.w      (a0)
   ble.s      .rte
   subq      #1,(a0)
.rte   move.l   PAL1(pc),d0
   lea      INTERLACE(pc),a0
   tst.b      (a0)
   beq.s      .nin1
   lea      PAL1(pc),a0
   move.l   PAL2(pc),(a0)
.nin1   lea      PAL2(pc),a0
   move.l   d0,(a0)
   move.l   BIT1(pc),d0
   tst.b      (a0)
   beq.s      .nin2
   lea      BIT1(pc),a0
   move.l   BIT2(pc),(a0)
.nin2   lea      BIT2(pc),a0
   move.l   d0,(a0)
.nint   lsr.w      #8,d0
.skip   popall
   rte
SCAN_COUNTER_50HZ:
   subq.b   #1,SCANLINE.w
   ble.s      SCREEN_RASTER_50HZ
   rte
SCREEN_RASTER_50HZ:
   move.w   #$2700,sr
   movem.l   d0-a6,-(sp)
   lea      (.ssp)+2(pc),a6
   move.l   a7,(a6)
   lea      VIDEO_COUNTER.w,a6
   moveq      #0,d0
   moveq      #64,d7
.wait   move.b   (a6),d0
   beq.s      .wait
   sub.w      d0,d7
   lsl.w      d7,d0
   sync      55,d0
   move.l   PAL2(pc),a7
   rept      199
   movem.l   (a7)+,d0-a6
   movem.l   d0-d7,COLOUR.w
   movem.l   a0-a6,COLOUR.w
   move.l   (a7)+,28+COLOUR.w
   lea      COLOUR.w,a0
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.w   #0,COLOUR.w
   move.l   (a7)+,(a0)+
   nop
   nop
   nop
   nop
   nop
   nop
   nop
   endr
.ssp   move.l   #0,a7
   movem.l   (sp)+,d0-a6
   pea      ARTE(pc)
   pop.l      HBI_VEC.w
   move.b   #$23,(sp)
ARTE:   rte
SCAN_COUNTER_60HZ:
   ble.s      SCREEN_RASTER_60HZ
   rte
SCREEN_RASTER_60HZ:
   move.w   #$2700,sr
   movem.l   d0-a6,-(sp)
   lea      (.ssp)+2(pc),a6
   move.l   a7,(a6)
   moveq      #0,d0
   moveq      #64,d7
   beq.s      .wait
   sub.w      d0,d7
   lsl.w      d7,d0
   sync      54,d0
   move.l   PAL2(pc),a7
   rept      199
   movem.l   (a7)+,d0-a6
   lea      COLOUR.w,a0
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.l   (a7)+,(a0)+
   move.w   #0,COLOUR.w
   move.l   (a7)+,(a0)+
   nop
   nop
   nop
   nop
   nop
   nop
   endr
.ssp   move.l   #0,a7
   movem.l   (sp)+,d0-a6
   pea      ARTE(pc)
   pop.l      HBI_VEC.w
   move.b   #$23,(sp)
   rte
*   INITIALISE PCS DISPLAY INTERRUPT                  *
ENHANCED_DISPLAY:
   move.b   #$12,$FFFFFC02.w      ; turn off the mouse 'cos it
   move.w   #$2700,sr
   pea      STE_HAM(pc)
   pop.l      VBI_VEC.w
   move.w   #$2300,sr
   rts
STANDARD_DISPLAY:
   move.w   #$2700,sr
   pea      NEW_VBI(pc)
   pop.l      VBI_VEC.w
   move.w   #$2300,sr
   move.b   #$8,$FFFFFC02.w      ; turn off the mouse 'cos it
   rts
INIT_VECTORS:
   lea      VECTORS(pc),a0
   move.l   USP,a1
   move.l   a1,(a0)+
   move.l   HBI_VEC.w,(a0)+
   move.l   VBI_VEC.w,(a0)+
   move.l   KBD_VEC.w,(a0)+
   move.l   TIMER_A.w,(a0)+
   move.l   TIMER_B.w,(a0)+
   move.b   ENABLE_A.w,(a0)+
   move.b   ENABLE_B.w,(a0)+
   move.b   MASK_A.w,(a0)+
   move.b   MASK_B.w,(a0)+
   move.b   DATA_A.w,(a0)+
   move.b   DATA_B.w,(a0)+
   move.b   CTRL_A.w,(a0)+
   move.b   CTRL_B.w,(a0)+
   move.b   VECTOR.w,(a0)+
   move.b   FREQ.w,(a0)+
   move.w   #$2700,sr
   pea      NEW_VBI(pc)
   pop.l      VBI_VEC.w
   move.b   #0,ENABLE_A.w
   move.b   #1<<6,ENABLE_B.w   ; leave IKBD alone
   move.w   #$2300,sr
   rts
RESET_VECTORS:
   move.w   #$2700,sr
   lea      VECTORS(pc),a0
   move.l   (a0)+,a1
   move.l   a1,USP
   move.l   (a0)+,HBI_VEC.w
   move.l   (a0)+,VBI_VEC.w
   move.l   (a0)+,KBD_VEC.w
   move.l   (a0)+,TIMER_A.w
   move.l   (a0)+,TIMER_B.w
   move.b   (a0)+,ENABLE_A.w
   move.b   (a0)+,ENABLE_B.w
   move.b   (a0)+,MASK_A.w
   move.b   (a0)+,MASK_B.w
   move.b   (a0)+,DATA_A.w
   move.b   (a0)+,DATA_B.w
   move.b   (a0)+,CTRL_A.w
   move.b   (a0)+,CTRL_B.w
   move.b   (a0)+,VECTOR.w
   move.b   (a0)+,FREQ.w
   move.w   #$2300,sr
   rts
NEW_VBI:
   push.l   a0
   lea      TIMER(pc),a0
   tst.w      (a0)
   ble.s      .rte
   subq      #1,(a0)
.rte   pop.l      a0
   rte
EMPTY_BUFFER:
   pushall
   bsr.s      FLUSH      ; flush the IKBD properly (sorry, GEM!)
.bak   push.w   #11
   trap      #1
   addq      #2,sp
   tst.l      d0
   beq.s      .out
   push.w   #7
   trap      #1
   addq      #2,sp
   bra.s      .bak
.out   popall
   rts
FLUSH:push.w   d7
.read   btst      #0,$FFFFFC00.w   ; empty hardware ikbd buffer
   beq.s      .out
   move.b   $FFFFFC02.w,d7
   bra.s      .read
.out   pop.w      d7
   rts
KILL_PALETTE:
   moveq      #8-1,d7
   lea      COLOUR.w,a0
.lp   clr.l      (a0)+
   dbra      d7,.lp      ; empty out palette
   rts
CLS:   move.w   #32000/4-1,d0
.loop   clr.l      (a0)+
   dbra      d0,.loop
   rts
Re: PCS format
Postby simonsunnyboy » Mon Mar 03, 2008 11:10 am
Hmm, contains a lot of ugly Devpac specifics 8O
Anyone willing to INLINE for GFABASIC use? :D
I'd like to try to but it comes with few docs, not a defined calling interface and sofar I can't overlook whether it is already PC-relative code...
Re: PCS format
Postby Cyprian » Mon Mar 10, 2008 2:29 pm
Nyh wrote:But because you asked so nice about the HRM:
Hans Wessels
great!
do you have any sources for HRM? I mean shower or converter e.g. BMP to HRM?
prog99
Re: PCS format
Postby prog99 » Thu Apr 10, 2008 11:03 am
SoLo2 wrote:Hello!
I saw a presentation screen by
Sinister Development, raytraced,
in red is the logotype, and was
very incredible because it showed
more than 16 colors, but in
medium resolution! 8)
Greetings,
SoLo2
Its been a long time but I'm pretty sure Asteroids is all running in low res.
All my real skills are undervalued
bod/STAX
Re: PCS format
Postby bod/STAX » Tue Apr 29, 2008 7:57 pm
I've just been looking through the above code on my ST and have a quick question.
I know this was written for use in another language such as STOS or GFA Basic and at the beginng of the routine is requires some 'VARIABLES' in some
of the registers. What I wan't to know is what are the correct offsets for each picture/palette to depack? The code only reads the screen/palette adresses
and doesn't define any.
I've just converted my own picture into Photochrome's 32000 colour format and want to test displaying it with this routine and try to see exacly what's going
on with this display mode.
**** EDIT ****
Forget it, every thing's clear to me now.
So let it be written, So let it be done. I'm sent here by the chosen one.
Re: PCS format
Postby simonsunnyboy » Tue Apr 29, 2008 8:46 pm
It is? Then explain please ;)
bod/STAX
Re: PCS format
Postby bod/STAX » Wed Apr 30, 2008 8:47 pm
Quite simple, you pass the number of seconds you want to display your picture in d0, the address of the picture in a0 and and four buffer addresses in a1-a4 two of those
are the addresses of your screens and the other two are the buffers for the palette data to be depacked, then you just call the assembled routine above.
I've just unravelled the above code and now I have my own display routine that makes it much easier to include 32768 colour pictures into demos and intros. I have one
piece of code that depacks a .PCS picture and saves both pictures and palettes out as raw data and then I have my display routine that uses this data to display the pictures.
It should now be easy to display a picture with no lower border where you could put a scroller and what not into the bottom border. I'll post the code here when I'm done
with it. It's much easier to read than the above code (although it does use the PCS depack routines from the code above).
One thing I did notice is that a PCS picture is not packed as well as it could be. My original picture was packed to 110K and when I repacked it with my display routine with
ICE packer it packed down to 77K.
**** EDIT ****
Ok, here it is. Included is the source code to depack and save a PCS picture into raw data files, a routine to display the raw data as a picture, the picture raw data files,
the PCS converted picture and the original Targa image I ported from the PC (Oh and an executable .PRG if you can't be bothered messing with an assembler).
Have fun with it. :D
Nyh
Re: PCS format
Postby Nyh » Thu May 01, 2008 12:43 pm
bod/STAX wrote:Ok, here it is. Included is the source code to depack and save a PCS picture into raw data files, a routine to display the raw data as a picture, the picture raw data files.
Nice. Only I think it is a complete waste of memory space to expand the display loop the way you do. It makes the program far too big. You can also use a nice small loop. I also fixed the code so it will work in both 50 and 60 Hz. I included the ZIP file including the new display routine.
hbl2:move    #$2700,SR
     movem.l D0-A6,-(SP)
     move.l  SP,save_stack
     lea     $FFFF8209.w,A6
     moveq   #0,D0
     moveq   #$40,D7
sync_wait:
     move.b  (A6),D0
     beq.s   sync_wait
     sub.w   D0,D7
     lsl.w   D7,D0
     move.w  #$0E,D0
wait_disp:
     dbra    D0,wait_disp     ; D0 = 0xffff at the end of the loop
     nop
     movea.l pal_pos2,SP
     move.w  D0,19104(SP)     ; -1
disp_loop:
fix_50_60:
     add.l   D0,D0            ; add.l d0,d0, 8 clocks, 50 Hz
; add.w d0,d0, 4 clocks, 60 Hz
     movem.l (SP)+,D0-A6
     movem.l D0-D7,$FFFF8240.w
     movem.l A0-A6,$FFFF8240.w
     move.l  (SP)+,$FFFF825C.w
     lea     $FFFF8240.w,A0
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.l  (SP)+,(A0)+
     move.w  #0,$FFFF8240.w
     move.l  (SP)+,(A0)+
     tst.w   (SP)
     bge.s   disp_loop
     movea.l save_stack,SP
     movem.l (SP)+,D0-A6
     move.l  #rte_label,$68.w ; disable HBL
     move.w  #$2300,(SP)      ; disable HBL (SR fix)
rte_label:
     rte
Hans Wessels
bod/STAX
Re: PCS format
Postby bod/STAX » Thu May 01, 2008 4:44 pm
I agree it's a waste of memory, that's how the original displays the picture. I was toying with making it into a loop, but could'nt seem to get enough time within
the NOPS. I was going to try and do it like this:
          move.w #199,loop_cnt     ; put this on vbl
.l3                                ; this is the picture display routine.
; display a line of picture here
          subq.w #1,loop_cnt
          cmp.w #0,loop_cnt
          bge.s .l3
I never thought about doing it the way you did (quite simple, really).
MiggyMog
Re: PCS format
Postby MiggyMog » Thu May 01, 2008 9:10 pm
Good work guys.
A quicker program to make the PCS files from BMP/GIF/raw etc especiall in bulk would be good.
Photochrome is really slow?
ROWBEARTOE
Re: PCS format
Postby ROWBEARTOE » Mon May 26, 2008 2:23 am
Hey everyone- I just recently hooked up my Atari Mega ST4 and have been playing around with it. I've been a Spectrum 512 and occasional Quantum Paint user, but now that I've seen what Photochrome can do-WOW!! I would love to convert some of my PCS files I just made and view them on my PC. I've been converting a lot of my work (which is one of the reasons why I hooked up my Mega ST4) to the PC. Most picture files. Reccently I just made my favorite HAM6 killer using Spectrum 512. The picture plays to the strenghth of Spectrum 512 and since the colors are sperated by the color black, HAM6 has to smudge a lot. =)
http://i162.photobucket.com/albums/t268 ... Colors.jpg
Now I'm not a programmer, I just want to be able to convert my PCS files to something like PNG. Thanks for you help.
Re: PCS format
Postby Mug UK » Mon May 26, 2008 7:28 am
Didn't 'Speed Of Light' get a mention earlier on in this thread? Or did that not convert Photochrome?
Re: PCS format
Postby simonsunnyboy » Mon May 26, 2008 9:13 am
Speed Of Light does not convert PCS. PCS is an entire custom format.
PCS is not a file format in the common sense but a special format to be interpreted by a custom display routine which is tightly tied with the ST(e) Shifter and the ST interrupt system. So writing a converter back to other formats would require a lot of work.
Best solution would probably be to get the pictures in their original formats and convert them from there to PNG.
Re: PCS format
Postby Mug UK » Mon May 26, 2008 10:11 am
Ah right .. my mistake :(
Nyh
Re: PCS format
Postby Nyh » Mon May 26, 2008 11:41 am
ROWBEARTOE wrote:Now I'm not a programmer, I just want to be able to convert my PCS files to something like PNG. Thanks for you help.
This ST program will convert almost any ST graphics format:
** supported formats:
** DEGAS: .PI1, .PI2, .PI3, .PC1, .PC2, .PC3, ICN, BL1, BL2, BL3
** Neochrome: .NEO
** CrackArt: .CA1, .CA2, .CA3
** ArtDirector: .ART
** STadCad: .PAC
** Tiny: .TNY, .TN1, .TN2, .TN3, .TN4, .TN5, .TN6
** Doodle: .DOO
** Spectrum: .SPU, .SPC, .SPS, .SPX
** Photochrome: .PCS
** QuantumPaint: .PBX
** Overscan: .PCI
** HighresMedium: .HRM
** DeLuxePaint ST (only the special ST format): .IFF
** STOS memory bank: .MBK
** STOS character set: .CR0, .CR1, .CR2
** Animaster Sprite Bank: .ASB
** Picture Packer: .PP1, .PP2, .PP3
Into a standard .BMP file. Runs fine in 1 MB only bigger high color pictures need 4Mb memory
Hans Wessels
Re: PCS format
Postby simonsunnyboy » Mon May 26, 2008 12:20 pm
simonsunnyboy wrote:Speed Of Light does not convert PCS. PCS is an entire custom format.
Looks like Nyh did that tedious work :D
Nice :cheers:
Re: PCS format
Postby Mug UK » Mon May 26, 2008 12:36 pm
Nice util .. one for the Wiki when I get 5 mins :)
Nyh
Re: PCS format
Postby Nyh » Mon May 26, 2008 1:06 pm
muguk wrote:Nice util .. one for the Wiki when I get 5 mins :)
It think it lacks a front-end.
Hans Wessels
Re: PCS format
Postby Mug UK » Mon May 26, 2008 5:17 pm
wiki/index.php/ST2BMP
Have mentioned it's a TTP file.
Return to “Coding”
